This thread is about: wheel arch trim, it's in Cleaning and Styling at the Honda Civic forum Civinfo; Does anyone have a clue as to how many pounds, a replacement wheel arch trim costs, somehow, someway, my drivers side wheel arch trim and ...
Old 2nd January 2007, 21:42   #1 (permalink)
itsrelfy's Avatar
wheel arch trim
Does anyone have a clue as to how many pounds, a replacement wheel arch trim costs, somehow, someway, my drivers side wheel arch trim and mud flap have broke, its the clip holding it to the car that has broke so it is not repairable either.
Cheers
Adrian
itsrelfy is offline   Reply With Quote
Old 2nd January 2007, 22:27   #2 (permalink)
Korkut Varol's Avatar
Most probably a fortune....
Old 2nd January 2007, 22:29   #3 (permalink)
generationgav's Avatar
I got one to replace mine; it was about £30 I think, and REALLY easy to replace; just be careful in the fact that the mud flaps go over it, so these need removing first.
Old 2nd January 2007, 22:32   #4 (permalink)
AL56's Avatar
Hi itsrelfy,
Ref, mud flaps on front of car. I damaged mine and was able to buy the plastic poppers that hold the wheel arch on.
Search forum Mudflaps.
AL56 is offline   Reply With Quote
Old 3rd January 2007, 00:40   #5 (permalink)
Enthusiastic Supporter
Miggins's Avatar
Originally Posted by AL56 View Post
Hi itsrelfy,
When I removed the rear wheel arch trims (very carefully) it was the trim that broke and not the clip (where it holds the clip!).
Come on Honda Engineers don't listen to the accountants - make the cheapest part the mechanical fuse!
Old 3rd January 2007, 08:57   #6 (permalink)
itsrelfy's Avatar
Hi itsrelfy,
Hi AL56
IM afraid mine was ripped apart somehow there is a big split in it, but for the life of me i cant think how it happened, the only idea i got is the local council car park and its stupidly steep ramps!!!
Old 3rd January 2007, 08:59   #7 (permalink)
itsrelfy's Avatar
Yes this is the exact problem ive got, again penny pinching every step of the way its a shame isnt it.
Old 5th January 2007, 19:08   #8 (permalink)
Miggins's Avatar
To be honest I think the Engineers are to blame as well for the weak clip mounts.
Cars have always been designed/engineered for a purpose and they sometimes achieve this, however they are not designed to be taken apart and reassembled once never mind frequently.
If you ever have a squeak or a rattle you should always assess whether the risk of more (and probably more annoying) squeaks and rattles after the attempted fix are worth it.
Barbs, tangs and clips on cars tend to be quick snap in-place devices to aid assembly and only operate in one direction. Careful disassembly is always required and a big bucket of spare clips!
Old 5th January 2007, 20:21   #9 (permalink)
pcr
pcr's Avatar
This is something I need to look at. The front wheel-arch trim and sill trim are very loose at the joint where they meet. Probably a missing/broken clip, but it has not been knocked.
Old 5th January 2007, 20:55   #10 (permalink)
Willie's Avatar
This is a problem I had after the dealer fixed door alignment on both sides. It turned out that the clips holding them in place were broken by the bodyshop, they in turn ordered up some clips to fix the trim back into place. I agree that the design of the trim fitting is very poor, if the Honda bodyshop can break them, then what chance has the rest of us got!
Willie is offline   Reply With Quote
Old 5th January 2007, 22:26   #11 (permalink)
pcr
pcr's Avatar
Willie,
Thanks for that, it won't surprise you to know that mine was recently in the body shop. Not another trip to the dealers, it must be in double figures by now.
Old 5th January 2007, 23:07   #12 (permalink)
Willie's Avatar
Hi pcr,
Fortunately the visit for this should only last about 15 minutes, good luck!
Old 7th January 2007, 00:33   #13 (permalink)
Miggins's Avatar
My front wheel arch trim doesn't sit flush to the front wing - one for the dealer next week.
Thanks PCR for reminding me - I'd forgotten about it when it went in for service - the fault list was so long!!
Old 8th January 2007, 12:05   #14 (permalink)
pcr
pcr's Avatar
I was wrong, turns out that the plastic sill is 4mm shorter on that side and therefore does not properly engage with the wheel arch trim.
Old 11th January 2007, 12:27   #15 (permalink)
steveking1000's Avatar
I have the same thing, the wheel arch liner came loose and snapped the trim. My local dealer fixed it all under warentee. Worth a try?
steveking1000 is offline   Reply With Quote
Similar Threads for: wheel arch trim
Front Wheel arch trim rtypeblack Type-R 17 10th November 2007 18:43
Wheel arch tar Milano_Jon Cleaning and Styling 0 13th August 2007 09:45
Trim bumper/wheel arch trim dman3uk Bugs, faults and irritations 2 10th June 2007 18:18
Painted wheel arch trims Silver Driver Wiki Article Discussion 6 12th May 2007 12:01
Rear wheel arch replacement? generationgav General Discussion 6 22nd June 2006 10:47
