This thread is about: Warm start problems!, it's in Engines and Transmission at the Honda Civic forum Civinfo; Originally Posted by kevin@wilson4569.fsnet.co Just spoke to honda! Its a Glow Plug Relay that is to be changed and it is covered under warranty! to ...
Old 7th April 2008, 14:06   #21 (permalink)
Also found in orange
Palindrome's Avatar
to me this would determine how long the glow plug stays on for and if the car requires the glow plug to come on depending on engine temperature!
this would mean if the car is warm the relay may tell the engine that the glow plugs are not required to come on hence a non start!
Does this sound logical??
"If they try to fob you off with "lets sort out the glow plug prob and see how it goes" tell them the glow plugs do not even operate when the engine is fully warmed up, if so I fail to see how this can effect the warm start, even if they were faulty in the respect that they are comming on whilst the engine is warm this would not make a difference to starting."
When the engine is warm the glow plugs have no part to play in starting, they are there to aid fuel combustion and reduce diesel knock on comperssion ignition when the engine is cold.
If they fail in any way it will result in very poor or non start when the engine is cold!
Palindrome is offline   Reply With Quote
Old 7th April 2008, 14:12   #22 (permalink)
cnicolini's Avatar
I can recall reading about an issue with the Civic diesels where the glow plugs were staying on all the time and causing them to burn themselves out.
"Voltage regulator and/or earthing fault can lead to glow plugs of 2.2i CDTi staying on and burning out. No low oil warning light on diesels which can use as much as a litre in 600 miles, so vital to check the oil regularly. "
Car review: Honda Civic UK (2006 - )
Old 9th April 2008, 20:33   #23 (permalink)
civik's Avatar
fuel
I got car back from dealer on Friday saying I had contaminated fuel and its not a warranty issue. The fuel was drained and a new fuel filter fitted to the tune of £200 of my hard earned cash.
I was asked to bring car back to dealer to have a glow plug change! I asked why and they told me it was an update that was required and was through warranty. This to me is what would cause poor starting rather than contaminated fuel surely?
I drove the car away and the next day the problem is back! Dont think it was fuel at all, as car ran perfectly it just wouldnt start - intermittently.
Once the update is done if that sorts out the fault i will be asking for my £200 back!
Has anyone heard of egr valve issues? I saw that some accords had this!
have you filled the car anywhere other than a filling station?have seen a couple of accords(same engine)with low mileage and running starting probs that have been filled at farms and hgv workshops.
civik is offline   Reply With Quote
Old 9th April 2008, 23:38   #24 (permalink)
Dont think it is fuel related now as its been drained and fault still persists.
Glow plug relay made no difference as per "Palindrome's" coments. I think youre suspicions are correct.
Im going to book it back into Honda in morning.
Il keep yous posted, and thanks for advice.
kevin@wilson4569.fsnet.co is offline   Reply With Quote
Old 16th April 2008, 12:12   #25 (permalink)
Car in at Honda just now, they are looking at it under warranty at moment.
They have ordered a new No3 injector as there was little fuel coming from it????
My car returns 45mpg as it always has and it doesent stall or chug etc it drives fine. It just struggles to start! Surely it cant be an injector as it would play up all the time not just on starting?
Maybe palindrome can help me sus this one out please??
Regards.
Old 16th April 2008, 13:16   #26 (permalink)
gray52's Avatar
injectors should idealy be replaced in a set. i hope this clears it up, as i had a cold start problem on my last car and they never did sort it. the warrenty was up and i didnt want to write a blank cheque as no one knew what the problem was. i had 2 injectors replaced and made no difference what so ever. fingers crossed for you.
Old 16th April 2008, 13:58   #27 (permalink)
Palindrome's Avatar
Regards.
Hiya,
Whilst the injector is operating normally ie being fed high pressure fuel via the pump you could drive around the world and back but when the engine is turned off the system(injectors) should hold a certain amount of pressure to ensure there is enough pressure to re start.
If a faulty injector is suspected this will internally "leak off" the fuel to the return system thus causing a loss of pressure and and extended cranking to start as it builds the pressure back up.
We saw this a lot in the dealer I used to work in and I think your dealer has found it now.
Let's hope it's just the one as I'm sure Honda will not let them change all four!
Cheers Chris.
Old 16th April 2008, 14:31   #28 (permalink)
glad you have made sense of that as i was struggling to
I thought it was a regulator not holding pressure or fuel pump.
Here is hoping it is just one then!
they did say it was just the one that had little fuel coming through!
regards
Thanks for replies
Old 16th April 2008, 16:27   #29 (permalink)
pcr
pcr's Avatar
Still can't see how a single faulty injector could cause a warm start problem but is OK for a cold start.
Old 16th April 2008, 19:09   #30 (permalink)
Started with not starting when warm then it struggled to start at anytime, sorry should have pointed that out!
Just got it back from honda they have replaced all 4 injectors and its starting fine, they have ordered me a new starter motor too as mines was ready to pack in after umpteen extra attempts to start car.
All down to contaminated fuel- either some petrol or water etc in with diesel. Who knows how it got there.
Thank God all thats over
Thanks Palindrome your advice has been spot on.
Old 16th April 2008, 21:35   #31 (permalink)
If it's down to contaminated fuel it may indeed return with your next visit to the fuel station I know these problems quite well, since I used to live in Poland where fuel can be made of anything but petroleum at times... And this is why I can't quite believe the story. You would have to have a totally jammed fuel filter _before_ an injector can fail (apart from issues such as filling petrol instead of diesel etc.). And with a jammed filter you could simply not drive. I think it's been a faulty injector and therefore you are not likely to continue having the problem. Good luck
Old 16th April 2008, 22:27   #32 (permalink)
Palindrome's Avatar
Great news,keep me posted!
Still not convinced contaminated fuel was the problem but the injector/s is correct.
Did you get your money back???
Chris.
Old 16th April 2008, 23:46   #33 (permalink)
gray52's Avatar
i still have all my fuel receipts from new, so BP will be getting the bill if this happens to me out of warrenty.
that would have cost you well over £1000, and looks like honda have looked after you, and i bet all new HP pipes were used as well, and a new starter, 1st class service to your main dealer and honda, buy that service manager a beer!!!
Old 16th April 2008, 23:59   #34 (permalink)
beggs's Avatar
I drive a Type R it has failed to start first go al least 50 times thought it was starter motor it is booked in with honda on the 28 They said that there has been a few were the fly wheel teeth dont line up properly and this stops it starting so they havet to drop gear box out which i am not trilled about on an 8 month old car
beggs is offline   Reply With Quote
Old 20th April 2008, 11:54   #35 (permalink)
Fuel filter was dirty and the water trap was full ! I had to pay for that part but injectors covered under warranty.
I am getting a new starter motor under warranty on tuesday.
Not going to complain about my £200 for cleaning out fuel lines and new filter etc.
If it was contamination it wasnt Honda's fault so i have to take some hit for it.
Old 20th April 2008, 17:36   #36 (permalink)
gray52's Avatar
the question now is where do you get your diesel from?
Similar Threads for: Warm start problems!
Warm greatings to you all Civic Fan Introduce yourself 2 19th November 2007 13:17
Tech Unattended warm up dondon Engines and Transmission 33 19th November 2007 11:38
AC/Heater Heated seats - strange operation, and not warm enough Floop1977 Electronics 7 2nd October 2007 19:07
AC/Heater Slow to Warm Up Harrop598 Bugs, faults and irritations 16 6th April 2007 11:07
hello and warm greetings phil Introduce yourself 4 9th January 2007 18:26
