This thread is about: Squeek above drivers door?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hi fellows, I need to get rid off annoying rattle sound which comes from the drivers side above the drivers door. It sounds like plastic ...
Old 9th July 2007, 10:26   #1 (permalink)
Jani's Avatar
Hi fellows,
I need to get rid off annoying rattle sound which comes from the drivers side above the drivers door. It sounds like plastic is rubbing somewhere, but I can't locate what causes it. I have tried to stuck handpaper under the "roofliner" so that it just would stop...but it doesn't help. Here's a picture where the sound comes from..
Please help..I am going more insane than I normally am..
Jani is offline   Reply With Quote
Old 9th July 2007, 10:34   #2 (permalink)
RaZeR's Avatar
Ik also have the same problem. When pressing to it, the sound is gone for some minutes. My car goes wednesday to the dealer for it's first service (20.000 km). I will ask then if they now how to solve it.
Greetz,
Dennis
RaZeR is offline   Reply With Quote
Old 9th July 2007, 10:47   #3 (permalink)
Jani's Avatar
Greetz,
Dennis
Yes, we are talking about the same problem. That's right, when pressing it, the sound is gone for few minutes..and then it comes back..
I'm very sorry because of your problem, but I'm pleased that someone else is suffering with the same thing
Let's work it out!!
Old 9th July 2007, 11:45   #4 (permalink)
davek9's Avatar
Hi, try spraying (wiping) carefully, some silicon spray on the rubber door seals, this worked on previous cars with a similiar sounding problem.
Dave
davek9 is offline   Reply With Quote
Old 9th July 2007, 23:50   #5 (permalink)
PTR
PTR's Avatar
Dave
not a bad idea you can try that also but I think there is another problem
there are some cables in the roof liner and they are not fixed properly and as they vibrateing etc. they are making a noise.
I have just put some foam under the cables and now it is fine..
ask pcr he made the same and he has a better english than me
Old 10th July 2007, 05:15   #6 (permalink)
Jani's Avatar
I also thought that it's cables where it comes from, but in my case I think it's not. But got to still try that foam thing.. With papers I didn't get rid of the sound. Thank's for the tip!
Old 10th July 2007, 10:10   #7 (permalink)
PTR
PTR's Avatar
ok but be careful! it's not very easy to remove the roof liner and the airbag is there also!
I would better go to the dealer and tell him your idea, let him do it!
Old 10th July 2007, 11:09   #8 (permalink)
Jani's Avatar
ohh...well...been there done that.. I know what I'm doing
..those famous last words..
EDIT: In the end of this month..I'm going to go to the dealer and we are gonna sort this problem out. Thank god my friend is working there, so it's very possible that they take me seriously with my problem.
Old 10th July 2007, 11:32   #9 (permalink)
PTR
PTR's Avatar
ok!
Old 11th July 2007, 18:26   #10 (permalink)
RaZeR's Avatar
Today my car had it's first service. I ask the dealer to look at the annoying rattle sound which comes from the drivers side above the drivers door. They have removed a littlebit of foam, because that was gliding against the steal. On my way back (50 minutes drive), It was very quiet in the car (offcourse the radio was on hahaha).
The strip on the upper front windscreen was replaced by a recall of Honda, because the original one could damage the paint. Also they have placed a sort of spring in the fuel cap. With the replacement of the fuel cap, they didn't have that piece in stock. (But my fuel cap has no problems after the first replacement).
It also had the small service (20.000 km). So filters, oil, rubber, total check, etc. has been done. Total costs: €176,00 Euro....
SEE YA!!
Dennis
Old 11th July 2007, 18:58   #11 (permalink)
Jani's Avatar
SEE YA!!
Dennis
Yep same thing here with the front windscreen and with the fuel cap. They are ok, but can you explain where actually the foam where took off? Because there is still couple of weeks when dealer is going to check it..but it makes me so insane that I could try it right away. So tell me please?
Old 11th July 2007, 19:03   #12 (permalink)
PTR
PTR's Avatar
yes I am also intrested!
you could post a pic to show us exactly where and what they removed!
THX!
Old 13th July 2007, 17:23   #13 (permalink)
I got the dealer to check this at my last service. When I picked the car up I was told there's a service bulletin for it. Apparantly when the car is built they leave some plastic clips in place on the lining. However, they have found these work loose and start rattling, so anyone that complains they remove the roof lining and the loose plastic bits. As someone said earlier not a DIY job as there's curtain airbags up there.
taylor is offline   Reply With Quote
Similar Threads for: Squeek above drivers door?
Trim drivers interior door opener bikersupermoto Bugs, faults and irritations 7 10th October 2007 10:15
5 Door Civic - Original Door garnish Doubtingthomas For sale and Wanted 9 3rd October 2007 19:37
Bodywork drivers side door handle clunky pikkumies Bugs, faults and irritations 33 27th June 2007 00:09
Squeaks Roof liner squeek solved Stef Bugs, faults and irritations 17 13th May 2007 23:37
Non-drivers SUPERTEACH General Discussion 8 26th August 2006 22:01
