This thread is about: water leak, it's in Engines and Transmission at the Honda Civic forum Civinfo; Noticed over the last couple of days that when i've come back from a run in the car, I park in the drive (sloped) and ...
Old 7th July 2008, 19:56   #1 (permalink)
mr bluetoon's Avatar
water leak
Noticed over the last couple of days that when i've come back from a run in the car, I park in the drive (sloped) and there's a trickle of water starts dripping from underneath the engine bay, It's behind the engine but could be anywhere back as I park nose down! Only thing I can think of is the AC, anyone else get this or is there a major problem? btw no it's not been raining.
thanks for any info.
mr bluetoon is offline   Reply With Quote
Old 7th July 2008, 19:58   #2 (permalink)
Probably the aircon, and therefore not a fault.
Climate Control - Civinfo Wiki
If you suspect it is not, check your fluid levels, but in all probability it is the aircon.
Old 7th July 2008, 19:59   #3 (permalink)
Jack The Lad.'s Avatar
It is indeed the A/C. draining off.
Nothing to worry about.
Jack The Lad. is online now   Reply With Quote
Old 7th July 2008, 20:00   #4 (permalink)
Dalboy's Avatar
Your right its the air conditioning always happens after a run with air con on
Dalboy is offline   Reply With Quote
Old 7th July 2008, 20:36   #5 (permalink)
Thanks guys put my mind at ease
Old 7th July 2008, 22:27   #6 (permalink)
Type R GT 09570
But judging by the summer we are having so far it's not something that you will be doing that often.
Old 7th July 2008, 23:39   #7 (permalink)
Dalboy's Avatar
Or if it does you won't notice as the ground is always wet
Old 7th July 2008, 23:41   #8 (permalink)
Type R GT 09570
Sad but true.
Similar Threads for: water leak
Servicing Oil leak after service Bungle Engines and Transmission 5 3rd June 2008 21:38
Faults Oil Leak on 2.2 i-CTDi Soichiro Engines and Transmission 22 13th May 2008 14:43
Leaks Water Leak!! mugen2 Bugs, faults and irritations 12 1st February 2007 09:07
Leaks Water leak in-to rear mike222 Bugs, faults and irritations 22 10th November 2006 10:34
Leaks Leak in Rear Exoi Bugs, faults and irritations 0 22nd September 2006 19:38
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
