This thread is about: Diesel Civic, it's in Engines and Transmission at the Honda Civic forum Civinfo; Hello, Could somebody please tell me EXACTLY what iCTDi stands for. Thanks in advance Buzby...
Old 25th January 2008, 15:18   #1 (permalink)
Buzby's Avatar
Diesel Civic
Hello,
Thanks in advance
Buzby
Buzby is offline   Reply With Quote
Old 25th January 2008, 15:26   #2 (permalink)
IanG's Avatar
Intelligent-Common Rail Diesel Turbo Injection ???
IanG is offline   Reply With Quote
Old 25th January 2008, 15:30   #3 (permalink)
Looked on the Honda website.
This is the only abrieviation they did not fully explain!
It just said that the first i was for intelligent...
intelligent commonrail diesel turbo ? intercooler?
Old 25th January 2008, 15:32   #4 (permalink)
smurf79's Avatar
IanG got it right. Its intelligent commonrail turbo diesel injection. i-vtec is intelligent variable valve technology
Old 25th January 2008, 15:35   #5 (permalink)
All is revealed here:
i-CTDi
Old 25th January 2008, 15:42   #6 (permalink)
Wiki abbreviation list updated.
Old 25th January 2008, 16:12   #7 (permalink)
Buzby's Avatar
Intelligent Commonrail Turbo Diesel Injection
Thanks everyone its been annoying me for ages, glad to know what it stands for!!
Buzby
Old 25th January 2008, 16:26   #8 (permalink)
philiphenderson's Avatar
Don't ya just love forums. Helpful little things they are.
Phil.
philiphenderson is offline   Reply With Quote
Old 25th January 2008, 16:28   #9 (permalink)
Phil.
15:18 - Case opened
15:35 - Case closed
15:42 - Documentation updated
16:12 - Case submiter verifies receiving information
Result in under an hour.
Old 25th January 2008, 17:11   #10 (permalink)
CDTI, CTDI, TDCI, TDI.
Four different brand names for the same thing (except old VW-engines with PD instead of CR).
Opelguy is offline   Reply With Quote
Old 25th January 2008, 17:19   #11 (permalink)
You missed the Fiat one: TurD
Old 25th January 2008, 18:24   #12 (permalink)
smurf79's Avatar
How about Saab? Theirs is TiD or TTiD for the new twin turbo one
Old 25th January 2008, 22:07   #13 (permalink)
ASH
ASH's Avatar
Sorry, I know it's not the issue here but I've looked up to find VTEC stands for Variable Valve Timing and Lift Electronic Control. Should it be VVTLEC?
ASH is offline   Reply With Quote
Old 25th January 2008, 23:12   #14 (permalink)
Wine and cooking !
l-noel's Avatar
And two French one HDI for Peugeot/Citroen DCI for Renault
Old 26th January 2008, 12:33   #15 (permalink)
Perfect Guy!
Brodick's Avatar
I-ctdi soon to be replaced with I-dtec !!!!
Old 30th May 2008, 16:45   #16 (permalink)
intelligent-diesel turbo electronic lift control???
i-DTEC?
sergiogon is offline   Reply With Quote
Old 30th May 2008, 18:19   #17 (permalink)
rmh999's Avatar
Who cares as long as it goes whoosh when i press the pedal
rmh999 is offline   Reply With Quote
Old 31st May 2008, 02:35   #18 (permalink)
mr bluetoon's Avatar
mr bluetoon is offline   Reply With Quote
Old 1st June 2008, 12:27   #19 (permalink)
DerChef's Avatar
Basically years ago most passenger car diesels were indirectly injected, they used a rotary injector pump to inject into an anti chamber (called a "ricardo gomet") off from the main cylinder heard.
(this is opposed to gasoline engines that inject at low pressure into the intake manifold)
The reason for this was that injecting directly into the top of the cylinder itself caused very violent uncontrolled spontaneous combustions and the engine was noisy and rattly. However it was much more efficient than the indirect injection method that had considerable pumping losses down teh narrow throat from the anti chamber.
Then with the advent of more advanced electronic means of injection timing we saw the first generation of modern direct injection. eg VW/Audi TDi and rover group L series ect.
THEN a big advance the rotary got done away with in favour of two much more advanced systems
PD (VW Audi) these are electronic unit injectors i.e the injectors themselves do the pumping like hypodermic syringes
Common Rail (almost everybody else) uses a reservoir of fuel under pressure that can be drawn from and advanced electronically controlled injectors.
PD advantages can inject at very high pressures hence much more efficient combustion. Disadvantages is generally less refined and the injectors themselves are noisy (make a clack clack sound).
Common Rail cannot inject at as high a pressures as PD engines as it is not safe to do so. However common rail can do things like pre injection to make the rise in temperature and pressure much less sudden and this has a big boost to refinement.
DerChef is offline   Reply With Quote
Old 1st June 2008, 14:46   #20 (permalink)
Interesting bit of info. Having owned both now, is it then fair to say that PD is more fuel efficient than common rail? I can say I have found it so.
simon1 is offline   Reply With Quote
Similar Threads for: Diesel Civic
Civic Diesel with yun-it box fitted!! whooooshh!! Honda Salesman General commercial posts 16 2nd August 2008 09:21
New Civic Diesel Buzby General Discussion 7 20th January 2008 11:00
Civic Type R diesel. Biker1 John Pease Honda 3 8th December 2007 15:46
Used advice please!! looking for a civic type s diesel davep Buying, Dealers and Servicing 17 24th September 2007 16:28
Civic 2006 Diesel Sport - what's it worth willisthm For sale and Wanted 3 1st June 2007 10:14
