This thread is about: Replacing glove compartment (discolorment), it's in Buying, Dealers and Servicing at the Honda Civic forum Civinfo; Can it be done without making any scratches at all? My dealership has scratched my interior on previous encounters . It does not look to ...
Old 11th April 2008, 12:36   #1 (permalink)
Can it be done without making any scratches at all? My dealership has scratched my interior on previous encounters.
It does not look to difficult to replace, or is it?
Old 11th April 2008, 12:49   #2 (permalink)
Make your dealer agree with you on the condition of your dashboard before they start work.
Tell them based on their previous performances, you don't want anymore scratches. If they do scratch anything they will have to replace it.
Old 11th April 2008, 12:53   #3 (permalink)
The thing that can be scratched is erm yes the entire front...I think I'll faint if they need to replace that. I hate to sound a bore about small scratches but I hate them... Good idea though!
Old 11th April 2008, 12:54   #4 (permalink)
Originally Posted by Jeroen1000 View Post
The thing that can be scrached is erm yes the entire front...I think I'll faint if they need to replace that. I hate to sound a bore about small sratches but I hate them... Good idea though!
Just remember it's your property and they shouldn't damage it.
Old 11th April 2008, 13:00   #5 (permalink)
Greedy's Avatar
Glove box is easy to replace. 2 bolts at the bottom then un-latch and twist it as it comes out (from memory) so they should not have any difficulty. It is made easy to take out as Honda use this as the access panel for a whole host of things.
Any sensible joe would tape around the edge of the openign first to eb safe but apart from that no excuse for any damage what so ever.
Old 11th April 2008, 13:53   #6 (permalink)
Indeed when you pull it out, there is a chance you rub it against the inner side (by that I mean away from the door) of the interior. I believe the side that is closest by the door is the compartment itself. It looks easy enough and I've found no other pitfalls.
I feel like doing it myself. It will take three times as long but I am frantically careful . It's funny many of us here fear the dealers' craftmanship. Mine are always so busy it has certainly affected quality.
Old 11th April 2008, 17:39   #7 (permalink)
Type R Brigade Member
NEEMSTAR's Avatar
but I hate them
scratches or your dealer?
NEEMSTAR is online now   Reply With Quote
Old 11th April 2008, 21:06   #8 (permalink)
Jack The Lad.'s Avatar
It's the handbrake fix that is a worry to me.
All that centre section coming off and thrown somewhere in the car, or the workshop floor.
Bet they use a 5lb club hammer, to remove those round plastic plugs, which hold it all in place, due to the time Honda will give them to fix each car.
I can remember when the dealership had to remove the whole dashboard from my Volvo,--- what a mess up that was.
Old 15th April 2008, 07:40   #9 (permalink)
ahar's Avatar
Had my glovebox replaced after thick thieves broke in and thought that it was locked so tried to break into it (why they didn'tuse the handle to open it I don't know). The dealer (crown honda in Bushey) did a good job and replaced it without scratches
ahar is offline   Reply With Quote
Old 15th April 2008, 07:44   #10 (permalink)
It's my fault!
Hence the expression, 'as thick as thieves!'
Old 15th April 2008, 07:48   #11 (permalink)
Oh no... Just tell them to keep away from it. If you always park in gear, the chances are minimum that the car goes off alone. But if you must replace it you can do as many people advise here: show them the condition the car is in and do not accept damage done.
When do you suppose they'll fix it? Maybe you should post the outcome
Had my glovebox replaced after thick thieves broke in The dealer (crown honda in Bushey) did a good job and replaced it without scratches
I just got a call it's in. I'm going to tape it off myself and clearly indicate they must be careful whilst pointing out my car is free of sratches except those already there when I picked the car up... (some scuffs in the boot). Mindless criminals. I hope that was all they damaged!
Similar Threads for: Replacing glove compartment (discolorment)
Squeaks Glove Box Rattle mikeydoo Bugs, faults and irritations 6 14th July 2008 18:22
No light in glovebox compartment? Wouter Hybrid 9 12th October 2007 16:45
How Much is the Boot Compartment Lid?? DanKo General commercial posts 2 13th January 2007 18:06
Little compartment under Head unit ? daiashthomas Cleaning 1 15th October 2006 19:06
Cool glove box Bigian General Discussion 22 10th August 2006 08:53
