This thread is about: Exhaust question, it's in Engines and Transmission at the Honda Civic forum Civinfo; I was looking at the rear exhaust tail pipes on my 1.8SE. On the right hand side, where the pipe bends there is a "Bracket" ...
Old 21st December 2007, 06:54   #1 (permalink)
Russell 10's Avatar
Exhaust question
I was looking at the rear exhaust tail pipes on my 1.8SE. On the right hand side, where the pipe bends there is a "Bracket" welded to the pipe, but isn't attached to anything. I noticed moisture dropping through a hole in this bracket. Is this normal, or has my tailpipe got a small hole in it. The car has only done 6500 miles. I would appreciate your comments.
Russell 10 is offline   Reply With Quote
Old 21st December 2007, 08:36   #2 (permalink)
Munro's Avatar
I don't know about the bracket, but it is not unusual to have a drain hole in an exhaust. Its there for the cold starts to drain out water condensing from the exhaust gases. Otherwise water would collect in the exhaust until the exhaust was hot enough to evaporate it.
Similar Threads for: Exhaust question
Exhaust Remus Exhaust Mr Lovedog Engines and Transmission 9 13th May 2008 09:58
sports exhaust Ali Type-R 9 10th December 2007 10:22
Exhaust Exhaust trims? Naresh Engines and Transmission 29 25th July 2007 22:54
Exhaust Exhaust Garnish! DanKo Engines and Transmission 1 1st November 2006 23:45
Other Sports Exhaust Fitted d555h3k Gallery 8 19th October 2006 21:12
