This thread is about: Collinite - before and after, it's in Cleaning at the Honda Civic forum Civinfo; Now that is a good shine....
Old 8th June 2008, 19:33   #41 (permalink)
Old 8th June 2008, 19:38   #42 (permalink)
RELOADING FOR ELK
The Dyson is the Daddy but cost the same as my first house.
Old 8th June 2008, 20:07   #43 (permalink)
It's my fault!
Not bad IH...Good this Collinite isnt it?
BTW. If you use a trigger spray bottle with water in, you can 'set' the previous coat and not have to wait an hour before applying the next...
Apologies if you do this already
Old 8th June 2008, 20:28   #44 (permalink)
DB SGT08's Avatar
robbo51 - presumably you leather off the spray?
Serious shine IH.
Is it a case of wash & dry, then apply the collinite or is there a stage in between such as apply Autoglym SRP/meguiars etc
New to this serious valeting!
DB SGT08 is offline   Reply With Quote
Old 8th June 2008, 20:33   #45 (permalink)
It's my fault!
No..I never use a leather...
Microfibre towel.
Old 8th June 2008, 20:48   #46 (permalink)
Esox Lucius Rules!!!!!!!!
I've just bought two tins as my shine is good, but it could be excellent, anyone reckon I can apply a whole tin to my car?????, so about 10 coats, mine will be so shiny, I'll start setting things on fire
As asked, anyone got a how to for applying collinite because:
A). Do you have to use a strong shampoo concentration to strip your paintwork before applying??????
B). How is it cured with water??? Just a quick spray and then buff???
C). How long to wait for perfect results before buffing properly, and anyone used an auto polisher???
ATB, TIA,
Old 9th June 2008, 02:54   #47 (permalink)
psykik's Avatar
robbo pls give us an idiots guide to Toms how to request above. Im going to print it off and use it!
Old 9th June 2008, 02:55   #48 (permalink)
psykik's Avatar
Originally Posted by illegalhunter View Post
there you go
wow wow wow
well done Sir!
Not a swirl mark in sight, how old is the car?
what did you do between coats?
Old 9th June 2008, 07:44   #49 (permalink)
It's my fault!
I havent stripped the car of the wax at all..But ig I did I would use washing up liquid, followed by polishing with Scratch X and then set to with the Collinite
No you dont but use Washing up liquid or a specially designed citrus wash (See 'Search)
Just a quick spray and a buff with a towel
I start again after 15/20 mins. I havent uised a polisher
Try this site:
A world for detailers...
Old 9th June 2008, 08:05   #50 (permalink)
RELOADING FOR ELK
Originally Posted by psykik View Post
wow wow wow
well done Sir!
its got swirls , its a 57 plate
Old 9th June 2008, 14:43   #51 (permalink)
allan40alt's Avatar
I've just done my bonnet with Bilt-Hamber Balm. Amazing stuff. No residue at all. Brilliant.
Old 9th June 2008, 14:45   #52 (permalink)
Brilliant thanks, I'll give it a go when my tins get here
Old 9th June 2008, 14:55   #53 (permalink)
psykik's Avatar
Alan, can this be used in combination with collinite?
How do the two compare? Are they complementary or substitutes?
Old 9th June 2008, 15:05   #54 (permalink)
allan40alt's Avatar
I don't see why not, but before applying, follow the washing instructions to use hot water and car shampoo (not washing-up liquid as it contains salt and you must avoid soap/shampoo that has salt).
Check with Bilt-Hamber first if in any doubt.
PS: This Balm is also recommended for Chrome and Metal too.
I was amazed how little was needed, just a tiny dab was enough to cover one section of the bonnet.
Old 9th June 2008, 17:14   #55 (permalink)
PJS
You need to use AB over a wax, not vice versa, as the solvent carriers in waxes will likely play havoc with the longevity, if not remove some of the balm.
That said, it is not your stereotypical sealant, as it has a wetness and depth you tend to get with a carnauba wax, but still retains the sealant's flake popness.
Also works on wheels, and glass!
And as above, less is more when it comes to applying - 2-3 dabs in the jar should do you per panel.
Oh, and it's priced much the same as Collinite, but which is less than its true market value should be.
BHL developed it for himself and his classic car(s), and the price is reflective of the fact the 1000's of samples made and tested (R&D), have not been factored in - they've effectively been written off.
Old 11th June 2008, 12:47   #56 (permalink)
Chris_J's Avatar
I found applying the Collinite 476 as thinly as possible allowed me to do a whole car and then buff off. Has to be applied so thin, that you can hardly see it and that also made it a lot nicer to work with. Less is more as the saying goes.
As for durability, not so sure it lasts so long as claimed. I always try and apply it over a sealant as I find the surface a bit nicer for applying the wax to.
Chris_J is offline   Reply With Quote
Old 11th June 2008, 13:11   #57 (permalink)
The Talented Mr. Robbieee
Robbieee's Avatar
Having used both 476s and 915, i can confirm the 915 is more durable... you should try that.
Old 11th June 2008, 14:38   #58 (permalink)
Vet_2010's Avatar
I just ordered a tin of the Bilt-Hamber Balm, the shine allan got is amazing so thought it would be worth a try!
At the moment I have a couple of layers of Collinite on, is it ok for me to put the Balm straight on top of this?
Old 11th June 2008, 15:13   #59 (permalink)
allan40alt's Avatar
See #53 & 54. Similar question.
PS: I haven't finished my car yet. I've done the front and rear but had to leave the sides as the wind started blowing the dust about and I don't want to risk any grit spoiling it.
I'm actually looking forward to getting a second coat on.
PPS: I've a good mind to get an orbital polisher.
Old 11th June 2008, 15:22   #60 (permalink)
Vet_2010's Avatar
Think I need to go get myself a white stick
Similar Threads for: Collinite - before and after
Collinite 476S photo MisterTee Cleaning 30 22nd April 2008 22:02
How long with collinite last? MisterTee Cleaning 13 18th April 2008 08:21
Waxing with Collinite milanoreds Cleaning 87 14th April 2008 19:17
Collinite kmmfc1 Cleaning 11 12th March 2008 14:41
