This thread is about: Power loss with A/C on, it's in Engines and Transmission at the Honda Civic forum Civinfo; Did you notice a power loss in your 1.8 engines with air conditioning on? The engine is much more lazy, the clutch reaction is different. ...
Old 2nd June 2008, 17:35   #1 (permalink)
Andiww's Avatar
Did you notice a power loss in your 1.8 engines with air conditioning on? The engine is much more lazy, the clutch reaction is different. One good thing is that the engne sounds better with AC on
Andiww is online now   Reply With Quote
Old 2nd June 2008, 17:59   #2 (permalink)
cnicolini's Avatar
This is normal in all cars, the AC takes alot of power from the engine, its even noticable on a Type R.
You also lose between 3-5 mpg too!
Old 2nd June 2008, 19:19   #3 (permalink)
ViBe's Avatar
yeah i've noticed it during the hot days we've had here in sweden lately.. it's almost as if someone left the handbrake on. I usually turn the AC off and open the window while driving in the city because of this
ViBe is offline   Reply With Quote
Old 2nd June 2008, 19:23   #4 (permalink)
The Talented Mr. Robbieee
Robbieee's Avatar
In my old car, my headlights actually dimmed when u turned the AC on!
Old 2nd June 2008, 19:27   #5 (permalink)
It wasn’t me!
Ive never turned mine off
Old 2nd June 2008, 20:22   #6 (permalink)
morten's Avatar
With the AC engaged, mine seem to be really lazy rewing up to around 3000-3500 rpm. Above that, the car kind of wakes up again, and I feel no power loss... Weird...!
morten is offline   Reply With Quote
Old 2nd June 2008, 20:42   #7 (permalink)
No appreciable difference here. At idle you do notice a blip in the idle as it engages.
Nexxo is offline   Reply With Quote
Old 2nd June 2008, 22:20   #8 (permalink)
GHGH's Avatar
After what I've read, the A/C consumes 0,2 - 0,4 litres/hour on a sunny summer day.
So - how much this affects the MPG depends of the speed.
(And how many watts that equals is to late in the evening for me to find out now.. )
Old 3rd June 2008, 06:18   #9 (permalink)
ViBe's Avatar
According to my own not very scientifical observations running with my AC on will make my mileage go down by about 13%. It would seem about right with 0,4liters/hour
Old 3rd June 2008, 06:46   #10 (permalink)
i dont notice any performance drop with the A/C on or off...is'nt that the reason why the civic's A/C runs seperate from the engine unlike older cars? or do i have it wrong? heh
gphillips123 is offline   Reply With Quote
Old 3rd June 2008, 06:52   #11 (permalink)
Nor me
I've run weeks with it on and then off and no noticeable difference here.
Even turning it on during travel when you would expect to notice a difference to power doesn't seem to make any difference.
My weekly average MPG is constant regardless of on or off as well.
Old 3rd June 2008, 06:54   #12 (permalink)
hurricane's Avatar
I rented a Fiat Grande Punto in Greece last year with only 1500 kms on the clock. Going up mountain roads we had to keep switching the A/C off to get more power! I couldn't believe it, all credit to the wife, as it was she who suggested turning it off to see if the car went faster! And it worked immediately! Luckily in Finland there are no mountains, not really any hills either, so that will not be a problem for my Civic here.
hurricane is offline   Reply With Quote
Old 3rd June 2008, 07:07   #13 (permalink)
GHGH's Avatar
Don't notice any difference either.
However, energy density of petrol is about 9 kWh/liter, so with 0,3 l/h A/C consumption, the A/C will burn 2,7 kWh or 3,5 HP.
Old 3rd June 2008, 07:56   #14 (permalink)
TYPE R GT (R-15016)
Rich 11's Avatar
It's like applying a parchute when you switch it on , if you need extra power for overtaking , switch it off . apparently you can lose approx 5-10 bhp more noticable on petrol vehicles and deisels have more torque
Old 3rd June 2008, 08:06   #15 (permalink)
Moved on
angie4m's Avatar
I usually drive with it off but give it a wee blast every now and again to make sure its kept in good working order, however I did find myself on Saturday needing it as it was 22 degrees outside, no wind blowing and it made the car hotter when I put the window down so the aircon went on, I've also used it to keep my juice and water cold in the glovebox on my trip up and down south (which was great) other than that its usually off.
Old 3rd June 2008, 08:11   #16 (permalink)
22 degrees outside? heh wow its 22degrees in south africa and we're all cold...(:
Old 3rd June 2008, 08:14   #17 (permalink)
TYPE R GT (R-15016)
Rich 11's Avatar
Not so lucky here............. i hate a/c as it gives me a sore throat so I tend not to use it
Old 3rd June 2008, 08:36   #18 (permalink)
GHGH's Avatar
I'm using it during winter when the demisting function comes in very handy, and during summer - the 5 or 6 hot sunny days around here .
Old 3rd June 2008, 08:57   #19 (permalink)
Realistically, it seems to use very little extra power or fuel. It should disengage when you are demanding full power from the engine, and you can easily test how much resistance it adds by coasting down a hill in gear and switching it on and off (I can't feel it).
Here's a shot of what happened when I tried doing 100 miles at 65 mph, with the aircon on and the outside temperature 24 (from here):
Old 3rd June 2008, 10:20   #20 (permalink)
GHGH's Avatar
I can't say I have noticed any differences myself - but I haven't preformed this A-B test.
Seems like the driver's mood and the driving conditions are much more important factors .
Similar Threads for: Power loss with A/C on
Resale Value price loss in ten months CHRIS REDPATH Buying, Dealers and Servicing 20 29th February 2008 00:45
MPG Dramatic Loss of MPG trasnagh Engines and Transmission 132 15th February 2008 20:45
Phone Loss of pairing with Nokia N95 philiphenderson Electronics 8 29th November 2007 21:47
Engine Sudden Power Loss LuCiUs Bugs, faults and irritations 20 26th June 2007 10:33
Loss of interest? JPDirect Any non Civic chat here please! 9 17th April 2007 13:05
1 2 3 4 5 6 7 8 9 10 11 12 13 14
