This thread is about: Do I have to get the Dealer to change pads?, it's in Buying, Dealers and Servicing at the Honda Civic forum Civinfo; If I get these changed by a non Honda Garage does it afffect my warranty? Thanks...
Old 12th July 2007, 08:17   #1 (permalink)
Gadgeteer
sonicsteve's Avatar
sonicsteve is offline   Reply With Quote
Old 12th July 2007, 08:29   #2 (permalink)
AubreyS's Avatar
I would almost definately say no to that. I guess the best way to find out for sure is to call your local dealer and ask them. I'm sure that someone will come up with the correct answer.
Old 12th July 2007, 08:31   #3 (permalink)
Topcat's Avatar
I think the answer may be yes - when I had my Focus I was told by Ford that any work done to my car should be done by a Ford dealer otherwise it could affect my warranty.
Unless of course this was their way of ensuring I went to them
Old 12th July 2007, 09:58   #4 (permalink)
chriswarwick's Avatar
Remember though a Ford '3 year warranty' is'nt the same as a Honda '3 year warranty'. The crucial difference is that a Honda has a 3 year maufacturors warranty whereas a Ford has a 1 year manufacturor's warranty and a 2 year dealer warranty - at least thats the way it used to be.
chriswarwick is offline   Reply With Quote
Old 12th July 2007, 10:09   #5 (permalink)
RELOADING FOR ELK
It will not affect warranty as there was a change in the law covering these sorta things . They cannot do this any more.
Old 12th July 2007, 10:11   #6 (permalink)
Gadgeteer
sonicsteve's Avatar
It is ok I found it in the service book. As long as you use parts that are as good as Honda genuine parts and the work is carried out by a competent technician the warranty remains intact.
Old 12th July 2007, 10:29   #7 (permalink)
Brake Pads
I agree with Sonic steve you can have the work done at a non franchise garage provided you use genuine Honda parts.
KEN BYE is offline   Reply With Quote
Old 12th July 2007, 11:31   #8 (permalink)
tomcat's Avatar
I'm not sure on legal side of things, but I bet if there is a fault with the braking system, they could try and use it as a way of not paying out under warranty, especially if you are using aftermarket pads.
However, I was quoted something around £120 - £150 to replace the pads on my Accord by the dealer. My dad is a mechanic, and picked up some aftermarket pads for £12, so was a nice cheap job. They have been on for about 25000 miles now with no problems.
tomcat is offline   Reply With Quote
Old 12th July 2007, 11:38   #9 (permalink)
It's my fault!
The law states that:
"as long as genuine parts are used and fitted by a qualified technician, the the manufacturers warranty has to remain intact"
ie. Get to your nearest Independent Garage and save yourself a shed load!!
Old 13th July 2007, 16:26   #10 (permalink)
Nice's Avatar
Exactly who decides whether a technician is " Qualified".
Rumours are that this may be clarified in law sooner rather than later.
Nice is offline   Reply With Quote
Old 13th July 2007, 18:02   #11 (permalink)
It's my fault!
What?
If youre not sure go to a dealer or ask at the independent garage. If they cant show you, walk away.
Old 13th July 2007, 19:28   #12 (permalink)
Greedy's Avatar
Very difficult for them to prove as Pads are considered wear & tear parts, same as tyres and thus have certain exclusions from the warranty.
The only problem comes if they are incorrectly fitted by your 'expert' and damage other parts of your car. I can't remember the design of the caliper. If it's like the old Civic where you have to undo the bolt of the floating fist and swing it up then you will need torque settings etc. If it's a removable pin then can't see how anyone marginally competent could mess it up.
Old 13th July 2007, 20:57   #13 (permalink)
well if you have taken your car into a franchised honda dealer then all the technicians will have been licensed by honda themselves,they have to attend the honda institute every 2/3 yrs & passed a stringent practical/written assesment .Honda catorgerize the skill level of there technicians at 3 different levels ,maintenance,diagnostic,master. incidently there are only approx 15-25 honda master technicians in the uk at the moment across the honda family of cars,motorcycle,garden,watercraft products.
The majority of mainstream car manufactures in the uk have also signed up to the ATA accredited technician scheme which is very similar to the honda way of licenced technicians where practical & written examinations are carried out and have to be retaken every five years to keep your licence current.this voluntary scheme was brought in by the industry themselves before the government forces legislation on the motor industry.http://www.automotivetechnician.org.uk
hondatech is offline   Reply With Quote
Old 13th July 2007, 21:05   #14 (permalink)
deeny's Avatar
servicing if done by a garage of your choice for the warranty to continue they must be vat registered and use genuine honda parts. With regards to the pads if you use genuine parts and do it yourself, how will honda know?its such an easy job i wouldnt pay a dealer to do it i would change them myself
deeny is offline   Reply With Quote
Old 16th July 2007, 07:52   #15 (permalink)
Nice's Avatar
Sorry....I didn't make my earlier post very clear.
I work within a Honda dealership and know about the training/licensing that Honda UK implement and how tough it can be.
What I was trying to get over is that this "Licensing" may well become a legal part of a motor mechanics training. I believe Honda UK think this and are therefore well ahead of the game.
Similar Threads for: Do I have to get the Dealer to change pads?
Oil Dealer wrote to us suggesting an oil change at 6 months old JohnH Engines and Transmission 10 29th September 2007 17:52
front and rear brake pads? valmiki Holdcroft Honda 13 10th September 2007 15:56
front pads lazzy git Holdcroft Honda 2 7th August 2007 22:21
Front Discs and Pads and drivers side fog lamp for 2.2 EX sonicsteve Holdcroft Honda 1 10th July 2007 09:57
Brakes New Disc's, pads and calipers B01JAMES Wheels, Tyres, Suspension and Brakes 3 18th June 2007 19:58
