| This thread is about: Strange engine vibration, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hello. I have searched for this fault but did not find anything similar...so here goes. In the last couple of weeks i have noticed a ... | ||
Hello.
I have searched for this fault but did not find anything similar...so here goes. In the last couple of weeks i have noticed a strange vibration in the front side of the car, when the car is not moving and the engine is on....(while standing at the red light for example). It can be felt on the steering wheel, floor, handbrake, even the front seats. It is quite disturbing, and the dealer found nothing wrong with the car systems, so they said is is probably the poor quality of the fuel. Since then, i have tried many fuel types, but the vibration is the same...... Please, does any one know what this could be, and how to fix it?... Thanks... |
Comedian/Smart A*se
Hmmmm, most odd mine has clonk as you pull away (like something sliding in to place), but I only get a minor rev every so often when still, and definately nothing as noticable as yours sounds, my 3 series did though and it was rotted rubber engine mounts, but it shouldn't be the case on a newish civic.
Tom |
Comedian/Smart A*se
The octane difference should have solved knocking and pinking, but it's shouldn't have been massively noticable in the beginning. I'd try another dealer and see if they have any luck finding it??
Tom |
[quote=Unknownsoldier;116863]The octane difference should have solved knocking and pinking, but it's shouldn't have been massively noticable in the beginning. I'd try another dealer and see if they have any luck finding it??
Thanks, i will try another dealer...hope the have more luck.... Off topic: Is the auto-dimming rear-view mirror an optional part for the UK, or did you adapt it from somewhere else?.. |
#9 (permalink) | |
My car has had a loud humming noise joined accompanied with strong vibration that fades over maybe four seconds. This tends to happen when the car is standing still, or just as I've turned off the engine. I think it might the aircon switching off, as it only happens on really hot days when I've got the temp set to 18o? I've probably heard this four or five times - this is in the only post on here I've found that seems to describe this scenario.
#12 (permalink) | |
[quote=Johny B;116883]
| FN2 clutch vibration | MoOriginal | Type-R | 14 | Yesterday 16:53 |
| How Strange | Maldax | Any non Civic chat here please! | 1 | 30th October 2007 23:23 |
| Squeaks vibration noise from roof blind front | deeny | Bugs, faults and irritations | 3 | 11th September 2007 12:24 |
| Trim Strange marks. | Velocity | Bugs, faults and irritations | 4 | 16th February 2007 08:05 |
| Engine Vibration while idling. | JB75 | Bugs, faults and irritations | 13 | 10th October 2006 21:32 |
