This thread is about: Steering drift (merged), it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Has anyone experienced steering drift at about 70 mph? I purchased my car with 3200 miles on it and soon experienced steering problems. At or ...
Old 7th August 2007, 19:11   #1 (permalink)
KJay's Avatar
Has anyone experienced steering drift at about 70 mph? I purchased my car with 3200 miles on it and soon experienced steering problems. At or just above 70 mph it would drift across the motorway lane and back. The dealer agreed the problem and changed the EPS unit. It was fine for a while but is now showing the same symptoms albeit intermittently. The steering also feels heavy at this speed and will wander down the camber if I let go of the wheel. There is no wear on the front tyres to indicate that the track is misaligned. It is quite twitchy on the rear when driving on the motorway under windy conditions.
It has today been in for a service and to check the steering but the dealer tells me that they have been unable to find any problems with the steering or the rear suspension.
KJay is offline   Reply With Quote
Old 7th August 2007, 19:23   #2 (permalink)
Fillmore's Avatar
I had the same problem, but mine is solved by changing the tyre presure. In my case a bit lower.
Grtz,
Fillmore
Fillmore is offline   Reply With Quote
Old 7th August 2007, 20:49   #3 (permalink)
Greedy's Avatar
Have a similair problem on my Accord. It has the 17" option with a 225 tyre. Wider tyres have a habit of picking up the grain of the tarmac, ie when one side has a better grip level than the other then this affects roling resistance which can effectively 'pull' the car accross the road. It is more pronounced on wider tyres which is the trend for newer cars.
That's also why it can be affected by tyre pressure which also affect roling resistance, slight differences accross axel can pull the car too.
Solution - keep your pressures even and keep 2 hands in the wheel
Old 7th August 2007, 20:56   #4 (permalink)
KJay, the first thing I would do (and I've had this on 2 cars) is to take it to have a full geometry check by someone with the right kit and the proper know-how. An independant tyre dealer with a nice 4 wheel laser rig will do OK, or better still go to a specialist like AMD in Bicester (don't know whether they will scratch their heads with a Honda though).
I have also found that tyre brand can make a difference, what brand/size do you have?
Old 13th August 2007, 22:43   #5 (permalink)
KillingJoker's Avatar
Hi Kjay,
I've had a drifting problem at 'any' speed ever since I first owned the car. The dealer insists that it drives perfectly and it is just very camber sensitive on UK roads in particular. I've never really been happy with this explanation (I've asked them to look at this on several occasions) but have just learned to live with it as a 'feature' of the car (as per a lot of it's other 'extra' features not listed in the brochure - lol).
Cheers,
KJ
KillingJoker is offline   Reply With Quote
Old 21st August 2007, 08:54   #6 (permalink)
South's Avatar
Keeps steering to the right...
I have my Type-S for over two weeks now and I'm fairly satisfied.
There are some minor issues I do have to get used to, but nothing which makes me dislike the car.
However, there's one 'major' problem: If I take my hands of the wheel, it steers gently to the right. If I have my hands on the wheel I do not notice it, so it's not that bad, but still.... it's not okay.
I went to my local Honda dealership and he (I hope this is the correct English) alligned the wheels.
I got it back and it was even worse !!!
So again back to the dealership and he put everything back as it was and said there was nothing else he could do.
It had something to do with Honda's power steering which makes the car go to the right.
Now, I'm not that technical, but I think that's a load of BS !
A car shouldn't do that, right ????
So what could cause this ?
South is offline   Reply With Quote
Old 21st August 2007, 08:58   #7 (permalink)
HACKIN & SLAYIN
Most car will pull when you take your hands off the wheel. Dont
Old 21st August 2007, 08:58   #8 (permalink)
I have had this problem on other cars and it has always been corrected by aligning the wheels. My Civic is fine however.
Try and independent tyre dealer, some have this equipment.
Old 21st August 2007, 09:00   #9 (permalink)
HACKIN & SLAYIN
My Cooper S pulls to the left aswell , but its a piece of junk
Old 21st August 2007, 09:29   #10 (permalink)
South's Avatar
The dealership outsourced it a tyre dealer, cause they appearantly didn't have the equipment.
But again, it did not help.. it became worse even !
Old 21st August 2007, 09:56   #11 (permalink)
CopyCatz's Avatar
Try to find another Honda dealer that does have the equipment. I haven't had very good experiences with independent tyre dealers when it comes to taking care of a car.
CopyCatz is offline   Reply With Quote
Old 21st August 2007, 11:05   #12 (permalink)
Yes, I agree.
A Honda dealer with the equipment would be the first choice.
I had my Merc sorted out by a offiicial Mercedes dealer.
It is wonderful to drive after that!
Old 21st August 2007, 15:10   #13 (permalink)
Topcat's Avatar
Could uneven air pressure in the tyres affect it also? I pressume you or the tyre people have checked the air in the tyres.
Old 21st August 2007, 15:28   #14 (permalink)
It could, worth a check (as it won´t cost anything).
But really noticable problems are usually wheel geometery issues.
Old 21st August 2007, 17:43   #15 (permalink)
True
Old 21st August 2007, 18:29   #16 (permalink)
Dutch_Civic's Avatar
I tested mine yesterday at 50 mph and is goes perfectly straight. I can shift up and then brake for a traffic light without having to touch the wheel. Even with teh 18" wheels, i have no problems whatsoever. The steering feels very safe, even under heavy braking.
Dutch_Civic is offline   Reply With Quote
Old 22nd August 2007, 08:38   #17 (permalink)
South's Avatar
So my dealer's comment about it having something to do with the power steering is untrue ?
Old 22nd August 2007, 10:04   #18 (permalink)
ciderman4's Avatar
Not trying to be funny but any car should normally pull slightly to the left or the right depending upon which side of the road that you drive. This is to do with the camber of the road.
Obviously, if it's pulling dramatically then you need to get the tracking done and check wheel alignment and tyre pressures.
ciderman4 is offline   Reply With Quote
Similar Threads for: Steering drift (merged)
Trim Damaged leather steering wheel Odiebla Bugs, faults and irritations 21 5th February 2008 16:19
steering wheel arm near foot pedals tweedie General Discussion 19 17th April 2007 16:35
Steering Steering almost sorted PhilCarrie Bugs, faults and irritations 1 17th February 2007 01:56
Steering tighter? PhilCarrie General Discussion 6 18th January 2007 15:12
Steering Dead Zone? Cad General Discussion 5 9th June 2006 18:57
