#521 (permalink) | |
![]() Join Date: 26th February 2008
Thanks given: 5
Cheers Tim |
Thanks to oilman from:
#523 (permalink) |
Oil Overfill
Hi
I just bought a 2009 2.2 Diesel froma dealer a couple weeks ago and a check on the oil level reveals somebodys filled well over the upper mark (equivalent to length between lower and upper again). Presume I should get this drained? Should I be worried that this has caused any serious problems? Thanks Ross |
#524 (permalink) | |
![]() Car: Civic FK3 2.2 Sport
Thanks given: 2
If your car have dpf, the extra amount of oil can be caused by fuel diliution...otherwise somebody over filled it. In any case you must drain immediately. If your car has DPF, and the excessive amount is caused by fuel dilution, you should also perform an oil change. Meanwhile, you must drive your car quietly, to avoid excessive pressure. |
#528 (permalink) |
Yes, I have only had the car a couple weeks and have not added any oil. I have used about 3/4 of a tank driving so far. I should have checked it earlier.
#529 (permalink) |
![]() Join Date: 29th July 2012
Thanks given: 5
Hi Oilman,
I have a 1.8 civic ES. Only do 5000 miles a year and thats lots of short town journeys. What oil would you recommend? No modifications at all. Thanks |
#530 (permalink) | |
Thanks given: 2
Idem for me, i not have necessity for a 0w40 But reading many past discussion on this board i noticed that there are many common places about sae grande and 0w30. Few know that on the market there are also 0w30 oils thicker than 0w40 oil, and there are a lot of 5w30 thinner that many 0w30 oils at all temps. Sae grade tell you a little story on a really oil spec, but not all and already the ACEA apec can tell much more about the thickness of an oil. A 5w30 B1/B5 will almost always lighter than any 0W30 B3/**. Honda reccommends 0w30 for "comodity" and security, with this grade certainly you not wrong and most of the people do not want see and analizes boring technical pdf sheet. So, a 0W30 is "certainly" right, but not "necessarily" the best you can get. Also, the great advantage of a 0w30 came in -20°C climate, where is designer to be really lighter, but this, with italian climate , is pure teory. There is also to say that the basis for formulating a 0W30 are almost always excellent. This is another reason why Honda recommends rightly to use this grade, because whatever you choose, definitely choose well. |
#531 (permalink) |
Thanks given: 5
Unless there has been poor quality control, a 0w-30 should not be thicker than a 0w-40 at operating temperatures. A B5 0w-30 might be a little thinner than a B3 0w-30, but the difference is minimal.
Cheers Tim |
#532 (permalink) |
Thanks given: 2
Hi tim, yes, you are right but my example was "intentionally" extreme, but really there are 0w40 lighter than a 0w30. It is the case of Castrol Edge 0w30 A3/B3 LL-01. It have an hths value of 3.6 and VI 167. Mobil 0w40 NL have hths value 3.68 and VI 186...so Mobil 1 will be a little lighter in every situation. And this statement fits perfectly with what my oil pressure gauge shows me.
#534 (permalink) |
Thanks given: 5
Amsoil MTF, Redline MTL and Fuchs Sintofluid are ideal.
http://www.opieoils.co.uk/c-670-75w-80-75w-85-mtfs-manual-transmission-fluid.aspx Cheers Tim |
#535 (permalink) | |
aka Paul
![]() Join Date: 14th April 2012
Thanks given: 719
#536 (permalink) | |
![]() Join Date: 2nd March 2011
Thanks given: 574
Wont be till next month atleast sorry. Lol! Sent from my Galaxy Nexus using Tapatalk 2 |
#538 (permalink) |
![]() Car: 2009 CTR CW Mugen Parts
Thanks given: 4
Hi Tim,
in my 2009 CWE is OEM Honda HFS-E 5W30. What is your opinion about this? Regards. Last edited by R-Lars; 2nd September 2012 at 00:40. |
Similar Threads for: Oil advice and recommendations here
| Mobile recommendations | apemonkeyman | Any non Civic chat here please! | 22 | 6th July 2007 16:48 |
| Cleaning the exterior - recommendations *** | Fedorov | Cleaning | 21 | 28th January 2007 21:14 |
| Speakers Size specs and recommendations for speakers needed | phuket | Ipods, MP3 Players and ICE | 1 | 3rd January 2007 09:38 |
| Car Seat Recommendations? | TheBull | Any non Civic chat here please! | 3 | 2nd November 2006 14:38 |
| UK Satnav recommendations please | Fedorov | Any non Civic chat here please! | 17 | 6th September 2006 21:33 |
