This thread is about: 2nd gear, it's in Engines and Transmission at the Honda Civic forum Civinfo; I have the 2.2 CDTi and I found that the engine starts to jerk and shudder if you go below 10mph when slowing down in ...
Old 31st May 2008, 05:59   #1 (permalink)
2nd gear
I have the 2.2 CDTi and I found that the engine starts to jerk and shudder if you go below 10mph when slowing down in 2nd gear. Is this normal? Has anyone else come across this?
Honds is offline   Reply With Quote
Old 31st May 2008, 12:15   #2 (permalink)
Without going out to check.. is this not because below 10 mph in 2nd you are at or below engine idle speed?
Diesels aggressively hold idle speed, so if you try to slow the engine below idle it will resist, resulting in shuddering.
Old 31st May 2008, 12:21   #3 (permalink)
Type R GT 09570
I also thought it must be because 2nd is not a suitable gear at this speed.
As I don't have the diesel though, I thought I'd let someone who has go first.
Similar Threads for: 2nd gear
Transmission 3rd Gear on my CTR Duecut Engines and Transmission 3 13th March 2008 15:12
Transmission 6th gear? MisterTee Engines and Transmission 30 6th March 2008 19:38
top gear vtec-hungry Type-R 22 30th August 2007 12:05
Top gear do it again ben hinkley Any non Civic chat here please! 2 18th May 2007 10:05
Top Gear or 5th Gear? czechplastik Any non Civic chat here please! 62 9th January 2007 23:24
