| This thread is about: Hesitation - Un Smooth Engine (1.8), it's in Engines and Transmission at the Honda Civic forum Civinfo; My 1.8 doesn't seem so smooth. It appears to have slight hesitations up the rev range and of late I've had to change down on ... | ||
It appears to have slight hesitations up the rev range and of late I've had to change down on motorways to get back up to 70+ Also, I appear to be down on fuel economy. It's just not smooth. Like when I have the cruise set at 80 - it's like it accelerating, decelerating quickly all the time. Anyone had similar issues - any suggestions as to what it could be or should I just book it in? Cheers! Last edited by euphonium_john; 9th May 2008 at 12:20. |
from which year is it?
this could be down to old vtec software, my engine also felt unsmooth but after the update it has improved a lot. You should check the thread: i-vtec stutter |
Why Do I bother?
Do you use supermarket fuel at all? My sister had a similar issue with her Polo and the garage said I be you use supermarket fuel (which she did) they advised she should stick a tank of V-Power in it every so often in order to clean the engine as it probably had crap collecting somewhere. She did as they said and it stopped the problem and now she only uses fuel from Shell (not V-Power)
| Faults intermittent hesitation | shakie1973 | Engines and Transmission | 12 | 11th February 2008 15:37 |
| Oil Engine oil | rogie | Engines and Transmission | 1 | 10th February 2008 11:25 |
| Faults Slight hesitation around the 2200 RPM | Dave Taylor | Engines and Transmission | 79 | 24th September 2007 21:58 |
| Faults engine hic ups!! | civie | Engines and Transmission | 2 | 5th March 2007 20:51 |
| Other is civic hb engine type-r engine? | mrcanadian | Engines and Transmission | 1 | 26th October 2006 21:56 |
