This thread is about: difference ?, it's in Styling at the Honda Civic forum Civinfo; Does anybody know if there's actually a difference between the type r and the type S front and rear-spoilers / sideskirts / arches? Thanks...
Old 30th January 2008, 09:12   #1 (permalink)
difference ?
project_x is offline   Reply With Quote
Old 30th January 2008, 09:28   #2 (permalink)
pjr
Type S(cotland)
pjr's Avatar
I believe the shape of the skirts & arches are identical in shape - just the R has them colour coded as standard.
Old 4th February 2008, 08:23   #3 (permalink)
It's my fault!
Youre quite correct.
Identical minus a coat of paint
Old 12th February 2008, 09:05   #4 (permalink)
very sure? Holdcroft told me they flared out more than the type-r ones..
Old 12th February 2008, 09:33   #5 (permalink)
It's my fault!
This is not so.
They are identical
Perhaps Holdcroft were confused by your question.
Old 12th February 2008, 09:46   #6 (permalink)
pjr
Type S(cotland)
pjr's Avatar
Wouldn't make sense for Honda to make two different sets of skirts for the R & S.
Here is a picture of my Type S.
And a Type R from a similar angle (borrowed from the white wheels thread.)
Haven't measured the skirts on both, but they look the same to me.
Old 12th February 2008, 09:51   #7 (permalink)
the fancy front and rear splitters from the R fit straight onto the S too, so I'd put money on the standard kit being identical
Old 12th February 2008, 21:36   #8 (permalink)
While we are on it, does this mean that the front and rear spoiler/skirt will fit on a normal 5 door civic? And They use the same wheelarches?
So in the end, the only thing that is not possible to put right on without modification are the sideskirts?
Ronny is offline   Reply With Quote
Old 12th February 2008, 21:57   #9 (permalink)
pjr
Type S(cotland)
pjr's Avatar
No sorry, not without a lot of work. The arches on the Type S/R are different as well. The rear wheel arches are also wider than those on the 5 door.
The joins are as highlighted in green on the photo below - the joins are after the bottom edges of the wheelarch have started to flare out again for the side skirts and front/rear skirts.
It can be done, but isn't a simple remove & replace.
Old 12th February 2008, 22:17   #10 (permalink)
It's my fault!
The R and S have identical body skirts, the 5 door is different.
Honest!!!
Old 12th February 2008, 22:19   #11 (permalink)
So without getting confused to much here
What part of the type-r spoiler/skirts fits on the civic 5 door? If any at all....
Old 12th February 2008, 22:59   #12 (permalink)
pjr
Type S(cotland)
pjr's Avatar
Ronny,
Technically they do fit, but with quite a bit of work/alteration, particularly for the rear wheel arches. The exhaust placement/shape on the Type R/S is also different from the 5 door.
This thread might help
The Danish Civic Project :)
or this one
The Greek 5door look type r
They are both long threads, but cover some of the issues in trying to fit the Type R/S bodykit to a 5 door.
Happy reading
Old 12th February 2008, 23:02   #13 (permalink)
Old 12th February 2008, 23:20   #14 (permalink)
u05rdh is offline   Reply With Quote
Old 13th February 2008, 01:54   #15 (permalink)
Vet_2010's Avatar
So would fitting the image pack to a 5 door and colour coding not make it the same as the Type-R body kit? Or at least look pretty close?
Old 13th February 2008, 09:04   #16 (permalink)
It's my fault!
No It would not look the same
Old 13th February 2008, 09:49   #17 (permalink)
Vet_2010's Avatar
Just found these in the gallery,
I think I actually prefer the front on the 5 door, although I prefer the flared sides on the Type-S
Old 13th February 2008, 09:56   #18 (permalink)
RELOADING FOR ELK
the blue looks great all colour coded
Old 13th February 2008, 19:46   #19 (permalink)
Vivid Blue Rocks!!!
Foggy69's Avatar
I think the picture of Hondaatje's VB 5 door proves that fitting the image pack on colour coded trim does look the dogs dangle bits
The Type S looks pretty nice as well
Similar Threads for: difference ?
Model year Civic 07 / 08 Difference If Any ?? jaysen Buying, Dealers and Servicing 9 5th December 2007 00:59
Fuel Diesel Difference DerekR Engines and Transmission 4 2nd August 2007 18:23
What a difference a week makes! Maxbert General Discussion 21 18th April 2007 16:00
Dealers What a difference a dealership makes !! Topcat Buying, Dealers and Servicing 15 16th December 2006 18:38
Difference between 2.2EX & 2.2EX SR ? Moley RUFC General Discussion 6 4th September 2006 09:08
