This thread is about: Central Clear Plastic Fouling Bumper, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Is this a crazy theory on part of the problem? When looking at mine (see pics below) mine doesn't look close enough to the corner ...
Old 20th August 2006, 16:45   #41 (permalink)
Fedorov's Avatar
Is this a crazy theory on part of the problem? When looking at mine (see pics below) mine doesn't look close enough to the corner of the plastic for that to have caused the problem on mine, mine looks like the very tip/corner of that piece of bodywork has not been sprayed enough...
...my theory on the others you guys have posted - is it related at all to closing your bonnet/boot???!!!
I watched this particular spot as my wife slammed the boot shut and you get a LOT of movement when doing this - I've not yet opened/closed by front bonnet but now wondering whether it's that nasty drop you do on the bonnet that could be what makes the close contact between plastic + bumper hit each other more???
Worth watching as you drop your lids, go on, go outside and try it a few times...
Old 20th August 2006, 22:07   #42 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
Fed about time you checked under the bonnet, there may be nothing there
Old 20th August 2006, 22:16   #43 (permalink)
Jobo's Avatar
It would be one way of stopping the engine problems!
Jobo is offline   Reply With Quote
Old 21st August 2006, 01:09   #44 (permalink)
Jeffao's Avatar
Checked mine today all is well, rubber spacers in place - April production car.
Jeffao is offline   Reply With Quote
Old 21st August 2006, 19:46   #45 (permalink)
DT
DT's Avatar
Found another place where the paint has rubbed off on my car. On the back passenger side where the top of the boot central light strip / boot handle ends the is some missing paint. You can also see that this side of the top of this side of the light strip is much closer than the other. Had a look at it yesterday and you can see the clear plastic move slightly when you open the boot.
DT is offline   Reply With Quote
Old 22nd August 2006, 09:40   #46 (permalink)
Smell My Cheese!
richierich's Avatar
UPDATE! Just got back from the dealers following inspection, this is the first instance that the dealer has seen of this issue (they always are), there is nothing on the sytem in relation to the problem. They have taken photos and will send them to the warranty people at Honda to see what the recommendations are. There are 3 likely outcomes, 1. Replace bumper. 2. Remove bumper, re-paint section with damage and re-fit. 3. Ignore issue all together and blame customer.
They tried to suggest that because the fog lamp was damaged that something had hit me, moving the bumper, I pointed out the dynamics of such an incident and they agreed the bumper would move the other way.
I would recommend those of you with the issue contact your dealer and get this matter to Honda, until they see it is not an isolated case I think they will not do anything.
Old 22nd August 2006, 19:23   #47 (permalink)
Topcat's Avatar
Well there is no way they can say its customer related, there are enough of us now with the same problem and plenty of pictures to prove it. I am going to sort mine out over next week.
I have emailed What car about the paint issue - im sick of the problems I have had with this car now.
Old 23rd August 2006, 00:06   #48 (permalink)
sco77harris's Avatar
well i have noticed as my bumpers popped out ive got a few small marks forming and will ask them to adjust it on thursday.
however saying this i have had quite a few niggles with the car and i guess it shows when the japanese are daring they face the same issues as other manufacturers.
So far however it has been worth it, to own in my oppinion the best car under 20grand on sale today and is also british made.
Old 31st August 2006, 13:11   #49 (permalink)
Smell My Cheese!
richierich's Avatar
Just had a call from the dealer, they are going to carry out work under warranty on the bumper. I do not know the full extent of the work, whether it is a new bumper or a repair to the existing one. Will post more when I know more.
Rear shocks being done at same time.
Old 31st August 2006, 14:36   #50 (permalink)
sounds like a result!
Not that you should have had to need to go down this route in the first place, but at least they are fixing it
Old 31st August 2006, 15:01   #51 (permalink)
Topcat's Avatar
Mine is going in to be looked at next Wednesday!!
Old 31st August 2006, 17:46   #52 (permalink)
pikkumies's Avatar
Fedorov
Fedorov, no offence but your whole boot seems to be misaligned? I mean it's 0,5cm more "above" than the backlights where the paint is missing?
Old 31st August 2006, 20:15   #53 (permalink)
Fedorov's Avatar
Re: Fedorov
No offense taken, I had noticed it and was on my list of things to be looked at when I book it in - my passenger side mirror is sounding a little dodgy as of yesterday, the motor doesn't sound as healthy, my mirror folds/unfolds while the other one is still going slower...
Old 1st September 2006, 11:15   #54 (permalink)
rmh999's Avatar
I have the same issue with the front bumber rubbing on the clear plastics .... funny thing is the dealer said "he never noticed it" and had never heard of it before....
they also had not heard of leaks into the boot (mine is dry thankfully) or any of the other problems that show up in here...strange that...
Anyway the car is booked it to get it sorted under warranty.....
Rob
rmh999 is offline   Reply With Quote
Old 18th September 2006, 15:15   #55 (permalink)
Smell My Cheese!
richierich's Avatar
Angry
Aaaagggghhhh!!!
Dealer just called, they are bringing the car back having done the shocks, and they have sent some photos off to Honda for them to look at re the front bumper. They already did that on the 22nd August. Thats another day at home and another f**king trip to the dealer. Do they get more money if they only fix one fault at a time?
Old 18th September 2006, 15:27   #56 (permalink)
Jazz's Avatar
Any faults you complained goes in the right ear ( and you think it's the "right" one ) and out goes the left. So do they really really listen ???
No wonder your'e i would definately be......
Jazz is offline   Reply With Quote
Old 19th September 2006, 00:57   #57 (permalink)
joora's Avatar
well, one edge of the front plastic grille (left) is awfuly close to the bumper, so i also expect to see the paint wearing pretty soon
joora is offline   Reply With Quote
Old 19th September 2006, 10:18   #58 (permalink)
Smell My Cheese!
richierich's Avatar
Was talking to the paint guy this morning, he did a couple of repairs for a car hire company last week which involved taking the bumper off, although there was no sign of wear from the front when the bumper did come off there was no paint along most of the top of it, looked like it had rubbed all along.
Old 19th September 2006, 18:07   #59 (permalink)
Topcat's Avatar
My dealershhip has also sent photos of mine to Honda Uk and waiting for their response!!
Old 21st September 2006, 18:17   #60 (permalink)
Honda is fitting a free new front bumper next week as the paintwork has been rubbed away by the plastic. They said my car didnt have the two rubber strips, but im sure I can see them, they're just not doing anything.
Also I scrached the other side of it near the bottom (my fault) so that will dissapear too with a whole new bumper!
timmons is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/bugs-faults-irritations/701-central-clear-plastic-fouling-bumper.html
Forums CivicYume :: Voir le sujet - Ajustment Calandre/pare choc This thread Refback 24th February 2008 21:53
Similar Threads for: Central Clear Plastic Fouling Bumper
Read (and clear) diagnostic error codes with no special tools Pottsy How To 26 12th July 2008 21:31
Computer Central Infomation Display CIVHEAD Electronics 6 12th July 2008 21:12
Remote Central Locking Question? Mr JP Type-R 8 13th June 2007 23:27
Damage damage on my new bumper MARK182 Bugs, faults and irritations 3 4th March 2007 18:03
Satnav Clear SatNav Knat Electronics 3 12th January 2007 19:02
1 2 3 4
