This thread is about: hundreds of scratches!!!!, it's in Cleaning at the Honda Civic forum Civinfo; I have noticed there are hundreds of scratches on my car where i have been cleaning. only had a for a month. what can i ...
Old 18th June 2007, 00:15   #1 (permalink)
I have noticed there are hundreds of scratches on my car where i have been cleaning. only had a for a month. what can i do to get rid off it. Does waxing the car help?
w.car is offline   Reply With Quote
Old 18th June 2007, 01:00   #2 (permalink)
wax would help a little, what were you using that scratched it in the first place? How deep are they?
Old 18th June 2007, 01:05   #3 (permalink)
thanks mate, i was using MIRACLE DRYWASH spray then dry it with a soft cloth i think because some of the area i forced it about end up havin loads of scratches. they light scratches but loads......
Old 18th June 2007, 02:38   #4 (permalink)
The drywash products were mentioned recently and people were put off because it could scratch the paintwork. Looks like thats what's happened with you. If they're light a good coat of wax should cover them up rightly
Old 18th June 2007, 06:53   #5 (permalink)
HACKIN & SLAYIN
Wow thats something else learned today, no waterless wash for me then.
Old 18th June 2007, 06:57   #6 (permalink)
Correct, any dirt/dust must be soaked first to loosen it otherwise.........
Old 18th June 2007, 10:06   #7 (permalink)
chriswarwick's Avatar
A secondary reason why I changed my black ES is because I had inadvertantly washed the car without sufficient water causing millions of tiny scratches. I now am utra careful, using a water fed brush, a new leather -which I rinse frequently. There was a product advertised on the Shopping Channels some years ago called GS27 Scratch remover. It came from France[!]. It does work but takes some time and you'll probably need a couple of tubes. Have just checked their website www.gs27.com . Its in French [surprise surprise], so over to you....
chriswarwick is offline   Reply With Quote
Old 18th June 2007, 10:22   #8 (permalink)
cheers lads, after i had these scratches i dont dont dare to clean my car myself thinking of gettin these mobile car wash company that come round house or office to clean + polish or wax. What you recon worth it or do it myself?
Old 18th June 2007, 10:29   #9 (permalink)
I've been told not to use the automatic car washes as they can scatch the car. Feel unsure about mobile car washes as they might be 'just doing a job' and not care about using sufficent water or rinsing any grit out of cloths.
Old 18th June 2007, 15:15   #10 (permalink)
ante00's Avatar
yes it is true...automatic carwasah can scratch car but you can see it...only if you look closely roof for example...you can see lines........for small scratches you have sonax scratch remover and it is very good....helped me to remove few scrathes from doors and hood
Old 18th June 2007, 15:21   #11 (permalink)
Charles_Harding's Avatar
There is no substitue for DIY in car cleaning.
Only you has the care and compassion to really clean properly a Space Ship.
Have a look around this section, under cleaning, nip out to Halfrauds, get some stuff, then Bingo, all the kit for DIY.
It may take a while, but Heck!
That motor cost thousands!
When you finish, and if you have done as we try to tell you, you should be very proud of 'All my own work'!
"I do definately believe in luck.
How else can you explain the success of those you don't like?"
Charles H.
Old 4th August 2007, 15:57   #12 (permalink)
If you are really OCD throw the leather and brush away as these too will scratch the top coat.
Best process by far is to rinse, pre-wash (best with foam as this draws dirt off the surface) rinse then hand wash with mitts (not sponge) using 2 buckets, one for shampoo, one to rinse the mitt.
To dry use a microfibre cloth and Megs Quick detailer (spray on when wet)
This absolutely reduces the chance of scratching the paint.
BUT - your neighbours will think you're a freak
m33
m33porsche is offline   Reply With Quote
Old 6th August 2007, 13:51   #13 (permalink)
Smell My Cheese!
richierich's Avatar
Originally Posted by m33porsche View Post
..............BUT - your neighbours will think you're a freak
m33
Mine said just that to me last night, apparantly him and his Wife were playing a game to see how many times I would go round the car, he won, he said 7. Rinse, Wash, Rinse, Dry, Clean, Polish, Wax. Thanks to Mrs RR it only took a little over 2 hours on Saturday morning, looks great though.
Old 6th August 2007, 14:22   #14 (permalink)
binchy's Avatar
Which Polish and Wax do you use on your Red Civic? Does it give a wet look finish?
binchy is offline   Reply With Quote
Old 6th August 2007, 14:31   #15 (permalink)
Is that all !
When I wash mine I go round it more than 7
Rinse = 2 (just to make sure)
Roof - 2 sides = 3 (can't reach the whole lot in one)
Then I wash all round from the bottom window line up = 4
Then all round down to the top of the bumper line = 5
Bumper & below = 6
Wheels = 7
Rinse = 9 (double whammy)
leather = the same rigmaroll = 14
then I open all the doors, tailgate, bonnet and go round = 15
Then go round with the Vax = 16
If I wax then take the number you first though of.........................
Old 6th August 2007, 19:35   #16 (permalink)
Originally Posted by Kremmen View Post
Is that all !
Bumper & below = 6
Wheels = 7
feel like I've come home
Old 7th August 2007, 00:07   #17 (permalink)
Honda Tardis
LoonyJohn's Avatar
Just to mention, TOYOTA, the car plant in Derby, use 3M Finesse-it! for light scratch / mark removal. It is expensive, but easily the best polish available today - e.g. £15 per litre on eBay
LoonyJohn is offline   Reply With Quote
Old 7th August 2007, 06:47   #18 (permalink)
joonyar's Avatar
I noticed a few scratches on mine & I bought Turtle wax colour magic plus (look here Turtle Wax) costs about £7
since mine is black I think scratches show up more but........
Anyway after applying this it really made a difference to the scratches, I had to really search for them.
joonyar is offline   Reply With Quote
Old 7th August 2007, 14:19   #19 (permalink)
richardc's Avatar
AutoGlym Super Resin Polish is great for disguising swirls. Cover with a good wax/sealent and should look good for a while.
richardc is offline   Reply With Quote
Old 12th August 2007, 10:11   #20 (permalink)
Smell My Cheese!
richierich's Avatar
I use the Meguiars 3 step jobby, it gives a great shine, I would not say its as wet as some of the pics I've seen but the shine is really nice and it really deepens the red.
Similar Threads for: hundreds of scratches!!!!
Dashboard Scratches Alix Cleaning 180 18th May 2008 21:47
Scratches Steevie Cleaning 23 1st February 2008 12:25
Scratches duffbear General Discussion 34 27th October 2007 10:14
Damage I've just caused hundreds of pounds worth of damage to my pride and joy :( emmaloula Bugs, faults and irritations 23 9th May 2007 07:08
Repairing Scratches Topcat Cleaning 21 10th January 2007 15:51
