Old 27th January 2012, 14:38   #1 (permalink)
steve fox's Avatar
Car: 2008 2.2 SE Blueish Silver
Thanks given: 3
Clicking noise from speedo area of dashboard
My 2.2SE has developed a really annoying intermittent clicking/tapping noise from somewhere around the speedo area. It definitely sound as though it's coming from within, rather than the windscreen cowl. It sounds very much like the clicking when the indicators are on, but it's definitely worse when on bad road surfaces. Anybody got any ideas, or had a similar issue?
steve fox is offline   Reply With Quote
Old 27th January 2012, 15:29   #2 (permalink)
furio101's Avatar
Car: 2011 CTS GT
Thanks given: 66
I had a the same sort of noise it came from the vent on the right hand side near the start button, dropped the bottom of the dash and moved it slightly and nosies has gone.
furio101 is offline   Reply With Quote
Old 27th January 2012, 15:35   #3 (permalink)
steve fox's Avatar
Thanks given: 3
Thanks for the reply buddy, but it deffo appears to be in the speedo area.
Absolute pain in the proverbial!
Old 27th January 2012, 16:17   #4 (permalink)
Civinfo Wind Up Merchant
Scotty182's Avatar
Car: 56' 2.2, 5 door, 195bhp
Thanks given: 24
Does it go away if you push or pull the lip above the speedo ??
(mine does)
I see it the same way as when you wake up with the GFs arm over you, just shove it off & hope it stops disturbing you
Scotty182 is offline   Reply With Quote
Old 27th January 2012, 17:11   #5 (permalink)
furio101's Avatar
Car: 2011 CTS GT
Thanks given: 66
I feel your pain my seat has a clicky noise and took 3 weeks to find it and solve it. Just try to diagnose by pushing different parts of the speedo. There is a how to in the wiki that shows you how to remove and replace the speedo housing that may help you stripping down
Old 2nd February 2012, 10:53   #6 (permalink)
Marley365's Avatar
Car: 2006 2.2,EX
Thanks given: 1
Did you resolve this? As it seems I have the same issue
Marley365 is offline   Reply With Quote
Old 5th February 2012, 22:43   #7 (permalink)
sensible's Avatar
Car: 59 plate Type S GT 1.8i
Thanks given: 46
Me too. First I thought it as leaves in the vents but then realised it was a crackling noise coming from the dash around the speedo area. Anyone found a fix for this yet. I am in my third year of the warranty (59 plate) Are dash noises covered.
sensible is offline   Reply With Quote
Old 5th February 2012, 22:58   #8 (permalink)
graham77277's Avatar
Car: 2010 type s gt blue
Thanks given: 2
yes my car has same noise, i think its where the 2 plastics meet
graham77277 is offline   Reply With Quote
Old 5th February 2012, 23:06   #9 (permalink)
steve fox's Avatar
Thanks given: 3
Not found the cause yet - some days it's worse than others, seems no logic to it at all. It's so ANNOYING!!!
Old 8th February 2012, 21:52   #10 (permalink)
mine made the same noise in the morning when it was really cold outside! but was gone in the afternoon!! checked it a while ago and the glue that holds the windscreen to the car is falling off as bits.
ash117 is offline   Reply With Quote
Old 8th February 2012, 22:20   #11 (permalink)
RickHondaR's Avatar
Car: CTR-19625 GT
Thanks given: 665
Remove the dash cowl around the rev counter then simply apply some double sided sticky padded tape to the areas where Honda have used some thin felt tape. Took me less than 20 minutes around 12" of tape and no more rattle
the tape packs this out making it a tighter fit plus stops the plastics rubbing and creaking.
RickHondaR is online now   Reply With Quote
Old 9th February 2012, 10:52   #12 (permalink)
steve fox's Avatar
Thanks given: 3
Thanks, I'll try that.
Old 20th February 2012, 19:10   #13 (permalink)
MeganoOdles's Avatar
Car: Civic FK2 Nighthawk Black
Thanks given: 105
Im having the same problems, if the double sided tape don't work it could be (for me) the km/h mph button hitting against the fascia
my solution... wedged a small piece of card inbetween the gap
MeganoOdles is offline   Reply With Quote
Similar Threads for: Clicking noise from speedo area of dashboard
Meguiar's Plast RX On Dashboard and Speedo Screen stugers Cleaning 7 14th June 2012 09:45
dashboard panel & speedo/radio screen scratches ?? kap01 Cleaning 4 21st August 2010 10:27
Cleaning the speedo area Ilya Cleaning 13 17th November 2009 16:20
Cleaning the speedo area ? kev909_2k Cleaning 37 23rd October 2008 07:02
Squeaks Clicking sound rear pillar area GHGH Bugs, faults and irritations 17 16th April 2008 07:02
