| This thread is about: warranty problem, it's in Engines and Transmission at the Honda Civic forum Civinfo; my question.......i have a type S GT 2.2 diesel honda civic only new but because i have overfilled the oil level by 1 litre of ... | ||
warranty problem
my question.......i have a type S GT 2.2 diesel honda civic only new but because i have overfilled the oil level by 1 litre of oil honda says that my warranty is no good as the oil has caused damage to the engine. but i can't find anything on my warranty to verify their decision .........i need help on this matter .....????????
Nobody gets out alive
ouch
well maintaining oil levels are solely the responsibility of the owner so i don't think you have a leg to stand on mate... hopefully someone will come and disprove me just out of interest how did you overfill it by so much and what damage has been done? costs? |
It might be worth getting an expert opinion. OK, you overflled the oil and the engine is damaged but do not take the dealer's word that the two are linked. What is wrong with the engine ?. I bet overfilling happens all the time without any serious consequences.
if engine switched on it escelerates to full power and will not switch off followed by a lot of smoke and a tapping sound from the engine only way i could turn off engine was to put it in gear & jam the brakes it was like a vehicle possessed out of a horror movie but honda dealers blame it on excessive oil..........
Why Do I bother?
If you have overfilled the oil then they are correct- warranty on the engine is void. It states in the handbook that you should check your oil levels on a regular basis and it even gives advice on the best way to fill it. Not only that it also has a warning advice telling you not to overfill the oil level as doing this will cause damage to the engine.
Its a sore one, but they do advise you how to check and top up oil levels and if you have failed to do this properly then you cannot expect Honda UK to be held responsible for your error and pick up the bill to rectify it. If you had realised that you had overfilled it at the inital stage you could have drained the oil before driving the car and start over again. |
warranty problems
my question.......i have a type S GT 2.2 diesel honda civic only new but because i have overfilled the oil level by 1 litre of oil honda says that my warranty is no good as the oil has caused damage to the engine. but i can't find anything on my warranty to verify their decision .........i need help on this matter .....????????..................................... ....................if engine switched on it escelerates to full power and will not switch off followed by a lot of smoke and a tapping sound from the engine only way i could turn off engine was to put it in gear & jam the brakes it was like a vehicle possessed out of a horror movie but honda dealers blame it on excessive oil..........Any Ideas
#11 (permalink) | |
#12 (permalink) | |
diesel fuel itself has whats called a `rising characteristic` that is for a given amount of fuel the engine will rev up & up untill it blows up,thats why diesel engines are governed to prevent themselves from overevving & causing damage. has your engine sustained any major damage ? if you managed to stall it & saved the engine from any major damage then by draining the oil back down to the correct level it may be ok ! |
#13 (permalink) | |
Why Do I bother?
Right lets start at the begining, you say 'I have a type S GT 2.2 diesel honda civic only new' Care to explain this? Are you trying to say this is a new car? If so a couple of questions, if it is a new car why the hell did you top up the oil and do you know how to check the oil levels properly? Again as said before by myself and others Overfilling the engine oil can damage the engine and by 1 litre is an awful lot. Its you duty you check your oil levels on a regular basis when cold and if you have to top it up then you should do it in small stages leaving it for 5 mins, checking the level and then adding a little more if needed and carrying on like this until its at the Maximum level. The handbook from Honda advises you on how to maintain your car and its oil levels. They also warn that overfilling the oil can damage the engine. Its therefore not a faulty engine but an issue caused by you, therfore its not covered by the warranty. |
#14 (permalink) | |
Why Do I bother?
I would say that you fall into this - you have negelected to check and top up oil levels properly and have damaged you engine. Its a shame you didn't consult page 370 when you decided to top up the oil. Also Advising you not to go above the max line otherwise you could cause engine damage is not a suggestion and if you think it is, you shouldn't be in charge of a car! Last edited by angie4m; 9th May 2008 at 22:22. |
#15 (permalink) |
maybe a tad strong there Angie, but certainly some good points
Over filling with oil may damage the engine. This means that if you over fill it by a few ml, then the chances are pretty good that you will be ok Over filling it by a whole ltr - is kinda pretty much guaranteed to cause a problem I'm afraid And one which isn't covered by the warrenty It's a bit like the warning on page 295: "serious amage may occur if petrol is used in diesel engines" It doesn't say will occur - becuase if all you do is fill it up with petrol you will probably get away with it. If you add £5 of petrol to a tank which was almost full of diesel - you may get away with it (I wouldn't try personally though!). Hopefully hondatechs post will prove good news though - let us know how it goes |
#16 (permalink) |
Why Do I bother?
Maybe TT, but I wouldn't say that the Do not fill above Max line, doing so could cause engine damage is a suggestion though. Its quite clear that they are telling you not to go above the max line and advising that doing so may cause engine damage. I've never heard of anyone put 1 litre of oil straight in an engine like that before. So if they think that is a suggestion, i'd hate to see what else they think is a suggestion.
Still confused if this is a new car and if so why they did it in the first place. Opening line aint quite clear. |
#17 (permalink) |
When I was fitting new sidelight bulbs just after I'd collected my car from the dealer I thought I'd check the oil level and they had actually overfilled it! I rang them and they said it "shouldn't" cause any harm as it is a new engine and will be using alot of oil, but I thought it best to stick with the margins given and just check it reguarly. After reading this I'm certainly glad I did, If something had gone wrong I reckon the service guy would have had a bout of amnesia and remembered nothing about me calling them
I hope you get something sorted johnnyjo, although as others have said there really isn't any excuse for not checking the oil, especially in a new car. I don't know about everyone else, but I've got wee castrol stickers everywhere stating I should check the oil everytime I fill up with fuel... which off course I do |
#18 (permalink) | |
Why Do I bother?
I check it once a week but fill up about once every three weeks but still use the car in that time frame. Always check it on the drive in the morning usually |
#19 (permalink) | |
#20 (permalink) |
i check my oil by taking the car for a run, letting it warm up , then parking on a flat for 5 mins before checking it
that's the way i was taught but there are many different schools of thought |
| Warranty help | uncler | Type-R | 3 | 12th December 2007 00:04 |
| Warranty Warranty? | czechplastik | Buying, Dealers and Servicing | 21 | 27th June 2007 21:49 |
| Alloys Corrosion Are Wheels under Warranty | scol78 | Wheels, Tyres, Suspension and Brakes | 54 | 29th May 2007 20:49 |
| Fuel LPG vs. Honda Warranty | hhuberla | Engines and Transmission | 6 | 23rd April 2007 14:44 |
| Warranty warranty? What's that!!! | theonefelix | Buying, Dealers and Servicing | 6 | 7th December 2006 08:43 |
