This thread is about: What could this be?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; My car has now developed a strange groaning, creaking grinding sound cant decide the best word to describe it but it as I bear left ...
Old 10th October 2007, 17:28   #1 (permalink)
Topcat's Avatar
What could this be?
My car has now developed a strange groaning, creaking grinding sound cant decide the best word to describe it but it as I bear left or right (mainly left) it is very noticeable at low revs and does it when going forwards or in reverse.
It sounds like it is coming from under the car possiblly connected to steering wheel movement or maybe the wheels. It does it whether I am braking or not so dont think it is connected to the brakes - will I ever be free from the dealership Argggggggggg!!!!
Any ideas?
Old 10th October 2007, 17:34   #2 (permalink)
Bungle's Avatar
Could it be the torsion beam on the rear suspension groaning as the wight is shfting, TC?
Old 10th October 2007, 17:41   #3 (permalink)
It could be the lower knuckle joint - maybe?
TC - whilst this is not normally something I'd recommend due to scrubbing your tyres, what happens if you turn the steering wheel whilst not moving?
Obviously you will hear the sound of the tyres scrubbing on the ground, but it will show if it something rotating (drive shaft etc) which is causing it, or something to do with the steering...
Old 10th October 2007, 18:05   #4 (permalink)
Topcat's Avatar
Thanks TT I have just tried this, the noise now appears to be coming from the steering column or somewhere around that area but the noise gets worse the more the steering wheel turns to the left and as you come back to the right, by the time I have got to full lock to the right it has stopped.
It sounds like a rumbling creak rather than a grinding sound I have decided
Old 10th October 2007, 18:24   #5 (permalink)
welcome TC
Unfortunately, this sounds to me like a fairly urgent trip to your favourite place
If it is the knuckle joint, then you don't want it to wear and fail!
Although it's not normally a greased item...
One other thought - might we just worth checking that your wheels nuts are tight too
and one more ()
the other bit that is near the knuckle, and is supposed to be greased, is the tie rod end.
From memory, it was one of these 2 items which mysteriously failed on someone's car in here - but they didn't progress it with Honda and just paid for the replacement bits.
Old 10th October 2007, 19:16   #6 (permalink)
Topcat's Avatar
welcome TC
and one more ()
Marvelous I will call them tomorrow, they will be sick of my name soon
Old 11th October 2007, 15:35   #7 (permalink)
Topcat's Avatar
Its the steering rack - booked in on the 22nd October
Old 11th October 2007, 18:34   #8 (permalink)
Perfect Guy!
Brodick's Avatar
connected to any of your bumps and scrapes??
Old 11th October 2007, 18:49   #9 (permalink)
Topcat's Avatar
Not likely the accident was the side of the rear bumper back in February and that was a scrape not a hit.
More likely to be down to Honda's inferior workmanship and cheap parts
Old 11th October 2007, 18:57   #10 (permalink)
Perfect Guy!
Brodick's Avatar
( to much of a gentleman to start another debate on that subject )
good to hear you are getting it fixed quickly tho TC
Old 12th October 2007, 07:04   #11 (permalink)
Tell them to be careful of the paint whilst in their care.
Old 14th October 2007, 05:51   #12 (permalink)
This sounds much like a problem I've been having...
Grinding noise.
Old 14th October 2007, 09:23   #13 (permalink)
Topcat's Avatar
Grinding noise.
CZ have you tried doing what TT said, when my car is stationary and I turn the steering wheel the noise is quite bad, when I took it to the dealer we didnt need to drive anywhere for them to hear it and each day the noise is getting worse.
Old 15th October 2007, 01:14   #14 (permalink)
The dealer assured me everything was fine having looked at it. Could possibly be the nuts but there is no reason why they would be loose. I'll make enquries if I ever get some time off work!
Old 15th October 2007, 04:17   #15 (permalink)
Honda Tardis
LoonyJohn's Avatar
Just guessing TC, but probably not the steering rack itself, but the electric motor that gives you power steering. there is a sensor which spots any torque applied by the steering wheel, and if it is over a certain amount, compensates by using a small but powerful electric motor
Probably isn't dangerous just yet, but I'd say the bearings in the motor are shot. It doesn't sound like the rack itself, as when you turn a steady turn, the rack is locked into one position, but the motor would still be applying a force to make your steering feel light.
Of course, once your PS motor dies, then you have no power steering, and your car would fail an MOT..
CZ try with your engine running, and car stationary, and apply a slight turn on your wheel, so you can here the PS motor straining slightly...
LJ
LoonyJohn is offline   Reply With Quote
Old 15th October 2007, 22:10   #16 (permalink)
Diesel Lover
richierich69's Avatar
Ditto to all the annoyances and strange noises from the steering called Honda in Letchworth today and they have me booked in for tuesday pm grrrrrreat service just hope they can fix it soon
richierich69 is offline   Reply With Quote
Old 28th October 2007, 19:11   #17 (permalink)
Topcat's Avatar
Got the car back yesterday and today the same noise is back
Maybe I was meant to buy a Jazz seeing as I spend most of time driving one !!
Old 28th October 2007, 19:14   #18 (permalink)
That is never fun...
Back to the dealer I presume.
Old 28th October 2007, 20:36   #19 (permalink)
Munro's Avatar
I would consider telling them you are concerned about the safety of the car in writing - that always makes the dealer extremely careful to fix the problem. They may replace the rack and various other parts while they are investigating just to make sure they fix it this time round (under warranty of course!) You might try for a better courtesy car as well - since you have been unlucky with problems so far (Type R ?)
Hope you have better luck with your car soon !
Old 30th October 2007, 18:24   #20 (permalink)
Topcat's Avatar
Back to Honda today, car booked in for 8th November they now want to look at the suspension
