Go Back   Civinfo > All Civics > Buying, Dealers and Servicing
Old 17th October 2012, 20:31   #1 (permalink)
Car: 2006 Honda civic 2.2 ictdi
Thanks given: 2
Will this a/c pump fit my Civic?
i have a Honda civic 2006 MK7 model 2.2 diesel i-ctdi and the air con pump is not working.
I found a used one from a petrol 1.8 same model and age as mine.
Will the air con pump of a petrol civic fit the diesel model? Are there any differences?
Thanks in advance for the help.
jdiasgs is offline   Reply With Quote
Old 22nd October 2012, 09:54   #2 (permalink)
Most Active Australian
Grayfox's Avatar
Car: 2010 Black Civic Si FK2
Thanks given: 67
Eco display Eco display
Where do you live?
Your flag says australia but i know for a fact australia never got the FK3/FN3 models.
We only had 2 choices.
1.8L 5 door(australian Si)
2.0L 3 door(australian type R)
And that aside, i doubt it but i'm not 100% sure.
I assuming no because not the same engine which means drive belt will be different size and in a different location to the 1.8.
Grayfox is online now   Reply With Quote
Old 22nd October 2012, 10:33   #3 (permalink)
CiViC_dIeSeL's Avatar
Car: 2008 2,2 i-CTDi 5D
Thanks given: 24
Originally Posted by jdiasgs View Post
Are you sure that it is just not the "famous" A/C relay that is broken?
CiViC_dIeSeL is offline   Reply With Quote
Thanks to CiViC_dIeSeL from:
Old 23rd October 2012, 12:03   #4 (permalink)
Thanks given: 2
sorry i am located in UK.
@ CiViC_dIeSeL: DO you mean the relay in the fuse box?
Old 24th October 2012, 13:50   #5 (permalink)
abs-civic's Avatar
Car: 2006 2.2 EX, NHB
Thanks given: 80
Yep there is a relay in the fuse box under bonnet you should check first. I believe it's called OMRON which is the updated one or the old one was called Mitsuba.
abs-civic is online now   Reply With Quote
Old 24th October 2012, 13:52   #6 (permalink)
abs-civic's Avatar
Thanks given: 80
Also I don't think the petrol version is compatible, as I changed mine 3 months ago and asked various sellers the same question to which the answer was no.
Similar Threads for: Will this a/c pump fit my Civic?
Civic Type R FN2 Fuel Filter / Pump Replacement stiggy How To 32 9th May 2013 17:41
Questions Will this a/c pump fit my Civic? Sw1pe Buying, Dealers and Servicing 5 29th May 2012 14:32
Civic Washer bottle & Pump Laney Items for sale 2 6th December 2011 08:49
Honda Civic Tyre Pump Inflater For Sale MarcoHojeer Items for sale 3 10th November 2010 00:22
servo,vac pump and abs pump s29uny Classifieds archive 0 7th March 2009 18:58
