This thread is about: Help with gear knob!, it's in Cleaning and Styling at the Honda Civic forum Civinfo; Anybody know how to take off the gear knob in a Type R The only advice I've been given is that it will unscrew; but ...
Old 8th June 2008, 19:01   #1 (permalink)
Jonboy8's Avatar
Exclamation Help with gear knob!
The only advice I've been given is that it will unscrew; but not a chance in hell. I've tried by hand, by pliers and even with mull grips, but nothing works. Any help would be grately received.
Jonboy8 is offline   Reply With Quote
Old 8th June 2008, 19:04   #2 (permalink)
Type R GT 09570
It should unscrew, obviously your has been thread-locked on with some Loctite.
If you've had mole-grips on it, it must be scratched by now, so it has got to come off.
Old 8th June 2008, 19:05   #3 (permalink)
dave525's Avatar
Try tightening it a fraction then try to undo it
Old 8th June 2008, 19:14   #4 (permalink)
Jonboy8's Avatar
Yeah your right Dimplyred....got scratch marks on the bottom of gear knob now. But still the bugger will not come off! Getting frustrated now. Anyone else got any advice...PLEASE!!!
Old 8th June 2008, 19:17   #5 (permalink)
Type R GT 09570
Do you have a set of stilsons. They should get it off, but they will wreck it.
Standard Stilsons only £5.99 - Buy Online or Call 0800 310 2852
Forgive me for posting a picture, if you know what they are, but obviously not everyone does.
Old 8th June 2008, 19:24   #6 (permalink)
HACKIN & SLAYIN
You Havent Scatched Your Knob Have You
Old 8th June 2008, 19:24   #7 (permalink)
Jonboy8's Avatar
Well I might have to get some stilsons. Don't mind messing up the old gear knob, fitting a Skunk2 gear knob (that's if I can get this bleeder off). Thanks for the advice Dimplyred.
Old 8th June 2008, 19:26   #8 (permalink)
Type R GT 09570
See if you can borrow some good ones, they will grip onto it, but as I say they will make a mess of it.
Old 8th June 2008, 19:26   #9 (permalink)
Jonboy8's Avatar
See now this could get silly. Not only have I scratched my knob, I'm prepared to wreck it!
Old 8th June 2008, 19:27   #10 (permalink)
Type R GT 09570
I believe you can get a cream for it though.
Old 8th June 2008, 19:28   #11 (permalink)
Jonboy8's Avatar
No cream will cure this!!!
Old 8th June 2008, 20:39   #12 (permalink)
On holiday!!
It just unscrews...Very odd
Old 8th June 2008, 20:43   #13 (permalink)
dave525's Avatar
Cross threaded ???
Old 8th June 2008, 21:38   #14 (permalink)
Type R GT 09570
Again forgive me if you already know this, you are trying to unscrew it anti-clockwise, aren't you?
I assume you are but I thought I'd mention it.
Old 8th June 2008, 22:47   #15 (permalink)
Type R 11239
R GT's Avatar
Underneath the silver gear knob there is a black metal ring that locks up against the bottom of the gear knob itself. if you are turning this part anti-clockwise you are tightening it NOT loosening as it is not connected to the gearknob. put your grips on the ring and turn CLOCKWISE at the same time turn the silver gearknob ANTICLOCKWISE. hope that helps.
R GT is offline   Reply With Quote
Old 10th June 2008, 18:40   #16 (permalink)
Jonboy8's Avatar
Cheers R GT. that did the trick!
Thanks everyone for all the advice. Job done and the skunk2 gear knob works a treat. I'd even say that it goes in gear a lot easier and better now...
Old 10th June 2008, 19:38   #17 (permalink)
Bullson's Avatar
I want to see the miracle !!
Bullson is online now   Reply With Quote
Old 10th June 2008, 19:40   #18 (permalink)
Type R-GT, R-11859
ctrdaveg's Avatar
Why Bother ?? Have u any pics of what you're trying to fit ?
Old 10th June 2008, 20:09   #19 (permalink)
If your old gear knob is still relatively unscathed, you could sell it for good money. The Type R gearknob is a popular item.
Nexxo is offline   Reply With Quote
Old 10th June 2008, 20:11   #20 (permalink)
Adding Type R parts to a non-R car - Civinfo Wiki
Similar Threads for: Help with gear knob!
Gear Knob.......... Rich 11 General Discussion 8 31st May 2008 12:16
Transmission digital gear knob panasony Engines and Transmission 61 17th February 2008 19:48
gear knob dman3uk Type-R 5 24th October 2007 21:22
CTR Gear Knob Kpow99 Holdcroft Honda 6 13th August 2007 10:50
gear knob hannibal555 General Discussion 5 30th May 2007 16:57
