| This thread is about: handbrake self release (inc recall letter), it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Originally Posted by Pottsy I agree. But now, when faced with news of a potential problem, they have a choice of: a) Deny everything and ... | ||
LinkBack (4) | Thread Tools | Display Modes |
#221 (permalink) | |
Oh do you mean like they have been doing until now, when we know for a fact that more than one or two people have contacted Honda telling them their car has rolled away. Sounds familiar to me , radios, fog lights, batteries, boot struts, shocks, paintwork You dont know everything Pottsy (although I do admit you know a lot I would place a huge bet on something quite bad happening for Honda to have had a wake up call on this one. Last edited by Topcat; 7th December 2007 at 22:13. |
#222 (permalink) |
I have just been reading through this old thread on handbrake problems, so many reports of poor handbrake and so many people saying YOU MUST press button when applying the brake
Handbrake Problem |
#223 (permalink) |
TC, those many people were, and still are correct. Ideally you should push the button in, pull the lever, release the button and pull the lever one more click (to ensure the ratchet has engaged properly). But that's a bit complicated for a letter aimed at the LCD, and the wear on the ratchet is probably not significant compared to getting the engagement wrong.
#226 (permalink) | |
Exactly - they were all doing it correctly, then some cars rolled away an Honda said "not our problem you didnt apply the handbrake correctly" !! My arguement from day one was that there were far too many incidents happening for Honda to ignore. Now they are addressing the problem they should also be looking to compensate all the people who have contacted Honda saying that there was a fault with their car causing damage. Chiswick told me that there was no problem with mine but I knew they were wrong and I was right. |
#229 (permalink) |
I was told, quite a while ago (on a slightly different subject) by someone who really should know. But then I haven't seen stripped mechanisms from 2 cars with my very own eyes, so it is second hand info.
#230 (permalink) |
just back on the issue of why Honda are using recorded delivery...
2 possible reasons spring to mind: 1) to cover their backsides, as suggested many times in here, or 2) to enable them to send out a second letter to all those owners who didn't receive the first one. 2 sides to every story |
#232 (permalink) | |
Knowing, as I now do this mechanism was a "tried and tested" one I feel Honda is less at fault, although obviously still responsible and accountable for it. However I doubt it will make anyone whose car has been damaged as a result of this fault feel any better. Thanks for the information Pottsy. |
#233 (permalink) | |
I, as I'm sure you are and you too Broders, am pleased they have identified a problem and are going to do something about it. And more importantly they have notified me of it. |
#234 (permalink) |
Honda aficionado
Thank you Pottsy, TT and all who have contributed to this thread. I feel it is perhaps now time to put a brake on it. Sorry....
No doubt a new thread linked to this will appear when Honda start the actual recall. It will be very interesting to see what Honda UK come up with and the advice/instruction with it. In the meantime I am having a little difficulty in remembering to apply the handbrake as per "the letter" - old habits die hard, but a second attempt fulfills the requirement. |
#235 (permalink) | |
(without re-opening the argument of if they applied the brake 'correctly' or not) But at least there shouldn't be any more of them now that Honda have sent the letter out |
#237 (permalink) |
Picked up my new CTR Thursday, asked the stealer a few questions about the faults on here including the handbrake. He said that Honda recommend that you do not press the handbrake button when applying the handbrake, So, a. they know about it and b.there is a fix, you just knacker up you rachet mechanism instead!!!
#239 (permalink) | |
short term fix is not to press the button long term fix - well we don't know quite what that is yet... |
