Performance misfire - Civinfo
post #1 of 6 (permalink) Old 18th December 2013, 19:46 Thread Starter
vision's Avatar
Car: 2006 ctdi ex civic
misfire
Hi all.
I am having a problem of a intermittent misfire.
It only happens at 1700 revs and sitting at those revs.
If im in 4th 5th gear at 1700 revs it will misfire but before those revs and after it its fine.
So when I accelerate to say 3000 revs from 800 its fine its only when im cruising at 1700.
o and only does it when its warm,
Has anyone else had the same problem any help would be great cheers john
vision is offline
post #2 of 6 (permalink) Old 18th December 2013, 19:49
stoney's Avatar
Car: 2007 FN2 GT
What car?
stoney is offline
post #3 of 6 (permalink) Old 18th December 2013, 20:15 Thread Starter
vision's Avatar
oops sorry mate its a civic ex 2.2 2006
vision is offline
post #4 of 6 (permalink) Old 18th December 2013, 20:20
stoney's Avatar
Car: 2007 FN2 GT
Diesels don't missfire, what you are experiencing is soemthing else.
What exactly is happening, could it be clutch slip ie. the engine rpm rises but the speed doesn't? if that's the case your clutch is screwed.
stoney is offline
post #5 of 6 (permalink) Old 18th December 2013, 20:53
Stage 4 Supercharged. LOL
Jon_G's Avatar
Car: 2005 Accord iCTDi Tourer
Not heard of this problem, so can't offer a definite fix. I suggest these things could be possible culprits...
Sticky EGR valve.
Sticky IMRC swirl valve (or actuator).
Sticky turbo vanes (or actuator).
Jon_G is offline
post #6 of 6 (permalink) Old 19th December 2013, 06:12 Thread Starter
vision's Avatar
its had a new clutch fitted, at 1700 revs it judders but u can drive thru it.
its got me stumped.
It in today for a new exhaust manifold because mine is cracked.
may ask Honda but a 90 pound a hour this could cost a lot to find.
I plugged in a diag code reader its only bringing up a code for a engine coolant sensor
vision is offline
  Civinfo > 8th Generation Euro Honda Civic > Engines and Transmission
Human Verification
Fuel RC injectors misfire Laney Engines and Transmission 8 1st August 2013 20:24
Misfire at 3000rpm in neutral or when in gear kart n trailer Type-R 5 20th January 2011 20:52
Performance 1.8 slight misfire PWOOD Engines and Transmission 31 7th September 2010 14:20
Faults Engine misfire??? drover73 Engines and Transmission 15 19th January 2010 22:45
engine stutter / misfire @ 4500 rpm when not in gear Newbie76 Type-R 8 11th January 2010 22:43
