This thread is about: Which Oil in your 2.2 CTDi?, it's in Engines and Transmission at the Honda Civic forum Civinfo; Originally Posted by Ancient Nerd Yes. Edge is for both diesel and petrol. The interesting point is that it does not claim to meet the ...
View Poll Results: Which Oil in your 2.2 CTDi
Castrol Edge 0-30W 25 14.45%
Castrol Edge 0-30W Diesel 86 49.71%
Other brand fully synthetic 21 12.14%
Hell, I don't care, anything goes in the filler hole! 1 0.58%
Who the **** knows - what ever my dealer decided 40 23.12%
Voters: 173. You may not vote on this poll | Withdraw Vote
Old 17th July 2007, 06:58   #41 (permalink)
cb550's Avatar
The interesting point is that it does not claim to meet the ACEA A1/B1 sequence that Honda specify as the preferred option for the 2.2 i-CTDI engine.
I'm trying to get an answer from Honda CS to confirm that Amsoil Series 2000 0W/30 is OK. This is similar. It claims A1/B1 and A3/B3 on the printed specification, but it turned out on the label to miss the A1/B1 spec.
BTW A1/B1 is the current economy spec
A3/B3 (& A3/**) are (I think) the heavier duty ratings, normally with higher viscosity ratings.
I'm assuming that both oils satisfy the A1/B1 or better. But I'm not using it until I've got confirmation. Does anyone know better?
If UK 2.2's have a diesel particulate filter (does anyone know for sure if they do or not??) then the correct oil should be to ACEA C3 spec.The oil is formulated to minimise fouling of the dpf.
Castrol Edge diesel 0-w30 meets that spec and Castrol Edge 0-w30 does'nt.
Old 17th July 2007, 08:26   #42 (permalink)
Ancient Nerd's Avatar
Originally Posted by Type S Bournemouth View Post
my dealer used 10w 40 in my civic and told me i can use any brand i want as long as its 10w 40 and part synthetic.
I strongly suggest changing your dealer. Read the manual. 10w 40 is acceptable as a second choice. But semi synthetic???
Then think what happens if they work on your engine with that sort of knowledge.
Old 20th July 2007, 16:58   #43 (permalink)
Sorry to say there is more than one Castol Edge. There is Castol Edge and castrol Edge Turbo Diesel 0W-30, Spec ACEA A3/B3/**/C3
This is designed to protect the paticulate filter. Put Castol into Google and check the web site. you can submit your car type and the recommended oil is shown.
djohnf is offline   Reply With Quote
Old 26th July 2007, 17:01   #44 (permalink)
vtidan's Avatar
My 2.2 had 10w 40 in it when I bought it, so I had the dealers change it to that 0w 30 oil that they recommend and my fuel consumption improved by 3 or 4 MPG!
vtidan is offline   Reply With Quote
Old 26th July 2007, 17:46   #45 (permalink)
DUNCAN's Avatar
WHY do dealers put 10w40 in ?????
Old 26th July 2007, 19:58   #46 (permalink)
madasadad's Avatar
Dunno, went to stealer yesterday for top up, and he tried to sell me 10-40 saying its the only oil they put in the CDTI. I couldn't be bothered arguing that the last refill pack I bought from them was Castrol Edge with an included refill pack, for £11.99. He's getting both in tomorrow and I'll be going for the 0-30 Edge.
Old 26th July 2007, 20:07   #47 (permalink)
DUNCAN's Avatar
honda should tell its dealers what oil to sell.come on honda do your job and lets put a stop 10w 40.
Old 8th September 2007, 03:25   #48 (permalink)
Dealer used Castrol SLX longtec FE 0w-30 at first service.
Old 1st October 2007, 15:15   #49 (permalink)
seejayess's Avatar
Originally Posted by djohnf View Post
..... Put Castol into Google and check the web site. you can submit your car type and the recommended oil is shown.
... and for the 2.2 HONDA civic diesel Castrol recommends the Edge Turbo Diesel formulation!!
seejayess is offline   Reply With Quote
Old 1st October 2007, 20:19   #50 (permalink)
Fish Bros of Swindon use Castrol Magnatec 10W40 A3 B3 in 1.8 and in the 2.2, they rekon you can use 0W30 but as its a thinner oil your oil consumption will increase.
I would check with your own dealer what they put in at service, because if they use a 10W40 you are just wasting your money topping up with expensive 0W30.
I am also not keen on mixing Full Synthetic with Part Synthetic, I was always told not to mix them
slowhand is offline   Reply With Quote
Old 6th October 2007, 10:49   #51 (permalink)
kamshaft's Avatar
ive had a service dont on my 2.2 and the dealer used shell helix ultra 5W-40,
kamshaft is offline   Reply With Quote
Old 6th October 2007, 12:21   #52 (permalink)
cb550's Avatar
Smile
My 2.2 was dealer serviced 5 months ago(approx.3k miles since) also using shell Helix.The dipstick level has'nt dropped and the car returns 48-55mpg depending on the mix of journeys.I'm more than happy with that
Old 6th October 2007, 13:35   #53 (permalink)
kamshaft's Avatar
well since having the oil change my car is returning less mpg, i get around 43/45mpg. Before i was getting 48ish. Would this have anything to do with the shell helix ultra 5W-40 that my stealer used?
Old 7th October 2007, 06:54   #54 (permalink)
cb550's Avatar
If the car checks out the same as before the service,including tyre pressures and the driving cycle is the same,you'd need to know what was in the engine before its service.
Presumably an 0w-30 engine oil would offer less engine 'resistance'-potentially a little more power/economy than would a 5w-40 oil.As the weather gets a little colder the car will take longer to warm up to its efficient operating temperature,which will have some effect on fuel economy.I reckon mine's using a tiny bit more fuel recently-say 1-2 less miles per gallon.
Old 9th October 2007, 18:12   #55 (permalink)
servanus771's Avatar
I cannot find Castrol Edge 0-30 w "diesel" variant, not even on the castrol website, so I bought the standard 0-3-w edge
servanus771 is offline   Reply With Quote
Old 9th October 2007, 18:50   #56 (permalink)
seejayess's Avatar
Halfords stock it and even Tesco's!! . . Castrol Edge Turbo Diesel 0w-30 1L Oil - Tesco.Direct
Old 9th October 2007, 20:53   #57 (permalink)
Angry
I apologise, it is on the castrol website and even at tesco, howver when you go on the castrol website and search by you car and enginer it directs you to the non Diesel specific variant of the oil
Old 9th October 2007, 20:55   #58 (permalink)
Angry Naughty Castrol Website
I apologise it is on the castrol site and even at tesco, howver when you are on the castrol site and search for oil by car and engine type it directs you to the non diesel specific variant of the oil
Old 10th October 2007, 07:57   #59 (permalink)
DJReto's Avatar
My dealer put Castrol TXT Softec Plus 5W-30 into my 2.2i-CTDI...
DJReto is offline   Reply With Quote
Old 11th October 2007, 10:55   #60 (permalink)
bikersupermoto's Avatar
Location: new baltimore, michigan, gods great country & glasgow, uk ((( US
oh my god, does all this really matter?...reading this from a distance i couldnt stop laughing at how obsessed people are with oil and mpg?....take car to the garage for its service when its due, an just fill up an drive, when the gas is empty, go fill up again. its only a car!. weird.
bikersupermoto is offline   Reply With Quote
Similar Threads for: Which Oil in your 2.2 CTDi?
Just bought an 06 CTDi KEN BYE Introduce yourself 5 21st February 2007 01:32
My car My new 2.2 i-CTDI Type S GT soon Type S 2.2 i-CTDI GT Buying, Dealers and Servicing 11 11th February 2007 22:44
Fuel Petrol into CTDI! wisha Engines and Transmission 24 7th November 2006 12:16
Tech i-CTDi SUPERTEACH Engines and Transmission 10 26th October 2006 12:43
Used What can I get for my CTDi EX ? Thoughts.... Roger Harris Buying, Dealers and Servicing 24 21st October 2006 04:45
