Old 14th May 2012, 12:56   #1 (permalink)
-Mick-'s Avatar
Car: '59 MR CTR GT
Thanks given: 20
Recall and a creak
Guys,
I've been issued with a recall letter that advises me to go and get the wiring harness checked as it could be a fire risk.
No problem with that but I also have another problem that I'd like to know more about / whether it is common before I take it is as I'll mention it as well!
Basically when the car has sat for a long period of time, say over night, when I pull off the drive I get a lot of creaking from the rear of the car. I suspect this can only be the suspension. It's usually worse if the car has been left on the drive and not garaged overnight.
Is this a common thing that others have had and if so is it something that needs to be sorted? I obviously rather it didn't make the noise but I'd imagine the garage might try the old 'they all do that, it's normal' line.
Thanks for any advice in advance
Oh btw, car is a '59 plate with 5k on the clock.
-Mick- is offline   Reply With Quote
Old 14th May 2012, 13:07   #2 (permalink)
無限 Unlimited
Laney's Avatar
Car: 59 Mugenised CTR
Thanks given: 257
I've had this creaking from the rear of the car, I think it's just the handbrake and the pads being released nothing to worry about.
Laney is offline   Reply With Quote
Old 14th May 2012, 13:13   #3 (permalink)
THE BEAST
hagan71ctr's Avatar
Car: CTR GT DEEP BRONZE PEARL
Thanks given: 416
One or two things on the back the well known rear suspension & also the exhaust hangers are prone to making the creaking noise too ? The wiring harness if it's not under the engine mount it's ok ? The basically just lift up bonnet & to see if it's secure away from the engine mount took them literally 60 seconds to check mine when I had it in for mot & service for the creaking there is a few how to to cure the noise but if yours is still under warranty let them sort it as they know about it long winded I do babble but hope that helps
hagan71ctr is offline   Reply With Quote
Old 14th May 2012, 13:14   #4 (permalink)
-Mick-'s Avatar
Car: '59 MR CTR GT
Thanks given: 20
Definitely not the pads / discs as it does not happen when it first moves off, only when the angle of the car changes with the drive / road level change
Old 14th May 2012, 13:16   #5 (permalink)
-Mick-'s Avatar
Car: '59 MR CTR GT
Thanks given: 20
Thanks! will just mention it when I take it in then.
If it's the harness next to the mount on the left as you look at the car then it's not trapped
I'll still take it in before the last service though as that will be the end of the warranty.
Old 14th May 2012, 13:17   #6 (permalink)
stevenmcc's Avatar
Car: # 39 Type R GT,Milano Red.
Thanks given: 19
i had the creaking noise when first moving off and turning corners for first 5 min or so. handbrake would only make a noise first time you move if the pads were stuck on a bit,like mine does after being sitting for 7 weeks while im at work. it must be the exhaust or the suspension settling,after i got my mods which included exhaust and suspension done it doesnt do it anymore. nothing to worry about imo.
stevenmcc is offline   Reply With Quote
Old 16th May 2012, 10:02   #7 (permalink)
CCC
CCC's Avatar
The creaking noise is the suspension, my cars has always done this from new, its worse when the weather is really cold outside. The noise disappears after a couple of minutes or so, I won't even bother getting the dealer to check it as its just one of those things, lets call it a feature.
CCC is offline   Reply With Quote
Old 16th May 2012, 10:20   #8 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 833
Don't know if you've got an warranty left but IIRC you can get the rear dampers changed if they are creaking when setting off.
Old 24th May 2012, 10:14   #9 (permalink)
-Mick-'s Avatar
Car: '59 MR CTR GT
Thanks given: 20
Guys, thanks for you help so far with this!
Since the weather has been nice I've also noticed that I have a loud metallic clicking noise that I have since read on here is a common issue as well! Seems to be a few things annoying on a car with only 5k on the clock!!
Anyway, to the point! I'm looking to get the car booked in to have the recall check and to check out the click and creak noises that I seem to have! Does anyone recommend a particular (friendly) Honda garage in the Washington area? Ones near that spring to mind are the one on Scotswood Road and one on Wessington Way.
Thanks again!
Old 24th May 2012, 11:49   #10 (permalink)
TH3DOCTOR's Avatar
Car: 09 Championship White Type R
Thanks given: 720
Thanks again!
This noise will probably be the sub frame points need re greasing it is a common problem tho not serious is very annoying and will be covered FOC. Had this with mine PITA!!
TH3DOCTOR is offline   Reply With Quote
Similar Threads for: Recall and a creak
suspension creak cache Torque Developments International PLC 9 25th May 2011 16:42
Suspension Another rear 'creak' story Ferny Bugs, faults and irritations 32 19th January 2011 22:02
Squeaks squeak/creak darron Bugs, faults and irritations 0 11th January 2010 17:57
Squeaks Creak zoidy Bugs, faults and irritations 0 18th April 2009 17:21
Squeaks Another creak.... Bungle Bugs, faults and irritations 41 23rd December 2006 07:17
