This thread is about: Help needed in converting Gear stick, it's in Styling at the Honda Civic forum Civinfo; have just been reading athread on changing the gear knob, gaitor and facia. i have managed to get hold of the gear gaitor, gear knob ...
Old 7th July 2008, 21:23   #1 (permalink)
slick's Avatar
i have managed to get hold of the gear gaitor, gear knob and facia from a type R.
but i have hit a snag.
i cannot get the facia to fit properly onto the dash. there is a plastic part that sticks out further on the bottom section (if you looked directly at it from above.) it won't hook under, which means the rest of the facia won't push down.
do you think i will have to make any adjustments, or change the cradle that holds the gear ball in place. is there a difference between type r and s
thanks
slick is offline   Reply With Quote
Old 7th July 2008, 21:38   #2 (permalink)
HappyMan's Avatar
Probably best to post some pics so that people can see what you mean.
Old 7th July 2008, 22:14   #3 (permalink)
It's my fault!
Have a look here:
http://www.civinfo.com/forum/general...-will-fit.html
Old 8th July 2008, 10:48   #4 (permalink)
slick's Avatar
Excellent thread, but that was the one i had read originally, the pictures are good but it doesn't show what it looks like under the facia panel.
i would be interested to see what the type r looks like under the gear change facia panel.
i have a feeling that i might need this part
Collar/Spacer (54103-SMT-E00) - £49.77
and this is what allows the new facia to fit over the gear ball.
Old 9th July 2008, 09:30   #5 (permalink)
slick's Avatar
could some one with a type R do me a favour and take a picture of their gear change facia.
or more specifically, underneath it.
i want to see if honda have used the same moulding to hold the gear stick in place. and if they haven't what is different.
i think i might be able to modify the current moulding to work with the type R gear facia.
and if i can it should mean an easy transfer of facias' between cars, and reduce the cost for others if they wanted to have the type R facia, gaitor and gear knob in their civ's
Old 11th July 2008, 13:53   #6 (permalink)
slick's Avatar
am desperate for a type r pic of under the gear change facia can anybody help?
Old 11th July 2008, 14:00   #7 (permalink)
The Talented Mr. Robbieee
Robbieee's Avatar
[how to guide] iPod/iPhone DICE box car Kit installation
any use?
Old 27th September 2008, 03:15   #8 (permalink)
f.ss.t's Avatar
hi guys
it is very hard to fit the type r centre console onto the type s or normal civics
this is why
the rings -on the type rs is different to the normal civic - the normal civic has the ball - then a dark grey ring, and then a silver ring yes?
the type r has the gaitor and then a thinner silver ring with bolts around it
also - the type r gaitor is held in by screws which go down deeper and thus its not a straight forward swap.
you have to grind down the bolts underneath so its smooth to get a good fit and take out the holdings for the type r gear gaitor...
take the gear gaitor holder out and make the underside of the darker grey panel from the type r smooth underneath so it will clip in
then thread through the gaitor and just hold it in place by clipping everythin back down - dont screw it in anyway as it is on the R...takes a cuple of hours!
f.ss.t is offline   Reply With Quote
Similar Threads for: Help needed in converting Gear stick
gear stick knob phil28sth Type-R 3 13th April 2008 22:52
Interior Blue light that shines on the gear stick rhoworth Lights 8 12th July 2007 11:56
How much for the upgrade Gear stick in options mike_GT General commercial posts 7 18th June 2007 11:16
Type-R gear stick? yorkshiregrit Styling 3 15th March 2007 23:10
Squeaks Plastic noise in gear stick : resolved Nanucq Bugs, faults and irritations 0 27th October 2006 08:44
