Civinfo CPL Racing
Go Back   Civinfo > Commercial > CPL Racing
Old 17th July 2011, 23:14   #1 (permalink)
Flat spot
Looking at getting my civic type-r Ep3 down to you soon to have some work done.
My car is standard apart from a Gruppe M intake and a K-pro ECU.
Since installing the K-pro and intake the car wont rev above 3k and just hits a flat spot. Also the car struggles to start, like its starved of something?
Looking at trying to get it down to you to have my JRSC fitted and mapped.
Any ideas what the problem may be?
Adam
cooper326 is offline   Reply With Quote
Old 17th July 2011, 23:23   #2 (permalink)
I-VTEC everyday ;)
dragon276's Avatar
Car: 59 Crystal Black Pearl CTR
Thanks given: 34
try put your original ECU back in, think it's the map on the kpro that's causing the problems
dragon276 is offline   Reply With Quote
Old 17th July 2011, 23:30   #3 (permalink)
Cigar Chomper
Loxy's Avatar
Car: 57 CTR GT Alabaster Silver
Thanks given: 492
Or put one of the base maps from the Kpro management software on it.
Do you know what the Kpro was mapped for previously?
Loxy is online now   Reply With Quote
Old 21st July 2011, 22:35   #4 (permalink)
higham's Avatar
Car: 57 CTR GT, NHB
Thanks given: 139
do cpl even come on here anymore?
edit: just looked yeah they do last time they were on was the 18th???
higham is offline   Reply With Quote
Old 22nd July 2011, 09:20   #5 (permalink)
Commercial Sponsor
Thanks given: 1
Hi Adam,
It sounds like your car is on limp mode.
Check that you have not disturbed something whilst fitting the Gruppe M
Also try loading one of the base maps from the software as previously suggested.
Did you purchase the KPro used?
CPL Racing is offline   Reply With Quote
Old 22nd July 2011, 10:16   #6 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 737
Have you removed the MAF sensor if it has one?
Basically check all the sensor are connected and oriented the right way.
Check all the vacuum pipes are connected or plugged.
Check for air leaks.
Similar Threads for: Flat spot
flat spot cf136322 Type-R 7 7th April 2011 12:37
Performance flat spot john1509 Engines and Transmission 3 9th August 2008 17:36
Performance flat spot john1509 Engines and Transmission 27 6th November 2007 18:20
Flat spot bonzo Type-R 22 1st November 2007 20:50
Engine CDTI Flat Spot? 323GT-R Bugs, faults and irritations 58 13th August 2007 19:49
