This thread is about: Exhaust Triangle Trims, it's in Cleaning and Styling at the Honda Civic forum Civinfo; hi all im looking at buying some exhaust triangle trims for my 1,4 se civic 2007 ,they are just for show so will i need ...
Old 27th November 2007, 20:37   #1 (permalink)
jamo9017's Avatar
hi all im looking at buying some exhaust triangle trims for my 1,4 se civic 2007 ,they are just for show so will i need to cut out the hole or do they just clip on thanks
jamo9017 is offline   Reply With Quote
Old 28th November 2007, 13:31   #2 (permalink)
jamo, I tried this on my old 1.4 as I thought it would be a simple matter of replacing the plastic trim with the new one. No such luck- I got the metal trim and it has to be held on with a bracket. To go for the honda bracket you would need to buy loads of other brackets, holders and stuff. Cheapest way would be to get a metalworker to make you a bracket and in this case all you would need are the metal trims.
Hope this helps
Old 28th November 2007, 16:09   #3 (permalink)
jamo9017's Avatar
thanks for the info mate
Old 29th November 2007, 14:25   #4 (permalink)
if I remember correctly, the entire kit was about £70 odd quid from Honda dlrs?
seem to remember Danko doing it to his (Dad's) 1.4
Old 29th November 2007, 15:20   #5 (permalink)
Teehee!
Old 29th November 2007, 18:28   #6 (permalink)
kryten's Avatar
Honda used to do a kit that converted 1.4's to full twin triangular exhaust set up, the part number is 06KIT SMG EXTFIN. Might be worth seeing if dealers can still order that.
kryten is offline   Reply With Quote
Old 29th November 2007, 18:41   #7 (permalink)
HACKIN & SLAYIN
£70 for the trims woo thats expensive
Old 29th November 2007, 19:07   #8 (permalink)
Would two triangles from a music shop not do?
Or some silver glitter pens?
Old 29th November 2007, 19:22   #9 (permalink)
barrel, bottom of, scraping there CZ
Old 29th November 2007, 19:58   #10 (permalink)
I'm just putting the ideas out there TT, no pressure to use them!
Old 29th November 2007, 20:19   #11 (permalink)
kryten's Avatar
The Honda kit came not only with the triangular trims but also the rear section of a 1.8 exhaust to give you proper twin exhausts for your 1.4.
Old 29th November 2007, 20:36   #12 (permalink)
Guess that goes some length to explaining the cost.
Old 5th December 2007, 20:39   #13 (permalink)
cho
I have some for sale
2 X Triangle exhaust trims from 1.8 Sport
cho is offline   Reply With Quote
Similar Threads for: Exhaust Triangle Trims
Exhaust Remus Exhaust Mr Lovedog Engines and Transmission 9 13th May 2008 09:58
Exhaust Exhaust trims? Naresh Engines and Transmission 29 25th July 2007 22:54
Touching up "Aluminium" trims Spud Cleaning and Styling 12 15th June 2007 13:36
Painted wheel arch trims Silver Driver Wiki Article Discussion 6 12th May 2007 12:01
Exhaust Exhaust Garnish! DanKo Engines and Transmission 1 1st November 2006 23:45
