This thread is about: Gearbox oil level, it's in Engines and Transmission at the Honda Civic forum Civinfo; Am I missing something ............how do we check the oil level in the Gearbox ? I have checked everywhere.........got no clue, I must be missing ...
Old 17th December 2007, 17:21   #1 (permalink)
Alantaverham's Avatar
Gearbox oil level
Am I missing something ............how do we check the oil level in the Gearbox ? I have checked everywhere.........got no clue, I must be missing something !!
1.8 i-shift ES
Alantaverham is offline   Reply With Quote
Old 17th December 2007, 17:30   #2 (permalink)
Greedy's Avatar
You should not need to check the oil in your gear box. Unlike the engine, the gear box does not 'consume' oil ordinarily and thus it only needs checking at services.
Old 18th December 2007, 21:40   #3 (permalink)
DUNCAN's Avatar
Old 18th December 2007, 22:41   #4 (permalink)
Tyre Shredder
ritchie_perriam's Avatar
there should be a little viewing window or bolt to take out to check, but the car would need to be level so you cant just use a normal carjack to get the car up.
in modern cars the gearbox oil is expected to last the life of the gearbox or at least 80k miles, so i wouldnt worry about checking it unless there are signs of leaking from the gearbox.
Old 18th December 2007, 22:50   #5 (permalink)
Type R GT 09570
Yes, the gearbox level is not a routine check most manufacturers expect owners to carry out.
Old 19th December 2007, 09:02   #6 (permalink)
Thanks folks for the info..........I will relax now !!!!!!!!!
Similar Threads for: Gearbox oil level
Gearbox, Enginestart .. any Problems? siam Type-R 8 5th May 2008 07:46
Transmission Gearbox - Type R 3rd gear eddie1010 Bugs, faults and irritations 3 23rd October 2007 12:48
Transmission closer gearbox for civic '07 1.8 5d Roukounas Engines and Transmission 0 23rd September 2007 15:48
Oil oil level Type S Bournemouth Engines and Transmission 23 12th July 2007 10:42
Transmission Gearbox on i-CTDi Notchy Tydo Bugs, faults and irritations 10 5th October 2006 22:10
