| This thread is about: Swirls, swirls and more swirls!, it's in Cleaning at the Honda Civic forum Civinfo; Originally Posted by Topcat If you put a machine to the paintwork an it is already too thin surely you will be losing vital microns. ... | ||
#21 (permalink) | |
Working on the basis of equal thirds (primer, basecoat, clearcoat) then you have approx. 35-40 µm to play with. Using a machine polisher and something like Menzerna Final Finish or even Intensive Polish, would probably only result in 1-3 µm removed. Obviously the deeper the marks, if not fingernail-catching, will require more removed. Ultimately a good cleaning regime should mean not having to polish more than 2-3 times a year at most. Something some people might consider doing, is get the car prep'd by a pro to a mirror finish, and then have the paint clearcoated with once of the new tougher clears like those on the German marques. Will cost quite a bit more than say Supaguarding it, but then it will be a thicker topcoat to work with, along with having greater resilience to scratching. That's what I'm thinking of with the Accord - as it really does need so much work done to it. So, if I do, and I may even change the colour, it WILL be having one of those types of clear put on it. Given the Civic's is softer again - if I was getting one new or used, I'd definitely budget for this sort of work to be done, even though correcting the defects is fairly straight forward. Rather than £800+ on new wheels, etc, get the paint sorted as it'll give the car a higher residual when you sell it, than a set of bigger alloys will. From there, your car care regime will be quite a bit easier. |
#22 (permalink) | |
Exactly MOST factory paints but many of us know the Civic's paint just isnt like that - and I know for a fact from my paint report that that the layers are definately not of equal amounts, the clearcoat being very thin in many places. My local dealership were reluctant to put a machine to mine because of this so I suggest that unless anyone knows for sure what their paint measures they think twice about sanding valuable paint off. |
#23 (permalink) | |
#24 (permalink) | |
70-80 µm is essentially single stage paint thickness, and if you ever measured any areas with that amount, you'd steer well clear of them with any machine. I hope you're instrumental in effecting a change by Honda, although I doubt it. What I would do, is seriously get every member here with a new shape Civic, to have their paint measured - doesn't need to be each layer, as polishing is only ever about the clearcoat, and see what the results are like. If there's a trend, then you can present the info to Honda directly, and BBC's Watchdog, although it's not the same since Annie left. That and Trading Standards, as well as RAC, and Top Gear. Bear in mind, anyone getting a pro detailer to measure their paint for them, should have a full report done - there'll be over 250 points measured, and mapped out as to where each high and low point is on the car. It'll cost £30 probably, and if you need my assistance to help orchestrate it, let me know, and I'll see what I can do. The only way you'll make this work and happen for you, is to act as one voice rather than one or two here and there. |
#25 (permalink) | |
I think I'd rather use the touch-up pen when I have time but the wax chipstick seems to be a good quick fix. |
#26 (permalink) | |
I have eyed up a few civics in car parks and you can almost age the NHB cars by the visibility of the swirls. Its a bit like the rings in a tree! |
#27 (permalink) | |
#28 (permalink) |
Interesting to see this CTR, and another member's CTS are measuring >110µm
Auto Finesse VS New Civic Type R - Detailing World |
#29 (permalink) | |
The car looks absolutely superb now, despite having to drive it home in the torrential rain yesterday |
#30 (permalink) | |
Type R Brigade Member
looks great btw |
#31 (permalink) |
I had a few light scratches around the drivers door where someone obviously had the keys in their hand when they opened the door and was a bit careless
A friend of mine recommended Autoglym super resin, which you can get from Halfords. There's a knack of applying it, basically its small particles which get smaller as you rub and these fill in the scratches and swirls (in much the same way as supaguard). So, to put it on, you need a lot of pressure at first to get the particles quite small and then once its kind of dried off use light pressure. After this, use some wax to finally seal it. It took me a while, but when I finished you can't see the scratches anymore. I was a bit skeptical at first but it did work. For the sake of a couple of quid from Halfords and some elbow grease its worth a go. |
#32 (permalink) | |
Well, let's just say that you wouldn't be too far out at around the mid four hundred mark! Cost really does dependant on the condition of your vehicle though. As you can see from the pics, mine was in a pretty bad way so needed quite a few man hours! |
