| This thread is about: Fuel pipe magnets and graphite oil?, it's in Engines and Transmission at the Honda Civic forum Civinfo; hi, i was speaking to a guy at work today, he mentioned u can buy magnets the tie wrap around your fuel pipe which excites ... | ||
hi, i was speaking to a guy at work today, he mentioned u can buy magnets the tie wrap around your fuel pipe which excites the fuel molocules to increase the efficiency, does this work? also he mentioned when doing an oil change to clean the engine out once you have drained it, then when you fill back up leave a 1/4 pint out or something along those lines and add the remaining bit with graphite oil. he said it neutralises the chemicals in the oil which reduces friction and increases efficiency, has any ever heard of or tried this? was thinking about trying them.
Nobody gets out alive
i always believe that if something is going to work (properley) then everyone would be doing it (including manufacturers and dealers).....
and on that bomshell i doubt these "ideas" would make a noticeable difference fella |
If it was as easy to get extra efficiency by simply putting a couple of magnets around the fuel line don't you think the manufacturers would be doing it? This idea has been around for years.
PS: I've just found this website that makes interesting reading: Slick 50 and other ail additives Last edited by allan40alt; 11th June 2008 at 18:20. |
#4 (permalink) | |
Have never done either of your collegues's suggestions and believe me would never either. |
I believe they cost around £7. That will be £6.99p too much then.
They were tested not that long ago on a T.V. prog' about fuel saving . The result ----------- Rubbish. |
You could always try this mod, port and polish the intake and exhaust.
Check this out Hey guys, please help with my mods gone wrong..... |
#7 (permalink) | |
...his mate at work told him to do it! |
#14 (permalink) |
adjust your driving technique
less throttle use the hills to maintain your speed brake less and earlier switch your engine when idling for long periods don't get enticed into traffic light grand prix use higher gears, earlier knows whats happening well ahead of you and anticipate so you can control your throttle and speed e.t.c |
#15 (permalink) |
i have been keeping it below 3000rpm, i filled it to 3/4 full with super unleaded, gonna see if using this from now on sees an slight increase.
#16 (permalink) |
About 10-12 years ago my next door neighbour sold these magnets that tie wrapped onto fuel lines and eventually talked me into buying one for my car. We checked out mpg carefully over a period of 3-4 weeks without the magnet, then checked it out with the magnet attatched, the results showed a small increase in mpg, approx 2 miles per gallon. At the time the magnet cost about £45, fuel saving was less than £1 per week, hardly worth the bother.
#18 (permalink) |
you have to change your driving style to achiev beter MPG. from the first 10000 myles my averange was 36.6 MPG with 2.2 Diesel Sport now i am driving with lower revs and using 5 gear in the city when posible and my averange for 6000 myles is now 53 MPG. i can easelay achieve up to 60 MPG driving long distances if i am acceleraing carefully.
and sory guys for my crap english ;]] |
#20 (permalink) | |
| Computer Fuel tank, reserve fuel??? | Fatgost | Electronics | 12 | 1st May 2008 22:05 |
| Fuel Cap | Vet_2010 | Styling | 4 | 1st April 2008 18:27 |
| Half-pipe in a car | trev0006 | Any non Civic chat here please! | 2 | 20th October 2007 13:37 |
| Fuel Ron | z1ppy | Type-R | 25 | 9th September 2007 07:43 |
| 'contaminated' fuel | Glass Spider | Any non Civic chat here please! | 11 | 2nd March 2007 09:05 |
