Commercial user
![]() Join Date: 28th November 2008
CPL Race Manifold (FN2)
We are often asked for information on our CPL FN2 manifold. Below is a list of features and relevant information:
- Developed in house over a period in excess of 1 year in order to ensure optimal design and quality, extensively dyno tested and road tested to ensure durability - All stainless steel construction (Grade 304) including flanges - High quality Tig welds - Welds are back-purged (back-purging is a process used when welding high quality pipework when full penetration of the weld is required, it results in a totally smooth weld on the inside as well as the outside). The back-purging process used on the CPL manifold is the same process that is used in Formula 1 exhaust manifold construction - Highest quality fabrication techniques used - Has optimal compatability with the Hondata Group N ECU, as the ECU was tuned specifically with the CPL Racing manifold - Pipe diameters and lengths optimized for best horsepower and torque gains throughout entire rev range - Direct fit with standard and aftermarket catback systems - Little to no increase in exhaust noise - Suitable for both naturally aspirated and supercharged cars - Lightweight, only 5.4 kilos compared with standard manifold which weighs 13.8 kilos - Economical to ship as comes in 4 sections which fit in a small box (this is particularly important for our overseas customers for which shipping a 1-piece manifold can be expensive) - Realistically priced for such a high quality manifold at £749 excluding VAT Below is some feedback we have found on the forums regarding the CPL manifold David – Poland (Civicinfo forum) “I have had fitted CPL 4-2-1 Race Manifold and the first impression of driving feelings is astonishing! I don't know how many BHP comes on the engine, but I really feel the difference, Significant much more power is available now !” Nuno – Portugal (civictype-r forum) “Today I decided to take my car to shop and fit the CPL exhaust manifold and a RRC intake manifold. I went to one of top racing teams in Portugal that have won the Portuguese touring championship some years ago with a Ep3 ctr by jas motorsport, raced DC5 integra" And here are some photos Last edited by CPL Racing; 23rd February 2009 at 15:09. Reason: correction of punctuation error |
Thanks to CPL Racing from:
![]() Join Date: 9th August 2007
I have this manifold and Hondata ECU , and the feeling is very good , it definitely pulls much harder trough the rev range !
After power upgrade you will feel that you need an LSD, too |
Commercial user
The exhaust manifold is easily accessable from underneath the car. Fitting is as easy as removing the cars stock manifold and catalytic converter and replacing with the race manifold. |
#12 (permalink) |
![]() Car: FN2 - K20/K24
Indeed. Fitting is quiet easy, but I recommend some potential buyers to do it with PRO. I'm very happy with CPL exhaust manifold, now I'm waiting (this week
The Poor Boy
![]() Car: 2007 FN2
took us a while to fit it...you could also get the manifold off by taking the weather guard, cowl top off...
just to add what CPL said- the manifold transforms the car...the pull and flow is so much better...highly recommend it..expensive but well worth it if you want the best gains guy- i should do all your advertising lol |
#15 (permalink) |
![]() Car: 2008 CTR, MILANORED
I had the CPL-Manifold in connection with the Hondata Reflash ECU.
I was not satisfied with the Manifold of CPL-Racing. in the lower speed range, he was clearly worse to drive or has clearly lax. in higher speed range he was not so much spinning happily. from 4500 rpm, I have a greater thrust to observe. this should not serve to CPL-Racing bad to talk, because I quite happy with the service. Last edited by NDFN2; 27th February 2009 at 17:31. |
#16 (permalink) | |
Commercial user
Your feedback is always appreciated but I can only imagine that something else in your setup caused the lack of power that you experienced as you are the only customer who has ever reported this, additionally the manifold that you purchased from us, I believe is now owned by fat4y who has experienced the opposite to you as per his comments above.
#17 (permalink) |
Commercial user
I would also like to add some info regarding fitting of our manifold as there seems to be some confusion.
Without a shadow of doubt a ramp is needed to fit this to make life easy There are no parts that need to be removed from above With the car on a ramp/lift all of the fitting can be carried out from under the car If there are any more questions regarding fitting feel free to post them. |
#18 (permalink) |
Yes, I agree with you CPL. I recived some PM concernig installation of CPL manifold from other user and he has some gas leaks problem during instalation so I think is easy to screw up something. I'm very happy with CPL manifold, soon I'll compare with TODA manifold. I'm pretty sure it would be very similar gains to CPL manifold. Anyway , It is not a spaceship technology indeed, and there so many manifolds for SI on the US market (Buddy Club, Hi tech, DC sport, etc) all of them showing us a similar gains +/- 3 hp. These 3hp are not noticable during driving.
This is mine opinion regarding manifolds. David |
#19 (permalink) |
I have the manifold mounted correctly and everything was tight.
I remain convinced that with my car everything is in order. I had a direct before and after comparison. I had neither a pit or a lift, so I had to part from the top of the car/engine. I have the car with two jacks lifted gently upward. Ultimately, everyone must know what convinced him and what not. With my current modifications, it is much better anyway! And also with legal catalyst, which is very important to germany roads! Last edited by NDFN2; 27th February 2009 at 23:46. |
#20 (permalink) |
NDFN2 please do not get me wrong, I'm not trying to say that you have done something wrong, no,no. I'm tellin you tha this Manifold transorm my car, dinoc car , nunoctr and one guy from russia as well, so it's little bit weird, you know what I mean?
Next week I'll compare with TODA manifold. Frirend of mine has purschased already and waiting for fitting, than we do a rolling road racing, and then I would tell more concerning CPL. Is good enough or not. If is not good enough, I'll buy a TODA . Cheers ! Last edited by Dawid S; 28th February 2009 at 15:15. |
LinkBack to this Thread: http://www.civinfo.com/forum/cpl-racing/23400-cpl-race-manifold-fn2.html
| Oppgraderinger på Honda Civic Type R 2008 - Club Honda | This thread | Refback | 18th March 2009 18:14 | |
Similar Threads for: CPL Race Manifold (FN2)
| Where to buy RRC manifold? | redlag | Type-R | 73 | 9th February 2010 18:27 |
| FN2 Race Manifold | tdi-north | TDI North | 36 | 7th April 2009 00:35 |
| For Sale Cpl Race Manifold 1 week old | parsey | For sale and Wanted | 43 | 7th January 2009 00:03 |
| New manifold for the fn2? | K15KNY-FN2 | Type-R | 4 | 20th August 2008 21:50 |
