This thread is about: Partnumber/Price of shelf infront of radio display, it's in Buying, Dealers and Servicing at the Honda Civic forum Civinfo; Hi all, I am looking for a price/part number of the civic shelf as in my attached picture......
Old 15th May 2008, 23:25   #1 (permalink)
The Talented Mr. Robbieee
Robbieee's Avatar
Hi all,
Old 16th May 2008, 08:37   #2 (permalink)
manda0402's Avatar
That looks like a RHD without sat nav so it will be 77270-SMG-E02ZA for aftersales.
manda0402 is offline   Reply With Quote
Old 16th May 2008, 15:47   #3 (permalink)
Commercial user
Gordons Honda's Avatar
Price is 13.35 inc VAT.
Gordons Honda is offline   Reply With Quote
Old 18th May 2008, 09:29   #4 (permalink)
Robbieee's Avatar
Thanks guys!
Old 19th May 2008, 20:57   #5 (permalink)
Good Luck if your thinking of fittin it yourself they are an absolute T@*T!!
Hondapants is offline   Reply With Quote
Old 19th May 2008, 21:00   #6 (permalink)
Robbieee's Avatar
I take things apart everyday. I toy with them. Bring it on. hehe!
Old 19th May 2008, 21:05   #7 (permalink)
I have the pleasure of working with these things every day!! guaranteed to "damage" radio display/sat nav!!
Old 19th May 2008, 21:08   #8 (permalink)
Robbieee's Avatar
Bugger!!!
The problem as you can see in the picture, the previous owner has drilled through it to put the plug and play on it. I dont want the glorified FM transmitter. Need a think. Brain hurts!
Old 19th May 2008, 22:07   #9 (permalink)
To remove: Lift the front up first. Use a long screwdriver for the back clips ( near radio display)
Old 19th May 2008, 22:59   #10 (permalink)
Robbieee's Avatar
Cool thats for that matey.
Old 29th June 2008, 21:55   #11 (permalink)
Robbieee's Avatar
I removed the parcel shelf. Didnt scratch anything. Pretty easy to come off actually- was surprised! lol
Old 27th November 2008, 12:54   #12 (permalink)
lark's Avatar
Only 13.35??
so how much it the display for the civic without radio? And for Navigation version?
Thanks!
lark is offline   Reply With Quote
Old 27th November 2008, 15:18   #13 (permalink)
if you are replacing it with a new one, VERY esay to remove without doing any damage to anything else, and save your radio from getting spoilt
The key is there is an inch gap under that part before you hit the underlying structure.
Solution, use an awl, bradle or something similar to make some small holes in it around its periphery. I used a cone shaped hole cutter for making holes in radio controlled model car bodies.
Then, use a pick, or a piece of wire with a bent bit at the end to hook into the holes and pull the piece, bit by bit using each hole in turn around the circumference until its out.
Like I said, you sacrifice £14, but leave everything else totally untouched
spacecadet is offline   Reply With Quote
Old 27th November 2008, 16:41   #14 (permalink)
Robbieee's Avatar
Just use a flat blade screw driver to ease it out. easy peasy.
Old 29th November 2008, 02:51   #15 (permalink)
lark's Avatar
Originally Posted by lark View Post
Only 13.35??
Thanks!
nobody knows?
Old 29th November 2008, 11:13   #16 (permalink)
nobody knows?
Try one of the dealers sections.
Old 29th November 2008, 16:25   #17 (permalink)
lark's Avatar
I tought I was in the right section (buying, dealers and servicing)
Old 29th November 2008, 16:26   #18 (permalink)
Try one of the dealers in here.
Commercial - Civinfo
Old 29th November 2008, 17:06   #19 (permalink)
lark's Avatar
Thanks Dimplyred!
Old 29th November 2008, 17:09   #20 (permalink)
Try Gordons Honda, and include a link to this thread.
Similar Threads for: Partnumber/Price of shelf infront of radio display
Head Unit non OEM radio and display TechnoTools Ipods, MP3 Players and ICE 6 15th November 2007 03:00
Radio/CD display Lozza General Discussion 0 25th March 2007 20:26
Rear Parcel Shelf Price?? DanKo General commercial posts 9 15th March 2007 21:37
Technical Air Condition display not working without OEM radio MikaK Ipods, MP3 Players and ICE 0 4th December 2006 20:51
Technical Radio display with i-pilot fullthrottle Ipods, MP3 Players and ICE 1 3rd November 2006 21:50
