This thread is about: Silicon Blade woes, it's in Cleaning at the Honda Civic forum Civinfo; Despite, on another thread saying all was well with my AutoGlym hydra blade. I managed to make two long scratches on my car at the ...
Old 4th February 2008, 16:22   #1 (permalink)
DeanFYoung's Avatar
Silicon Blade woes
I managed to make two long scratches on my car at the weekend when using it, just above the fuel filler cap.
Suffice to say I am annoyed, but they dont look too deep, and should polish out OK (no time to do it yesterday unfortunately)
A warning to all - be very careful with these things!!!
Old 4th February 2008, 19:38   #2 (permalink)
PJS
Careful? Feck them in the bin pronto to save grief in the first place!
Buy a couple of decent microfibre towels (good heavyweight ones) and you'll never look at a blade ever again.
Old 4th February 2008, 19:49   #3 (permalink)
I've stopped using one for this very reason.
My scratch did polish out, but the blade IS in the bin now.
Old 4th February 2008, 19:52   #4 (permalink)
It's my fault!
Good advice
Old 4th February 2008, 21:40   #5 (permalink)
ADE Type S's Avatar
Couldnt of put it better my self!
Ive been using the PoorBoys World Waffle Weave drying towel and the only thing i can say about it is AWESOME!!!!!
ADE Type S is offline   Reply With Quote
Old 4th February 2008, 21:49   #6 (permalink)
DeanFYoung's Avatar
"PoorBoys World Waffle Weave drying towel" - sounds like quite a towel...
I will venture to my nearest Halfords this week and see what I can find...maybe I'll give my blade to my brother!!
Old 4th February 2008, 22:43   #7 (permalink)
gray52's Avatar
you must have had dirt on the car or the blade???
if you get the same on a microfibre cloth it will do the same. i used a shammie but spent ages running it all over the car, which is not good and you will get swirls. i spent alot of time at the weekend cleaning, polishing and waxing. im now using the applicator foam pads and they are brilliant!! half the time and half the product being applied. these do not leave any swirls either.
a good swirl or scratch test is to get an old rw dvd which has failed, and run whatever you are going to use on your car first, you will then see or not see scratches appear on the disk. if what ever your using scratches the disk it will scratch your car, simple.
Old 4th February 2008, 22:57   #8 (permalink)
R GT's Avatar
Meguirs do a waffle towel that halfords sell it is £11 pounds but worth every penny happy drying. ps it works best after it has been saturated so go easy on the wiping and go over areas several times you will not be disapointed.
R GT is offline   Reply With Quote
Old 5th February 2008, 08:08   #9 (permalink)
It's my fault!
Its called a:
Meguires 'Water Magnet'
Old 5th February 2008, 09:31   #10 (permalink)
DeanFYoung's Avatar
Its called a:
Cheers - I'll look out for that one as well.
Reckon I didn't rinse the car thorougly enough, as I definitely rinsed the blade, and I'd done most of the car before getting the scratch.
Old 5th February 2008, 13:10   #11 (permalink)
spile's Avatar
Sorry but if you have grit on the car that it makes no difference WHAT you dry the car with. I find the water magnet one of the worst things I've ever bought for the car. It certainly isn't any good at removing excess water when compared with the Autoglym blade.
spile is offline   Reply With Quote
Old 5th February 2008, 14:16   #12 (permalink)
Koen's Avatar
Originally Posted by spile View Post
Sorry but if you have grit on the car that it makes no difference WHAT you dry the car with. ...
I don't agree completely. When you use a blade, you have to apply some pressure. Moreover, the pressure is applied to a very narrow surface. That means that any grit or whatever gets a firm push into the paint/finish.
When I dry my car, I kinda drag a shammy over the surface, giving hardly any pressure at all. I'm sure that makes a difference.
K.
Old 5th February 2008, 19:03   #13 (permalink)
PJS
You bastid!
What's your brother done on you then, to foist this upon him?
You'll not get anything decent out of Halfords, least of all the Meg's towel - it works for a while, then most have found it stops working as well as it first did, so resort to chucking more money at what they should've done first time round.
I have an absolute stonker of a towel, but it's not one anyone has heard of or come across yet, and at the price, they might just have a coronary - but by Christ is it superb!
I may do something with it soon - so keep your eyes peeled, as they say.
Should also point out, pat drying is the best method for minimising swirls or scratches, but I don't go for the QD to 'help' drying malarky either.
Some swear blind it works - to each their own, is what I say.
Old 7th February 2008, 12:16   #14 (permalink)
spile's Avatar
[quote][/When you use a blade, you have to apply some pressure. Moreover, the pressure is applied to a very narrow surface. That means that any grit or whatever gets a firm push into the paint/finish.
QUOTE]
This effect is more noticable with a cloth where the main direction of force is down whereas the main direction of force with a blade is to the side.
Of course YMMV as this all depends on HOW you use the thing.
Old 7th February 2008, 14:46   #15 (permalink)
I also scratched my car with this blade.
I burned it...
Old 7th February 2008, 15:05   #16 (permalink)
Ramsay's Avatar
I don't like the Autoglym blade either and now only use it on the windows.
Koen also mentioned dragging a open chamoix leather to remove the excess water - this is precisely how my car cleaning Armah in Hong Kong used to do it - all for £1:00 a month. Do it myself now though.
Ramsay is offline   Reply With Quote
Old 7th February 2008, 15:17   #17 (permalink)
My car is one year next week, and I'm already more relaxed about cleaning regimes and water spots...
Similar Threads for: Silicon Blade woes
18" Blade Alloys Trekker308 Holdcroft Honda 7 4th March 2008 16:23
Oh b*gger! Car cleaning woes... uncler Cleaning 28 28th January 2008 13:59
My install H+K Installation woes cjthompson321 Ipods, MP3 Players and ICE 9 29th November 2007 12:36
Alloys Choice Blade lookalikes Foggy69 Wheels, Tyres, Suspension and Brakes 5 19th September 2007 11:00
Type S on 18" Blade Alloys Biker1 General commercial posts 3 17th May 2007 17:20
