| This thread is about: Oil Warning Light, it's in Engines and Transmission at the Honda Civic forum Civinfo; Hey guys, I'm just wondering at what point does the Oil Warning light come on. Only reason I ask is my mate has been going ... | ||
Moved on
Oil Warning Light
Hey guys, I'm just wondering at what point does the Oil Warning light come on. Only reason I ask is my mate has been going on about the very low MPG he is getting in his CTR and my trip the other week didn't help.
He has been saying about taking off the Milltek but I just keep telling him its his driving but yesterday after he had a wee search on here, he text to say he think he knows why the low MPG........his oil is rather low! I am slightly concerned for him as it was way below the low marker on the dip sitck, like almost off it! He's done over 6k in it and he's not had an Oil Warning light appear. I'm thinking he has a faulty oil sensor! I've pointed out that it not coming on and being that low could damage the engine but he is convinced that its fine. I just don't want him to rely on the sensor waning him when it seems it may not be working. I don't know when it comes on, it doesn't really advise in the handbook and I, unlike him check my oil about once a week. Anyone have an ideas? Last edited by angie4m; 11th May 2008 at 14:28. |
#2 (permalink) | |
Assuming quite reasonably,the min mark on the dipstick is the lowest permissable point,after which oil must be added,what on earth kind of mentality fits a low oil level indicator at a point below that level?(The last time I topped mine up at min at the dipstick not a single warning flagged) My 147 had a graduated level indicator and worked a treat |
Bournemouth Belle
My warning light came on when my previous civic had done around 5500 miles - was a shock! We stopped and checked the oil and it was just below the minimum mark. Left it to settle and checked again - was slightly higher and the oil light did not light up so driving slowly and carefully we bought some oil at the nearest garage, topped it up and was fine. Mentioned to dealer and they said it was fine and they also said is not unusual for a civic to use oil when 'new'.
If your mates is below/at min level wont be long before he does serious damage as warning light SHOULD come on a min mark. If I were you I'd keep telling him the cost of a new engine, which unless the sensor is faulty, wont be covered by warranty - prob wouldn't be anyway as it would be the user at fault for not checking/topping up. Mr Lippy says that the oil warning light is last resort and people should, as you do, keep checking. |
The oil level light does seem to be a bit random - it's only there as a bonus. The dipstick is what you should use.
Low oil level will not result in poor MPG though. So long as the input to the oil pump receives oil at all times, then the engine is lubricated. If for any reason, for any period of time, oil is not pumped into the engine, then damage could be done. The litre of oil between max and min is to allow the engine to use oil without you filling it up daily. Hopefully, when at min, you should still be able to tear the car around corners and there will be enough oil in the system so that the engine still gets oil at all times. Below min and you are taking a risk of momentary pressure loss and subsequent damage. If ever the oil pressure light comes on, then this means there is no oil at the input, and you are currently damaging your engine. |
#7 (permalink) | ||
Moved on
You are all correct, the oil warning light is a last resort and means that the engine is being damaged. I'll just have to pester him a bit more in order for him to check his engine oil on a regular basis. I do not intend to see my oil light at any point......and the cost of a new engine does not bare thinking about! |
#8 (permalink) | |
![]() Ups! Too big. Itīs in spanish, Iīm sorry. Iīll try to translate... If there is any problem with the oil level system, this symbol will appear, or this symbol with the message "check system" in the information screen. If you ignore this symbol/message and keep driving, the system will be seriously damaged. For furthe information, check page 476. No more useful information in that page. |
Moved on
Sorry, I think itīs my fault for my english. This symbol will appear when the level sensor fails. It warns you that the sensor of the oil level isnīt working properly, so if your friend doesnīt see this symbol on the screen, it does mean that the sensor is working fine...
#11 (permalink) | |
Moved on
I will just have to get him to check more often |
#12 (permalink) |
i am gonna check my oil when going home from work. At home the car is always parked on a slope and so maybe the oil read out on the dipstick isn't a 100% correct.
I WILL piss my pants if its suddenly below the minimum mark. Its still quite unclear to me why the oil light does not pop on earlier, after reading all the posts which mention engine damage already occuring when the light has just come on |
#14 (permalink) |
I think that the manual states that if the oil level warning light comes on then you have to top it up straight away. Whats the big deal, just check it weekly! Honda cover themselves by saying that you should check the oil at every fuel stop! Check the manual. Why take risks and wait for the oil light???
#15 (permalink) |
The sensor is for the oil pressure when the engine is running, it's not a low level warning light.
If the light comes on there is insuffcient oil pressure and could result in engine damage. |
#16 (permalink) |
My light came on about a month ago but thankfully was right by Halfords so was able to pull in and top up. The oil was just over the first dot on the stick (from the bottom).
#17 (permalink) | |
There are 2 sensors. One is the oil level sensor and one is the oil pressure sensor. If your engine starts to lose oil, the level sensor light will come on while you are driving (on my car it came on when the oil level was below the bottom line). Obviously if you then continue to lose oil up to the point when the feed to the pump starts to get air, then you will lose pressure, light the low oil pressure light and damage the engine. After an incorrectly fitted oil filter, I experienced the low oil level light after about 100 miles: Car dumped all of its oil |
#19 (permalink) |
It's fitted on all engines. The diesel shouldn't burn more (although 81% of 1.8 owners answered "hardly any" to the question "how much oil does it use" compared to 74% of diesel owners). Mine (2.2) needs no top ups between 12,500 miles services.
#20 (permalink) | |
Moved on
