| This thread is about: Poorboys wheel sealant experiment, it's in Cleaning at the Honda Civic forum Civinfo; Hello all, 2 weeks ago I washed the war and applied poorboys wheel sealant to 2 wheels only. I been driving around as normal and ... | ||
Hello all,
2 weeks ago I washed the war and applied poorboys wheel sealant to 2 wheels only. I been driving around as normal and today I concluded my experiment by having a visual inspection of the amount of dirt/brake dust the wheels with and without poorboys has, and how easy the wheels are to clean. In the words of the fast show's Professor Denzil Dextor.."the results were disappointing". Putting on Poorboys did not reduce the amount of brakedust/dirt that sticks to the wheel and the amount of cleaning effort was the same. Does this tie in with anyone else's experiments? |
Diesel of course
You need 2 or 3 coats.
HOWEVER: You must not think that it will cut down on brake dust. It wont! It will make the wheels easier to clean. Thats all. Its a sealer for protection NOT a repellant |
Why Do I bother?
I think that when people come to changing their pads they should opt for the EBC GreenStuff pads, they cut down on the break dust and i've found previously that they lasted longer than the standard pads from BMW on my previous car.
But agree with Robbo that you do need a couple of coats and then you'll see a difference with regards to the cleaning time |
I have recently started using poorboys and have found it to be an improvement over what I used to use (Mer).
As stated earlier you need a few coats of the poorboys and still need to regularly clean the wheels. I have not needed to resort to acidic wheel cleaners since using poorboys. |
Righty ho, my next experiment will be 1 front wheel with 3 coats of Poorboys and 1 front wheel with 1 coat of gloss guard. A friend of mine has nismo chrome wheels and swears by gloss guard.
Thanks for your comments! |
I had to give the Poorboys back to the person I borrowed it off, so I tried 2 layers of Chemical Guys wheel guard and 2 weeks of general car driving.
I can report that it did slightly reduce the amount of brake dust on the wheel (it wasn't as dirty) and it was definately easier to wash off. Just a case of wiping it with a damp cloth rather than having to do any scrubbing type motion. So, if you want to save yourself a bit of time cleaning the wheels, spend 20 minutes waxing them. Erm. |
#11 (permalink) | |
#12 (permalink) |
i have been useing the poorboys gear since i picked up my civic and i must have applied around 5 coats of the wheel sealent to my storms since day 1 and now i can get 70% of the dirt/dust off with hose and 95% with the karcher and just a quick swipe with a sponge and they sparkle, never used a wheel cleaner on them, andd the water beads away nicely!
I never waste money on these special wheel products, I've been using AutoGlym car wax on the alloys too. Just wax the alloys while waxing the car! It adds a protective coat of silicon and the wheels always look as new. I have done this for years, and owned my previous car for 10 years and the alloys still looked like new!
I have waxed my alloys on my CTR a couple of times now in 6 months, and the dirt just washes off without any hassle! |
#15 (permalink) |
Pit marks? Do you mean tar on the alloys? If so you can buy some tar removal products. Or you can keep rubbing on the wax until it disappears, as it has a mild T-Cut effect.
#16 (permalink) |
Pit marks are corrosion caused by brake dust eating into the alloy, unless as above, the marks are proud of the surface rather than indentations - in which case a clay bar or tar remover is required.
#17 (permalink) |
OK thanks. Well I have always added a coat of wax to my alloys for all my cars for years, and have never had this problem. I do know what you mean, the paint starts to go matt and then flakes off. Try waxing the wheels!
| Poorboys World Products. | ADE Type S | Cleaning | 10 | 12th August 2008 09:02 |
| Applying a sealant | Speedy471 | Cleaning | 12 | 9th March 2008 02:10 |
| Spare Best Tyre Sealant? | defrece | Wheels, Tyres, Suspension and Brakes | 9 | 4th February 2008 01:01 |
| Wax/Sealant/Stuff for lighter colours? | Skippy | Cleaning | 15 | 19th May 2007 21:33 |
| AC/Heater Climate Control experiment | Pottsy | Bugs, faults and irritations | 32 | 28th March 2007 04:46 |
