| This thread is about: 'Fluid' leak found after service, it's in Engines and Transmission at the Honda Civic forum Civinfo; Hi, Checked under the hood after the car's 25K service (as you do) and noticed what might be an oil (of some kind) leak...... Should ... | ||
Checked under the hood after the car's 25K service (as you do) and noticed what might be an oil (of some kind) leak...... Should I be worried? Am. |
Hmm looks like they might have spilt some oil when they were changing the oil filter. Did you only notice this after the service? The best thing is to clean it up maybe you can get the dealer to do it as it looks like they didnt do the job properly.
Thanks for the responses!
I gave it a bit of clean, and I haven't seen an further sign of oil, so it was probably a spill as you've mentioned. If you think that was bad, you should have seen the attempt they made to wash the car.... Am. |
| Faults Oil Leak on 2.2 i-CTDi | Soichiro | Engines and Transmission | 22 | 13th May 2008 14:43 |
| Windscreen Low washer fluid | euphonium_john | Bugs, faults and irritations | 29 | 1st February 2008 08:46 |
| Squeaks Brake fluid filler cap rattles. | pcr | Bugs, faults and irritations | 1 | 1st January 2008 10:15 |
| Leaks Leak in Rear | Exoi | Bugs, faults and irritations | 0 | 22nd September 2006 19:38 |
| Head screen / headlight washer fluid | TTDegs | Lights | 12 | 2nd September 2006 13:24 |
