| This thread is about: handbrake self release (inc recall letter), it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hi my new civic rolled down the drive a month after I bought it. I have been told by the dealer that it is an ... | ||
LinkBack (4) | Thread Tools | Display Modes |
#681 (permalink) |
Hi my new civic rolled down the drive a month after I bought it. I have been told by the dealer that it is an 08 model (VIN confirms this)and is not part of the recall. Honda uk are not having anything to do with it and are happy that the handbrake is in good working order-checked at dealers- and that I didn't put it on enough. I am not happy |
#682 (permalink) | |
Newton Honda
Ok, my tuppence worth... When found after rolling away, was the handbrake still in the 'up' position or had it reset itself? |
#685 (permalink) | |
Who needs a 4x4??
From my dealership (not Newton Honda), I was told no loan car as only takes 30 mins, however they would not do the work on a Sat am, so I had to finish work early - I was not impressed |
#686 (permalink) | |
#687 (permalink) |
Newton Honda
As other posters have said, it depends on what is being done. some of the work only takes 30mins to an hour but, if a car is available (not booked out for weeks in advance) then one is available
#688 (permalink) | |
#689 (permalink) |
Honda aficionado
chrisv
It looks like you are in the same position as 'stayrich', both almost new 08 Civics, which Honda declare as being free of any handbrake defect. Stayrich succeeded in having his dealer pay for the repair as a gesture of goodwill for the reasons mentioned in his posting above. I think 'stayrich' has done exceptionally well as advice on how to operate the handbrake is contained in the driver manual. I can only suggest that you tackle the issue as 'stayrich' did and hope for the same result. I note that you live in Bolton and there is only one Honda dealer in that town, G*****s, the same dealership I use for service/repairs and have done for quite some time. I have always, hitherto, found them to be OK, so if it is the same dealership involved, I have an added interest in following your progress. Good luck! |
#690 (permalink) | |
Newton Honda
1) If the car rolls away and the handle is still in the active/up position, then it has been attributed to the brake not being applied hard enough, the discs cooling and shrinking and then the brakes losing grip, car rolling away scenario. As with any car, when you stop, apply the footbrake, then pull up the handbrake until it stops (without the use of the button of course). For added safety, use the old school method of also turning the wheel 'into' the hill and leaving the car in gear. 2) if the handbrake is in the off position then it was a) maybe not applied or b) the known 'issue' has occurred and the ratchet has slipped due to the handbrake not being applied correctly (by using the button) - Don't wait for a letter, call your dealership and give them the reg and chassis number, they will be able to tell you if the car requires the revised handbrake assembly. |
#691 (permalink) |
Honda aficionado
NH Dan,
Thank you. I think I am right in saying both 'chrisv' and 'stayrich' fall within category (1) of your post. The two separate issues you detail are well documented in this thread. As there is no apparent handbrake fault with 08 model Civics, any handbrake related problem therefore is down to the driver. That is why I think 'stayrich' did exceedingly well having the garage foot the bill, but good luck to the guy. Fantastic result. As a matter of interest I was under the impression the remodelled /replacement handbrake is designed to cater, safely, the button being depressed whilst it is applied. I cannot recall any forum member being told specifically, after having the handbrake replaced, that the handbrake should be applied without touching the button. Leaving the car in gear and wheels inclined etc still apply of course. If I am wrong perhaps some kind soul will enlighten me. |
#692 (permalink) |
My car has returned from the dealership this evening, with its replaced handbrake.
I did have a courtsey car (Jazz, boy do they drink petrol!!) but I had some other bits done under warranty so it had to be in all day. I asked about the door lock and was told after it had been looked at it that it has already been modified. But if I find I have a problem I will be talking to them again!! |
#693 (permalink) |
handbrake!!
Thank you everyone for their advice-hindsight is a great thing and now park my car very carefully!!
They have been helpful re repairs etc and courtesy car but then I went through my insurance -it is only since on discovery of a potential handbrake issue that I wish to pursue this further with them-I will keep you posted. Being in shock on the fateful day I cannot honestly say what the position of the handbrake was when I got back in the car. |
#694 (permalink) | |
Honda aficionado
The "letter" which I and many others received last November/December says, 'rest assured that we do appreciate that this is an inconvenience; so with longevity of your ownership of the vehicle in mind we will be improving the handbrake to reduce this inconvenience in the future' The letter equates "inconvenience" with 'pull the lever up fully without touching the release button. If these operating instructions are followed the handbrake's efficiency will be unaffected' That is my interpretation. If one has still to avoid pressing the release button in on applying the modified handbrake what is the point of the recall/modification? As Honda UK has not fulfilled it's promise to contact me to have the work done within their specified time limit I am minded to write them asking when I can look forward to the modified handbrake being fitted and once fitted, can one revert to the "usual" way of applying it - ie with release button depressed. |
#695 (permalink) |
Who needs a 4x4??
Please see attacked the VOSA recall note.
Recall Details for HONDA - Civic 3 & 5 door IMO It implies to me that the amended handbrake should be able to be appliesd either with button pressed or not. PS I have never pressed the button to apply the handbrake in this or any previous car. |
#696 (permalink) |
Honda aficionado
Thank you Alan. I am still minded to write to Honda UK as mentioned. I'll post their response, if I get one.....
Last edited by Doubtingthomas; 1st May 2008 at 09:17. Reason: additional sentence added. |
#697 (permalink) |
Hi Guys
Yes I do think we had a good result but our dealer has a good reputation for service. It all comes down to your negotiating skills and not just accepting what your told by the dealer. Here's the wording of the disclaimer we were asked to sign. 1. Press the foot brake firmly 2. While pressing the brake pedal, pull the handbrake lever up smartly to its fullest extent. 3. Do not press the release button while pulling the lever up. 4. If your vehicle is parked on a hill and facing uphill, select 1st gear and turn the steering wheel away from the curb. 5. If your vehicle is parked on a hill facing downhill, select reverse gear and turn the steering wheel towards the kerb. 6. Vehicles with an automatic transmission should always be left with the selector lever position in park P. 7. ALWAYS REFER TO THE SECTION IN YOUR MANUFACTURER HANDBOOK WITH REGARD TO YOUR SPECIFIC VEHICLE. Then there is the following statement: My Sales Executive has made me fully aware of my vehicles correct handbrake operation during the handover,or whilst on test drive. Signed .................................................. ....Our Customer Signed .................................................. ....Sales Executive Date............ I know this repeats alot of whats alreay in this thread but this is the exact wording of this particular dealers disclaimer. We refused to sign because as we are buying our car on HP our contract is with the finance company and not the dealer. My advice to anyone in a similar situation would be negotiate with your dealer before you go to your insurance company and find out where you stand legally before anything else because it makes the negotiation process with your dealer easier, and if you buying on finance talk to your finance company as legally they own the car. Information is power. |
#698 (permalink) |
Newton Honda
Having just sdiscussed this with one of my techs, the re-mod of the handbrake means that you should be able to apply the handbrake with or without the button being pressed, the ratchet system has been re-modelled to cater for this.
#700 (permalink) | |
Newton Honda
That must be something to do with the dealer by the way as Honda have not released instructions to have a disclaimer signed, you can tell that as it mentions keeping automatic cars in 'P' - the civic i-shift doesnt have a 'P' setting. |
