This thread is about: How long does it take to get hot air?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Round about 10 minutes/2 miles here (through built up area). For some reason though, I only get warm air for a while, then it's blasts ...
Old 25th October 2007, 11:32   #21 (permalink)
Cad
estranged
Cad's Avatar
For some reason though, I only get warm air for a while, then it's blasts of cold air (Honda's method for waking drivers up maybe?). I've noticed that I only get warm air back if I have at least 15 degrees difference between outside temp and the temperature set for A/C.
Old 25th October 2007, 15:58   #22 (permalink)
under a minute for me
MoOriginal is offline   Reply With Quote
Old 26th October 2007, 14:06   #23 (permalink)
sw65's Avatar
Hot air
8 degrees outside this morning. Timed it. 5 minutes for hot air; about 3 miles
sw65 is offline   Reply With Quote
Old 26th October 2007, 14:34   #24 (permalink)
Bog
Bog's Avatar
About 2-3 mins for my 1.8 - quickest car I've had (Heater and speed )
Old 26th October 2007, 15:56   #25 (permalink)
Very quick, couple of mins at max.
Will be interesting to see when it get really cold.
MUCH faster than my other car... but then that has silly ammounts of fluid and metal to heat up.
Old 16th November 2007, 07:14   #26 (permalink)
3rd Honda's Avatar
This morning, -2C on outside gauge, after 10 minutes and about 5 miles, arrived at the office - temperature gauge not moved off cold stop (not even to bottom of scale), and windscreen still trying to freeze up from freezing fog. No heat of any significance from blower at all.
My other two diesel cars are much better than this!
Old 16th November 2007, 07:20   #27 (permalink)
TANSTAAFL!
GHGH's Avatar
Diesels are efficient engines not producing much heat - in norway diesel cars frequently have an additinal heater fitted.
This can be the explanation - your other cars have heaters.
Old 16th November 2007, 07:48   #28 (permalink)
montana's Avatar
My old Golf 140 TDi sounded like a tractor and would have hot air just as I left the estate.
My new Type S GT does take twice the distance. It's obviously a lot more fuel efficient.
I don't mind waiting the extra time.
montana is offline   Reply With Quote
Old 16th November 2007, 11:09   #29 (permalink)
The CIvic diesel also has one but you need at least 5 mintes to get warm air, in the Golf the heater is combustion-based AFAIK
Old 16th November 2007, 11:26   #30 (permalink)
JohnH's Avatar
This morning (-4 DegC) our diesel took about 5 mins and 2 miles, I really miss the heated windscreen in our previous Focus though - don't care what anyone says about the 'lines in the screen', it's worth its weight in gold this time of the year.
I also noticed that a patch of screen just above the LHS wiper doesn't de-ice with the blower - guess it's too low down ? Oh for a heated screen.....
JohnH is offline   Reply With Quote
Old 16th November 2007, 11:33   #31 (permalink)
Perfect Guy!
Brodick's Avatar
2 mins this morning in the Civic -outside temp was 0
( I love the 1.8 i-vtec engine - it's just the best)
Old 16th November 2007, 11:45   #32 (permalink)
TANSTAAFL!
GHGH's Avatar
Unfortunately I start the morning trip with a 2 km descent, so I don't use any fuel nor get any heat before the road flats out, hence you beat me with three minutes.
Old 16th November 2007, 13:25   #33 (permalink)
3rd Honda's Avatar
Actually one does (but not working at present) - and the other doesn't - but both quite a lot faster to warm up than the Civic.
I have never seen any evidence that the claimed PTC electric heater works in my Civic. Does anyone know how one can tell?
Old 16th November 2007, 13:43   #34 (permalink)
emmaloula's Avatar
Last night after the car had been standing for 8 hours, I got hot air after 4 minutes
emmaloula is offline   Reply With Quote
Old 2nd December 2007, 14:53   #35 (permalink)
Tyre Shredder
ritchie_perriam's Avatar
well i suppose its all to do with how your driving the car!
for some people who are taking it easy and keeping below a certain rpm it could take 10 mins or so,
but for others who are revving the nuts off the engine even when cold it will be warm in a min!
when driving my own cars it usually takes a while cos im not a fan of revving cold engines. but when in work vehicles (usually a diesel) (and i dont care about the health of the car) i just drive it basically on the limiter and its warm in 30 seconds.
i suppose it depends weather your willing to sacrifice a bit more engine wear for a bit of warm air!
but to be honest i just go and start the car a couple of minutes before i leave in the morning. and by the time i get out there its just started kicking out warm air. i know its not good for the environment but i leave for work at 6am, i just cant handle getting into a car that cold!
Old 4th December 2007, 08:17   #36 (permalink)
Defo a good 10mins or 4-5 miles in the morning, put that down to the engine i guess. Wor lasses fiesta zetec heats up in a nano-second
Carter es is offline   Reply With Quote
Old 4th December 2007, 08:41   #37 (permalink)
Exiled Englishman
bucketp's Avatar
2 degrees this morning 1.5 miles before I got warm air. 5 miles before I got hot air.
Old 4th December 2007, 08:44   #38 (permalink)
The worst part for me is that my commute is only 15 miles, so, 33% of that time the car is cold, mind you, my previous Focus TDCi wasn't much better.
Old 5th December 2007, 19:39   #39 (permalink)
HondaTiger's Avatar
Takes 5 mins to start warming up even when below 3deg. I have been driving for nearly 50 years and without doubt this is the best heating system I have had in a car, just put is on Auto and leave it. We have temp at 20 deg in winter and 19 deg in summer, works a treat.
HondaTiger is offline   Reply With Quote
Old 15th December 2007, 16:06   #40 (permalink)
Tyre Shredder
today it took 2.4 miles to start getting hot air and about 3 mins! and that was at 6Am! but that did include a bit of overtaking and hard driving! i always drive gently from cold except when im late for work!
Similar Threads for: How long does it take to get hot air?
Not long now longitude Buying, Dealers and Servicing 8 20th September 2007 15:21
How long to travel 1.7M? JoeyF Any non Civic chat here please! 6 27th August 2007 01:49
First long run in the car yesterday For Mash Get Smash General Discussion 5 21st August 2007 16:48
how long TFL Buying, Dealers and Servicing 1 21st June 2007 14:13
How Long To Tax A Car ? Pezza General Discussion 18 30th July 2006 23:49
