This thread is about: Stereo Power with No Keys?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hi guys, I was just in a carpark earlier waiting for someone so thought i'd turn on the radio. I must say i was rather ...
Old 9th September 2007, 21:31   #1 (permalink)
><((('> o O
pekwah1's Avatar
Hi guys,
I must say i was rather disappointed when it wouldn't turn on without the key.... even my cheap plastic ford had this function!
Just thought i'd have a rant...
pekwah1 is offline   Reply With Quote
Old 9th September 2007, 21:41   #2 (permalink)
Perfect Guy!
Brodick's Avatar
But fords have to pile the kit in them cause they are bad
Old 9th September 2007, 21:45   #3 (permalink)
Jack The Lad.'s Avatar
Turn the volume down for some reason whilst driving, forget about it, leave the car overnight and one flat battery in the morning Mate.
Jack The Lad. is online now   Reply With Quote
Old 9th September 2007, 21:47   #4 (permalink)
><((('> o O
pekwah1's Avatar
Well i was intending that the car would turn the stereo off when you take out the keys, but my ford would let you turn it back on and would auto-off after an hour.
Old 9th September 2007, 22:51   #5 (permalink)
Last Ford car I had was a new Capri 3 litre.
Really thought that I was Jack The Lad in that one, until the gear shift came off in my hand whilst doing 50+.
To be fair, I suppose they have moved on a bit since then, ---------- Maybe. ?
Old 9th September 2007, 23:02   #6 (permalink)
Honda's standard seems to be - no keys = no power to anything
Windows won't work (ok, they carry on working for 30 seconds or so)
wing mirrors won't fold
radio doesn't
all not great, especially if you want to sit in the sun with the doors open, windows down, having a pinic and listening to the radio
because if you do that, you have to leave the keys in, and then all you get is the 'ping ping ping' - you've left your key in the car warning
Old 9th September 2007, 23:40   #7 (permalink)
This is one thing I miss from the Passat, the radio goes off with the ignition but you can then turn it on via the on off switch with out the keys it. Nice to have as you say if you have the door open it bloody pings all the time.
cylon2007 is online now   Reply With Quote
Old 20th September 2007, 16:06   #8 (permalink)
Woo frakkin' Yay
Mercifull's Avatar
I wouldn't mind so much having the key in the car but the beep beep beep noise is really annoying. Like TTDegs said i like to sit in my car on a nice day and listen to the music and I cant have my door open or is beeps at me
Mercifull is offline   Reply With Quote
Old 20th September 2007, 17:36   #9 (permalink)
seejayess's Avatar
. . . and thank god for that!! Nothing more irritating than being subject to other peoples second hand music. You get enough "cruisers" with the windows down blasting the neibourhood with bass dross. In fact there should be a window lock engaged when the radio is turned on . . .
. . . . Meldrew exits stage left
seejayess is offline   Reply With Quote
Old 20th September 2007, 18:02   #10 (permalink)
Interestingly the car will eject CD's with the power off....
Old 21st September 2007, 13:08   #11 (permalink)
The Doctor's Avatar
Amen to that. Get an MP3 player & headphones is what I say!
The Doctor is offline   Reply With Quote
Old 21st September 2007, 13:15   #12 (permalink)
JoeyF's Avatar
From memory it is possible to open the doors and listen to the radio but only if you turn the key as far a sit will go (as if you were just about to press the start button!) and leave it, once the seatbelt buzzer has stopped you should be OK.
Not sure if this damages anything on the car but it does work.
Old 21st September 2007, 13:23   #13 (permalink)
Does the seatbelt buzzer not repeat after x amount of time anyway
malett is offline   Reply With Quote
Old 21st September 2007, 13:23   #14 (permalink)
dondon's Avatar
IIRC, if you leave the engine running as well, it only pings once!
dondon is offline   Reply With Quote
Old 21st September 2007, 13:23   #15 (permalink)
JoeyF's Avatar
From memory I think you can do this all you need to do is turn the key as far as it will go (as if you were just about to press the start button!) and leave it there, after the seatbelt warning beeps stop you can open the door and listen to the radio. Yes all the ingnition lights come on but it does the trick.
Not sure if it causes any damage to the car though!
Old 21st September 2007, 13:24   #16 (permalink)
JoeyF's Avatar
Ignore my second post my PC is playing up!
Old 21st September 2007, 13:32   #17 (permalink)
JoeyF's Avatar
I think this only happens when the engine is running and you are in motion, I know for definite this happens in this way for the passenger seat.
Old 21st September 2007, 18:07   #18 (permalink)
bonzo's Avatar
Not exactly, some car radio's have a function whereby after the key is turned off, the radio will continue to operate for a pre selected time (say 30 mins) this would be a good idea on the Civic.
I concur with others that not being able to listen to the radio with the door open (when cleaning for example) is annoying with that bleep bleep bleep,,
bonzo is offline   Reply With Quote
Similar Threads for: Stereo Power with No Keys?
Stereo, custom made for FN2 trunk anar Type-R 17 30th October 2007 21:51
Technical Type R Stereo Questions Ralphy Ipods, MP3 Players and ICE 3 24th July 2007 21:23
Music Stereo Frozen Everlong Bugs, faults and irritations 9 19th July 2007 19:40
Alarm Flip Keys pekwah1 Electronics 19 15th July 2007 23:53
Power Lap Maldax Type-R 1 18th February 2007 23:02
