This thread is about: Lower millage per tank with 98 octane petrol, it's in Engines and Transmission at the Honda Civic forum Civinfo; I own the car for two months now and since i got it I used to fill it up with 95 octane by ESSO. The ...
Old 15th May 2008, 05:48   #1 (permalink)
gm1980's Avatar
I own the car for two months now and since i got it I used to fill it up with 95 octane by ESSO. The car then averaged about 620 - 640 kilometers per tank. The last 3 fillings were with 98 octane by ESSO and i find it hard to go with more than 600 kilometers to a tank. Has anyone experience anything similar?
Old 15th May 2008, 17:31   #2 (permalink)
Woette's Avatar
I dont have any experience with this because my dealer told me explicitly that i had to run it on 95....
maybe because of the vtec system, i didnt ask him
gtz
Old 15th May 2008, 17:42   #3 (permalink)
Why do I come here?
Clive242's Avatar
I've never had the guts to put anything higher than 95 in mine.
Also, I was under the impression that the higher octane meant you could get the same performance from the vehicle with less right foot pressure.
If so, wouldn't any economy improvement rely on the driver relaxing their driving style?
Does that make sense? I'ts been a long day.
Clive242 is offline   Reply With Quote
Old 15th May 2008, 17:54   #4 (permalink)
TYPE R GT (R-15016)
Rich 11's Avatar
I always use Shell Optimax or BP Ultimate with a splash of Millers Octane boost
Rich 11 is online now   Reply With Quote
Old 15th May 2008, 18:45   #5 (permalink)
Andiww's Avatar
I used 95 and 98 and there were no difference in milage or engine work. I think there's no sense in buying 98. But i must try it with Vpower racing
Andiww is offline   Reply With Quote
Old 15th May 2008, 20:56   #6 (permalink)
Orschild's Avatar
According the manual you should use 95 or higher. A higher octane should give you a little bit more power, but going from 95 to 98 is fairly marginal.
Orschild is offline   Reply With Quote
Old 15th May 2008, 21:38   #7 (permalink)
Jack The Lad.'s Avatar
According to the City Wizz Kids, petrol will reach £1.80p per litre by the end of the year. S-d putting anything higher than 95 in the tank. Gawd knows what diesel will be. ??
Old 15th May 2008, 22:50   #8 (permalink)
fbssucivic's Avatar
Higher Octane fuels are really to prevent knocking. Chances are there is no more energy in a litre of 98 than 95.
Cars that require 98 and above have high performance engines.
e.g. a SLK 350 is quite happy with 95 whereas the SLK55 ( 5.5l ) requires 98.
Most engines these days have knock sensors and can adjust the ignition accordingly so running a car that requires 98 on 95 should not cause a problem.
I think the petrol companies push the higher octane as 'better' as they charge more for it and presumably make more money.
fbssucivic is offline   Reply With Quote
Similar Threads for: Lower millage per tank with 98 octane petrol
MPG How Many Miles To A Tank ? JUST4KICKS Engines and Transmission 55 8th May 2008 07:44
Suspension How much to lower by 30mm? eighteentee Wheels, Tyres, Suspension and Brakes 3 14th February 2008 00:30
MPG Wot mpg you get to a full tank on a FN2 lee.typer.gt Engines and Transmission 1 11th June 2007 19:45
Full tank on new Obo Buying, Dealers and Servicing 31 5th April 2007 21:59
Fuel What octane? 86CarloSDJ Engines and Transmission 12 2nd February 2007 13:22
