uneven power delivery
Hi, can anyone help with this very annoying problem?
I have a 2007 1.8 civic which has uneven power delivery in a most gears, it feels like lag or missfire / hicup. I have just been on a 100 mile motorway run and it was driving me crazy. Cheers Chilli
![]() Car: 2006 1.8 Sport Ishift Milano
Thanks given: 130
Has it had a thorough service recently? How many miles has it done? Once the engine is warmed up can you see any smoke or cloudiness from the exhaust (note on a cold day you will see cloudiness regardless).
![]() Car: 56 2.2 I-Ctdi EX NHB
Thanks given: 93
First thing I'd try is in the same situation, turn off the vsa and try again, atleast then you can iliminate traction control/abs sensors being faulty...
Cockup Specialist
Thanks given: 739
Check your battery connections as a 1st port of call.
Then as above....plugs/coils/leads No fault codes ? No datalogging ? |
Cheers for the replies, I think I will change the plugs first to see if that helps.
No fault codes have flashed up, it just feels odd.7 Cheers again, chilli |
[ Laird Mac Nac Feegle ]
Thanks given: 297
Dirty injectors perhaps
Run a can or two of BG44K through it |
Similar Threads for: uneven power delivery
| Brakes Uneven Pad wear... | onweed | Wheels, Tyres, Suspension and Brakes | 8 | 14th September 2011 21:45 |
| Suspension Uneven ride height. | Mr Lovedog | Wheels, Tyres, Suspension and Brakes | 24 | 12th April 2010 23:05 |
| Brakes Uneven brake wear, why? | matg | Wheels, Tyres, Suspension and Brakes | 1 | 31st May 2009 17:53 |
| Tyre Life Uneven tyre wear | Muz | Wheels, Tyres, Suspension and Brakes | 23 | 27th June 2008 23:33 |
| Tyre Life Uneven tyre wear | Miggins | Wheels, Tyres, Suspension and Brakes | 57 | 14th April 2007 11:31 |
