Thinkware had a wiring mix up on the early F770's, so the red/yellow wires were actually reversed.
One is for switched ignition live and the other for parking recording which should be hooked to a constant live feed. Don't necessarily believe the label on the wires.
As I don't use the parking option (disabled in the device) I hooked both yellow/red wires to an ignition switched supply. Easy.
With weak Civic electrics I don't recommend you hook up the constant power supply UNLESS you have another power source.
If you want to ID which colour wired is switched and permanent, then the hook both up initially and wait for the camera to boot. Disconnect one wire and if the camera stays on for more than 5 sec's or so then that's the permanent wire.
I knew about the option to switch off at a set voltage and figured if I set it to 12.5 volts then try parking mode on a weekend, to avoid having a flat when going to work, unless anyone knows the minimum a 1.6 DTEC needs to start I would try lowering the cutoff each weekend to see what I can get away with.
Regarding the option connector, where can I pick one of those up from ?
I am fitting the option connector and have 12v with ignition on but can't seem to get the battery constant working. I've wired bottom left and bottom right to 2 spade connectors and the multimeter only registers 1 wire 12v with ignition on. Did they change the battery 12v connector for the 2016 civic ?
Either that or my wiring is duff.
Related Threads
2006+ Honda Civic Forum
2.5M posts
104K members
Since 2006
