This thread is about: Slight hesitation around the 2200 RPM, it's in Engines and Transmission at the Honda Civic forum Civinfo; Hi My 1.8 SE seems to have a very slight hesitation point around 2200 RPM in 3rd & 4th. When accelerating. Its difficult to explain ...
Old 10th October 2006, 19:54   #1 (permalink)
Dave Taylor's Avatar
Hi
Its difficult to explain is not really like a misfire but you now when you go along and the air-con kicks in, well it’s a bit like that. (I have driven with the air-con off)
Only 200 miles on the clock but noticed it as I drove it away. I know its going to be difficult to demonstrate as it’s very subtle but when you drive a car every day you notice these little things.
Any idea’s or suggestions.
Re Dave
Dave Taylor is offline   Reply With Quote
Old 10th October 2006, 20:05   #2 (permalink)
Bungle's Avatar
With only 200 miles, I would just wait to see if it sorts itself out. The engine only really comes to life after a few thousand, so it might just need a little more time.
Hope it does go away!
Old 10th October 2006, 22:21   #3 (permalink)
basegreen's Avatar
Havent noticed that - but will try tomorrow.
Old 11th October 2006, 08:47   #4 (permalink)
Nick7's Avatar
Could be VTEC
Old 11th October 2006, 08:59   #5 (permalink)
Bungle's Avatar
Originally Posted by Nick7 View Post
Could be VTEC
I don't think so, i-Vtec doesn't kick in to around 4500rpm, and there is just a 'boost', no hesitancy.
I have felt small hesitations during acceleration a couple of times, but I put it down to the traction control sensing a wheel loose traction on uneaven roads and killing the power or applying that brake for an instant.
Old 11th October 2006, 11:23   #6 (permalink)
BeeBee's Avatar
You'd know if it were the traction control. The light would come on.
BeeBee is offline   Reply With Quote
Old 11th October 2006, 11:31   #7 (permalink)
Bungle's Avatar
I tend to look at the road while driving!
Old 11th October 2006, 12:07   #8 (permalink)
BeeBee's Avatar
It would catch your eye. Peripheral vision is very good at reacting to flashing lights.
Old 11th October 2006, 13:01   #9 (permalink)
The Great Soprendo's Avatar
May be unrelated but when I had a 2.2d for the weekend (I'm still waiting to own mine, unfortunately) I did notice a slight hesitancy in throttle response. I'd cruise along at normal speeds and then floor the throttle, and notice a slight delay (difficult to guess now, maybe 1/2 second?) before anything happened. My current Alfa 156 doesn't seem to have this characteristic, or if there is a delay it is much shorter.
The Great Soprendo is offline   Reply With Quote
Old 11th October 2006, 13:09   #10 (permalink)
smiffy's Avatar
Turbo lag.
Old 11th October 2006, 13:51   #11 (permalink)
Galaxy class starship
Copycat's Avatar
Turbo lag + the odd millisecond from drive-by-wire perhaps?
Old 11th October 2006, 14:33   #12 (permalink)
Nick7's Avatar
You're quite wrong here.
VTEC on R18A engine is similar to E-VTEC in 6th gen 1.5 engine.
VTEC on R18A alternates between two lobes - of which one is used to keep intake valve much longer open, to reduce pumping loses on light throttle.
What this means, VTEC has 2 stages, one is on low throttle, and 2nd is 'power' or actually 'normal' mode. To get to 2nd stage you need either to push throttle pedal more than some 50%, or at low throttle pass 3500rpm.
On attached picture is range of stage 1 and stage 2.
As you can see, this is quite different than on i-VTEC on K20 engine, or B16 or similar engines.
You can also check this link for some more info on R18 engine: http://paultan.org/archives/2006/03/...i-vtec-engine/
Old 11th October 2006, 14:38   #13 (permalink)
BeeBee's Avatar
That's interesting. So, basically, as long as you keep the pedal on the floor, you'll always be using the "power" mode, yes?
Old 11th October 2006, 14:59   #14 (permalink)
Nick7's Avatar
Yes - which also means you cannot hear/feel VTEC kick in.. as there is no VTEC to kick in than.
Old 14th October 2006, 16:04   #15 (permalink)
Greek Subtopic Moderator
skam's Avatar
i think that is the right answer...but Dave TAylor drivew a 1.8 petrol so no turbo installed. The drive by wire delay is a common problem (especially to VAG GROUP Cars) so it may have something to do with it. Search the aftermarket for the solution with that but i don't know if it worth the money. Havee anyone tried this stuff for the drive by wire delay...let us know
skam is offline   Reply With Quote
Old 14th October 2006, 21:29   #16 (permalink)
basegreen's Avatar
when idle and in neutral -- stab the gas pedal and note the dbw lag
Old 15th October 2006, 10:46   #17 (permalink)
Hi
A bit more info on my problem, it seems that it only does it after I just pull away (i.e. after the engine has idled).
I pull away go up through the gears and when I go from 3rd to 4th at 2200 RPM a slight hesitation, if I then go past that point and the drop dowm to say 1500 RPM and the accelerate through 2200 it does not do it.
It only does it again after I have come to a halt and then pull away go up through the gears and from 3rd to 4th?
Re Dave
Old 15th October 2006, 14:32   #18 (permalink)
basegreen's Avatar
I tried this earlier, no hesitation, but wasnt from idle, so will try again.
Old 18th October 2006, 20:24   #19 (permalink)
Unhappy
My experience in my 1.8 iVTEC is very like the subject of this thread but a whole lot more pronounced. In my case as I ease the peddle back the power will suddenly disappear altogether before the end stop is reached. When accelerating again nothing happens for the first few mm of peddle travel until a certain point when the power suddenly comes on with a bump. This makes for a very uncomfortable driving experience especially in first gear and when the revs are anywhere above 1500. I have done 7000 miles and it has been like this since new. My garage says all Civics do it and it’s because it’s drive by wire. Honda Technical are said to have agreed with this. Am I being spun a line? Do all Civics do this? Any inputs appreciated.
Blue Max is offline   Reply With Quote
Old 18th October 2006, 20:50   #20 (permalink)
basegreen's Avatar
I think this is due to driving style making the DBW system "adapt" in an unusual way. This is not a criticism of driving style, just something different that makes it like this. Have you driven a demo car with similar mileage or less? Does that car do it? If not - there's a problem. First is very aggressive and can be uncomfortable if you are not careful with the pedal travel. Try a different foot position.
Similar Threads for: Slight hesitation around the 2200 RPM
S-Red Some slight changes! robbo51 Gallery 65 5th May 2008 20:20
Alloys Damage Slight Kerbing... should i...? sambuca2907 Wheels, Tyres, Suspension and Brakes 3 18th September 2007 22:13
Faults Slight noise at tickover Russell 10 Engines and Transmission 10 24th February 2007 07:42
