![]() Car: 2012 1.8 5 door,White Orchid
Thanks given: 15
Transmission kickdown
Hi all,
Have had my Civic for 2 months now (1.8l Auto SE) and noticed a distinct lack of power when mashing the accelerator pedal to overtake. To compensate I would regularly use the paddle shift function. Tonight i realised it was the rubber floor mat preventing the pedal from allowing kickdown. I have a rubber mat to protect the factory carpet floor mats. The thickness of the rubber mat was just enough to prevent full travel of the pedal. This was the only major criticism of the car and it has been resolved. |
![]() Join Date: 19th February 2008
Thanks given: 6
I have the same car and notied that the kickdown is sort of in two stages.
There is a feeling of pressing over some gentle resistance and then the car does change down a gear, However by continuing to press down on the pedal it turns out that there is still some pedal distance to go and there is a more firm resistance point which when passed makes the car change right down and leap forward. I was worried about my acceleration until I found how to work the kick down. Now it works instantly and is ideal for fast overtaking. |
Thanks given: 15
Yes, it takes more of an effort to initiate kickdown. You'd probably not do it often as the engine noise is quite loud when doing so.
Thanks given: 6
The paddles work differently according to whether the selector is in D position or S position.
Basically in D position the paddle change will return to normal auto when it senses you no longer need it. In S position it stays with the paddle choices. |
Similar Threads for: Transmission kickdown
| Transmission Transmission clicks | Terry_uk | Engines and Transmission | 1 | 16th July 2012 21:27 |
| Servicing i-shift transmission oil change | keigo | Engines and Transmission | 5 | 28th September 2011 07:46 |
| Transmission Is your transmission noisy | griffian | Engines and Transmission | 8 | 5th April 2011 01:51 |
| Transmission Transmission rating | Melba Toast | Engines and Transmission | 0 | 21st July 2009 00:21 |
| Transmission i-shift kickdown | shieldy2k7 | Engines and Transmission | 6 | 30th August 2008 12:42 |
