This thread is about: Disappearing Diesel, it's in Engines and Transmission at the Honda Civic forum Civinfo; Living in Northern Ireland gives me the opportunity to buy my diesel in the Republic of Ireland at approx 85p per litre, a substantial saving ...
Old 8th December 2007, 11:16   #1 (permalink)
madasadad's Avatar
Disappearing Diesel
Living in Northern Ireland gives me the opportunity to buy my diesel in the Republic of Ireland at approx 85p per litre, a substantial saving when covering 30k miles per year. Yesterday morning with 35 miles showing on the readout to empty, and 70miles to the border, I called into a local filling station and put in 7litres of diesel. When I restarted the engine, needle hadn't moved and readout still showed 35 miles. Curious I thought and drove off, thinking it would sort itself out further up the road. About a mile later, the reading was still the same, so I returned to the filling station and asked the pump attendant if it was possible for the pump to indicate a delivery of fuel, but not actually deliver it. A simple no would have sufficed, however he called the manager who then proceeded to fill a 5litre can with fuel in front of me, whilst I felt a tw*t. Common sense told me that it would be impossible for a pump to register fuel delivery when none was present, but I couldn't believe my Car was lying to me!. So, full up on humble pie, I then went to another filling station, and put another 5litres in to see if that made any difference. Again, Judas betrayed me and showed only 35 miles to empty. So, 2.5 gallons later, the Civic still hadn't registered the fuel having been added. When I eventually filled up later, all was fine again, and the needle and range indicator behaved again. Any ideas?, I'm not overly concerned since I always plan my journeys to fill up in the South where possible, or if I'm not going to make it, I fill up at home. It was the first time in 20000miles that I hadn't put a full tank of fuel in!
Old 8th December 2007, 11:40   #2 (permalink)
Probably the culprit is the electronic fuel sensor - in my Citroen Xsara a few years ago I had an early version of this - I could fill in 15 litres without a change in the computer readout (and gauge!)
Just another pseudo-modern gimmick no one had asked for but everybody gets - probably because it's cheaper to make (?)
Old 8th December 2007, 11:46   #3 (permalink)
You need at least a couple of gallons (10 ltrs ish) for the car to realise that more has gone in
This is to stop it getting overly optimistic / pesimistic as you drive up and down hills
Old 8th December 2007, 12:02   #4 (permalink)
madasadad's Avatar
Possibly, however, I added 12 litres to approx 3 litres already in the tank, which is 3 gallons'ish, so I'm surprised it didn't register any improvement when the 12 litres were added. Must be a Civic thing, another one
Old 8th December 2007, 12:07   #5 (permalink)
Maldax's Avatar
Yea it is a pain! I have added £10 and then another £10 the following day with nothing showing up and must have had a quater of a tank in!
Did read somewhere on here that it has something to do with the shape of the tank as it has a ridge in the middle and the sensor is on the wrong side of the ridge
Old 8th December 2007, 12:42   #6 (permalink)
I should have added - 'in one go'
Old 8th December 2007, 14:57   #7 (permalink)
The voice in your head
aslz78's Avatar
I had the same thing on my Focus when i was going to pick the civic up, put about £7 of petrol in, but the computer didnt recognise any, still got me there fine tho.
aslz78 is online now   Reply With Quote
Old 23rd January 2008, 00:25   #8 (permalink)
hi there...i just got my civic type s gt 2.2 ctdi before christmas + have found the same as you, that when refuelling, the range didnt go up at all! i also found that when i drove the car to 0miles...i was able to continue driving for another 50/60miles! i have never drove it til it ran out so goodness knows how far i could have got. also im doing a test at the minute on border fuel vs not border fuel...apparently its a false enonomy + you mite get more miles from the dearer stuff.
jelliedrik is offline   Reply With Quote
Similar Threads for: Disappearing Diesel
Fuel best diesel for 2.2 gb110430 Engines and Transmission 68 3rd September 2007 12:54
Oil Is OW-40 ok for 2.2 diesel crid Engines and Transmission 2 8th July 2007 14:27
MPG mpg in 2.2 diesel from new. Type S Bournemouth Engines and Transmission 33 8th March 2007 09:11
What mpg are you getting from your diesel daveyboy Buying, Dealers and Servicing 2 30th November 2006 20:54
Diesel SUPERTEACH Any non Civic chat here please! 14 5th October 2006 04:06
