This thread is about: Engine Rattle, it's in Engines and Transmission at the Honda Civic forum Civinfo; I have noticed a loss of performance and a change in the engine sound of my Type-R following filling up at a garage last week. ...
Old 7th May 2008, 22:10   #1 (permalink)
Engine Rattle
I have noticed a loss of performance and a change in the engine sound of my Type-R following filling up at a garage last week. I noticed tonight that the engine sounded more wheezy, and when parked up idling I lifted the bonnet to hear a rattling noise in the engine. Obviously I am going to get in contact promptly with the garage but I wanted to check whether anybody had run into similar problems and what the outcome was. Would engine faults be covered in the warranty? Is there any maintenance that needs to be done on the engine (e.g. change the oil) in the first 8 months?
Thanks in advance.
paithuk is offline   Reply With Quote
Old 7th May 2008, 22:15   #2 (permalink)
Diesel of course
Have you topped up the oil level in the last 8 months?
Old 7th May 2008, 22:23   #3 (permalink)
No - is this required?
Old 7th May 2008, 22:25   #4 (permalink)
Type R GT 09570
Yes, I'd check your oil before you take it into the dealers.
Old 7th May 2008, 22:40   #5 (permalink)
Nobody gets out alive
NEEMSTAR's Avatar
have you checked your oil in the past 8 months?
if not ...
Old 7th May 2008, 22:44   #6 (permalink)
I have checked it a couple of times, once recently. Isn't there a low oil indicator anyway?
Old 7th May 2008, 22:51   #7 (permalink)
NEEMSTAR's Avatar
as long as you have checked it...
there is a low oil pressure indicator
which is when it is too late !!!! (bad decision by Honda)
VTEC thrives on oil
it won't engage properley when the oil is cold or the oil level is low
keep an eye on it mate
Old 9th May 2008, 17:48   #8 (permalink)
Woette's Avatar
so if the light comes on you have damaged the engine? i can hardly believe that, surely they cannot be that stupid to make the mechanism like that
Old 9th May 2008, 19:11   #9 (permalink)
NEEMSTAR's Avatar
"normally" if the low oil pressure light was too come on at speed its game over mate
new engine time
Old 10th May 2008, 14:40   #10 (permalink)
Lately Ive been hearing a rattling noise coming from around the timing belt only occured when I took the car out for some driving out in the mountains. Should i get it checked out?
cjcha4 is offline   Reply With Quote
Old 10th May 2008, 16:21   #11 (permalink)
Woette's Avatar
are you sure this is coming from the belt?
Do you only hear it when the car is driving or also when stationary?
I WOuldnt fly to the dealers straight away but if this keeps reoccuring then you might have to go....
Old 11th May 2008, 00:51   #12 (permalink)
Only noticable when I was stationary I heard a weird rattling noise, then had the bonnet up and had a friend with me who heard it as well.
Old 13th May 2008, 10:05   #13 (permalink)
Woette's Avatar
well if its that easy to reproduce, then i suggest a quick stop to the dealer and let them them hear the noise. They'll probably know whats going on and you can make an appointment if necassary.
Good luck with it
Similar Threads for: Engine Rattle
Squeaks Glove Box Rattle mikeydoo Bugs, faults and irritations 6 14th July 2008 18:22
Faults Engine rattle around 1400rpm quach Engines and Transmission 9 20th February 2008 22:01
Exhaust Engine rattle sound when cold on my CTR cnicolini Engines and Transmission 12 19th January 2008 18:44
Squeaks Do any not rattle? Swindon Japster Bugs, faults and irritations 10 6th October 2006 23:52
