Civinfo CPL Racing
Go Back   Civinfo > Commercial > CPL Racing
Old 30th May 2012, 22:43   #41 (permalink)
ash_rage's Avatar
Car: CTR GT
Thanks given: 702
Originally Posted by Noxia View Post
Mine arrived today. It was your review which tipped me over to order it Ash. Can't get it installed for a while but that's ok.
Good to hear buddy. Whose installing it?
ash_rage is offline   Reply With Quote
Old 31st May 2012, 09:47   #42 (permalink)
(\)o_O(/)
Noxia's Avatar
Car: 2008 CTR, Silver
Thanks given: 559
Don't know yet. Probably the same garage who will do my manifold
Noxia is online now   Reply With Quote
Old 31st May 2012, 11:10   #43 (permalink)
The Property Man
fat4y's Avatar
Car: 2007 VW Beetle 1.6
Thanks given: 24
Nice write up ash..i wanna see videos!!lol
If i was to buy an fn2 again id try this kit
fat4y is offline   Reply With Quote
Old 31st May 2012, 11:40   #44 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 717
Well the CAI is fitted and sounding great. It's a little groggy now on rapid throttle changes but I suspect with a bit more driving round the ECU will improve a bit. Need to get it to TDI for mapping now, really.
It's not the quickest of installs, especially in the dark using a torch
Two things that need to be said (I'm gonna call CPL about these, too) are 1/ the bracket needed some slight tweaking to get it to the mounting point, and 2/ where the breathers are braised on there was a couple of metal flakes on the inside of the tube that I had to remove as it looked like they might come off and get sucked in to the engine. The HKS RSK had the same bits of metal that needed cleaning out so this isn't just a CPL thing. Just be aware before installing.
Revs FN2 is offline   Reply With Quote
Old 7th June 2012, 22:55   #45 (permalink)
Chrisn01's Avatar
Car: 2009 2.0 Civic Type R, Red
Hiya Mate
Is it quiet easy to install and do you have to remove bumper? Also, has the groggy'ness ceased yet as thinking about getting one myself, but am still on the fence lol.
Cheers
Chrisn01 is offline   Reply With Quote
Old 7th June 2012, 23:29   #46 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 717
I'm running a FlashPro now so yes, long gone Seems to effect some cars and not others, also I have a misreading ARF sensor which CPL corrected for in the remap. Goes like stink now and sounds awesome. Like the HKS but not coming from inside the dash (don't know if you've heard one but the RSK is bloody loud inside the car).
As for fitting. It's case of relocating the battery (easy), lengthening and rerouting a wire (needs soldering), Rerouting a minor coolant hose, NS arch cover off and lining out, loosen bumper and move out about 2" forward to get to remove the stock resonator bolts, remove ducting, fit CPL intake tube, fit K&N, fit supplied breather hoses, reassemble. Job done!
Old 8th June 2012, 13:26   #47 (permalink)
ash_rage's Avatar
Car: CTR GT
Thanks given: 702
Bumper doesn't need to come off.
Put it this way: if I can install it, anyone can.
Old 9th June 2012, 00:53   #48 (permalink)
Coskun's Avatar
Car: 2007 Honda CTR FN2
Thanks given: 2
Is there bhp & torque differences between cpl cai vs factory cai with performance panel filter? (both tuned)
Coskun is offline   Reply With Quote
Old 9th June 2012, 02:31   #49 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 717
Probably very little. Though I bet as mods continue the CPL CAI is less likely to become a restriction.
Old 9th June 2012, 03:27   #50 (permalink)
bryte1's Avatar
Car: 2008 Honda Civic Type R
Hi all,
I has just had my FN2R in to Jtune for their CAI intake install (very similar setup to CPL CAI) and Hondata reflash tune. Totally different car now! The car in stock form would demand a heavy right foot and snappy gear changes to keep the power and revs up... after tune and CAI it now requires quite a different driving style, as it seems to have much improved pick up and pull without needing to mash the accelerator. Intake sound is immense, especially if you do decide to mash the accelerator! Intake noise does actually quieten and smooth out when driving and shifting above 6000rpm. The throttle response of the stock setup seems a joke in comparison.
Cheers,
Bryan
bryte1 is offline   Reply With Quote
Old 9th June 2012, 12:07   #51 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 717
Nice one Brian. I think the CAI sounds best just after the low Vtec point.. about 4200rpm... sounds raw and throaty
Out of interest; did you end up with a MAP or a MAF tune?
Old 10th June 2012, 07:08   #52 (permalink)
bryte1's Avatar
I believe it is a maf tune. Custom tuned on dyno after install of CAI. Piping of CAI still has MAF sensor in place. The intake sound is nice with a more gentle right foot, heavy right foot sounds like a large horny bull is about to leap out of the bonnet. Will be asking the guys about this next week to see if the tune needs tweaking or whether this is just the typical response with rapid open throttle with CAI.
Old 10th June 2012, 11:09   #53 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 717
The MAF sensor has to be left in place as it also houses the AIT sensor, but with a MAP tuned the MAF sensor is ignored.
Old 13th July 2012, 19:44   #54 (permalink)
Car: 2009 NHB CTR
Thanks given: 18
Originally Posted by rowbo View Post
Anyone ?
Here is my experience of the CPL CAI.
Who ever said it a dig job was a proper joker as it just isn't.
It killed my car, it felt as flat as a pancake. My car was running a toda and a CPL manifold.
Took it to TDI the very same day as it was THAT bad !
OMG - it woke up big time - the sound- the performance.
It's not the prettiest thing, but it's in expensive and works on a maped car
shae is offline   Reply With Quote
Old 13th July 2012, 20:13   #55 (permalink)
ash_rage's Avatar
Car: CTR GT
Thanks given: 702
Correct me if I'm wrong.
You run the group n map. You fitted a 4-2-1 exhaust manifold which is a decat... and your surprised you needed a custom remap?
Do you have any idea how much the engines VE changes when you go from the stock manifold to a 4-2-1 decat? A lot. But yeah it's solely the CPL CAI's fault ... Not.
I fitted mine with no issues, as has many others.
You purchased a second hand one which you said in another thread didn't come with instructions.
It's easy with instructions.
Old 14th July 2012, 03:34   #56 (permalink)
Car: 2009 NHB CTR
Thanks given: 18
yes i did run a gp n map, like i said it didnt work with my mods and that map.
i never said it was cpl fault
i had a copy of the instructions from cpl
i also said how good the product was when maped.
gave an honest report of my experience
Old 14th July 2012, 09:45   #57 (permalink)
ash_rage's Avatar
Car: CTR GT
Thanks given: 702
Ah ok, your post is poorly worded then as it came across like you was solely blaming the CPL CAI.
Anyway good to hear you're now pleased with it.
Old 14th July 2012, 15:01   #58 (permalink)
Car: 2009 NHB CTR
Thanks given: 18
i was blaming the cpl intake, because that is what it did to my car with the mods i was running. it destroyed them UNTILL it was mapped. Once mapped it performs extreamy well, wouldnt have anything else.
Old 15th July 2012, 22:11   #59 (permalink)
ash_rage's Avatar
Car: CTR GT
Thanks given: 702
If you say so.
Old 15th July 2012, 22:50   #60 (permalink)
(\)o_O(/)
Noxia's Avatar
Thanks given: 559
That's funny because I drove home on stock map with a newly installed CPL CAI and a race header and it drove alright.
Actually I was also on group N.
Tags
cpl cai review fn2
Similar Threads for: CPL CAI Review - FN2
Crz review regan1985 Honda CR-Z 7 13th July 2012 12:45
5dr 2.2 FRS Review DannyBoi ABP Motorsport 2 26th February 2011 13:43
ABP Review murray ABP Motorsport 18 13th October 2010 11:26
another 1.8 review g_bak User Reviews 7 11th September 2008 07:49
new honda civic review + NEW review added and a bit funny sco77harris User Reviews 7 8th July 2006 09:59
